agreed, looks like the clutch sensor - either bottom or top mounted depending on the year for starter interlock and/or cruise disable.
Maynor is your car in the GRM UTCC!? if so that would be awesome to see such a nice e36 lsx showcased.
you should make those brackets and sell them, seriously, I can think of some people that would like them...
I wish I was in the UTCC this year. Didn't know if I'd have the car ready in time with the broken rocker, cracked wheel spokes (CCW service ROCKS by the way) and this modification.
I'll be there for support for some friends who are in it however and racing over the weekend. I have no welding skills so I asked a local shop to make up and install that bracket. I really wish I could weld... handy skill to have.
Thanks for the info on the clutch interlock. Looks like I can toss it and save a few more ounces of weight.
John
E36 LS3
John,
Very nice!
It HAS to help!
After three brutally hot sessions today at VIR (one more to go), I can definitively say the 7/8" clutch master is absolutely amazing! I had no idea the TR6060 could be this buttery smooth when it comes to shifting.
My high rpm downshift issue is gone. It's almost boring how quick and smooth the shifts now are. Even idling, rowing the gears has zero noticness or bind.
I'm pissed I didnt do this sooner because it's a slap in your face difference. Word of advice, If you have any notchiness whatsoever, if gear changes arent buttery smooth, in any gear, at any rpm/speed, your clutch master should be considered suspect.
John
E36 LS3
do you can write some diy for install this 7/8 master cylinder in e36 with all part numbers?
great that you resolved this problem.
http://www.youtube.com/watch?v=Ocrvaw3d4UM Dont drive over limited speed!!! Drive safely......
2003 M5 LSx l 6 Spd Manual l 4.10 LSD
Build Thread
The chassis must always be regarded as a means to an end and never as an end itself
Foler,
Unfortunately, no write up. The part number for the master cylinder is in my post one page back. The bracket was custom done by a local shop. The fittings to connect the master cylinder to the stock pedal were off the shelf hardware. Everything else was fairly plug and play as far as the hose connections go.
Schitzo, Wai!
John
E36 LS3
did you ever solve the clutch sitting 3" too high?
so i am fixing a swap car, and well i dislike how high the wilwood cmc causes the clutch pedal to sit, anyone have any solutions???
[img=http://s15.postimg.org/bm6rs1gh3/image.jpg]
[img=http://s8.postimg.org/ga2ezpc4x/image.jpg]
Cut the pushrod shorter and re-thread it?
95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
10.4@136 Pump gas at 3530lbs.
Build thread
http://www.bimmerforums.com/forum/sh...LS-Turbo-build
Hi John,
I was reading through the forum and found that you upgraded you master cylinder to wilwood one, tried to search through the posts where you posted photos for under the dashboard of the bracket.
Is it possible if you could post the photo again.
Sam
Z3-LS1/T56
Hi John,
Sam
Z3-LS1/T56
Sorry Sam,
Those pictures are no more and I no longer have the backups (or the car).
John
E36 LS3
@samramgarhia , I sell kits that adapt the 7/8" Wilwood master to the stock location. I'll send you a DM.
www.LantzFab.com
2002 BMW 525i - 6.6L LS Turbo Swap
Follow me on Instagram at @LantzFab
Link to LantzFab.com
Link to my Facebook page
Link to my build page
