Results 1 to 16 of 16
Thread: Gas Pedal Squeak
    Sep 2008
    Portland, OR
    1995 525iM 157,500
    Gas Pedal Squeak
    Ok, i have never read a thread about this before but i cant believe that i am the only one who has this problem. When i push the gas pedal in and out, it squeaks...is there a simple solution to this? I cant tell where exactly the squeak is coming from so i cant tell what i should do to make it stop. I usually turn up the music so i dont have to hear it...lol. WD40? Grease somewhere?
    Sep 2008
    Chesapeake, VA
    '12 Golf, '95 540iA sold
    I have the same problem and I would like to know the solution for this as well.
    Sep 2008
    Portland, OR
    1995 525iM 157,500
    its so annoying! however sometimes i can use to annoy people who are bugging me in the car. it doesnt take much, i usually point it out and they usually say "well i didnt notice it until you said something but now i cant stop hearing it! AH!" lol
    Aug 2009
    Strafford, NH
    95 BMW 530i
    Just try spraying behind the pedal with some WD-40 and see what happens. I did the same with my brake pedal and it worked.
    Canada
    1992 535i
    I sprayed WD-40 on the hinge, very quiet now.
    Sep 2008
    Portland, OR
    1995 525iM 157,500
    i figured as much. i'll try it and see what happens. i just wasnt sure if it could be something else. thanks for the input.
    San Rafael, CA
    1995 AlpineWeiß 525i
    I had the same problem. I used tri-flow which is what I use on my bike chain. Any type of lube will do.
    Well, not any type.
    Sep 2008
    Portland, OR
    1995 525iM 157,500
    haha yeah you have to be careful that you dont use the wrong stuff
    PA
    Girl car
    If you want to actually fix the problem for a good while, pop the pedal rod out of the pedal cluster, clean the rubber bushings and regrease them with white lithium grease. Also clean and regrease the hinge on the floor.
    Vehicles:
    (Sold) 95' 525 - ZF320 5-speed swap, 3.46LSD rear, Raceland headers + straight pipe
    (Current) 2012 Scion tC 6-spd M/T - slow
    Sep 2008
    Portland, OR
    1995 525iM 157,500
    how do you pop it out? is it pretty simple? never done it.
    PA
    Girl car
    Quote Originally Posted by pdx e34 View Post
    You may have to remove the lower portion of the dash (black piece), but it pops out easy. There is a clip that holds the pedal to the cluster, then there is a spring that wraps around it that is easy to pop off, kind of have to look at it. After that just pull the pedal off the cluster and clean it.
    Vehicles:
    Sep 2008
    Portland, OR
    1995 525iM 157,500
    cool. i have the day off tomorrow so when i get done moving my buddy, ill take a look at it. thanks.
    Tustin, CA
    2002 BMW Streetcarver,
    I used wd40 but it wore off after a few months. I just turn the radio up so i cannot hear it.
    Nov 2007
    NYC
    86 911, 91 XJ
    Quote Originally Posted by MaxSteel View Post
    Well, not any type.
    i have the same problem..oh wait
    Nov 2018
    North Carolina
    2000 Bmw 323i
    Im having the same problem now. What did you do to fix it?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    You have a 2000 323i, here is the E34 forum, I noticed that you already asked now on the E46 forum, there you will get the answer for the 323.
    As for the E34, just change the 08 Bushing D=12,2MM 2 35411154172 , they crumble away when old http://www.realoem.com/bmw/enUS/show...diagId=35_0136
