Is there a way to replace the left blade without spending a rediculous $40 for it? There probably is but I haven't done enough research. Suggestions would be great thanks.
Not Much. EAT Chip. Beyern Mesh 17".
All parts stores and websites want around $40 for one. I'm kind of wondering if a regular $15-20 blade would connect to the arm?
Cheapest way is to get the replacement blade insert and keep the wiper.
Although, if you want to get a new set, I think Pelican Parts sells the set for ~$40 (both)... but let me double check that.
EDIT: So pelican sells the left arm (non-OEM part) for $15.75. and I know you can get any wiper from any auto parts store for the right side.
on my 91 i used the cheap walmart blades, but if i remember right 89 had something weird and you couldnt use a standard blade correct?
03 mustang gt, 96 Land Rover Discovery, 95 740i, 06 750i
Yeah guys, on the 89's the driver's side wiper blade is inverted, OP is looking for a cheap way to make it normal.
Current Fleet:
E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
Past:
E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
E39 1998 528i 5-Speed Black on Black - Sold locally.
E34 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
why not just swap on a newer arm so you can use a normal blade?
I think it's dealer only. My parts suppliers don't carry them. They do carry the right side though.
-M30 | Miller W.A.R. Chip | Miller MAF conversion | S3.73 | Single Mass flywheel | e60 ssk | 25,20mm Sways | Vogtland Springs | Glasspack ~RIP~
heres what you do, go to a junkyard, find an E34 or E32, take out the passenger side wiper arm, take off your drivers side wiper arm, put new junkyard arm on and voila. No more fussing, fit any blade you want. Best way to go imo, don't risk having that little spoiler scratch your windshield like it did mine.
yeah just take an arm off of one thats not inverted and then get normal blades. thats what i did on my 90 525i and what i plan to do with my 535i
13 Grand Cherokee Limited V8 - Daily Driver - Wife
97 Z3 2.8 Roadster
95 325i Sedan - Project #ebayE36
90 BMW 535i/5 - i should probably work on this again...
I own mostly junk. Except the Porsche, that's kind of cool.
All the motorcycles are trash which you can read about at
http://oneguytwowheels.blogspot.com/
I'll update it eventually
Thansk
yeah i had to modify the post to get the arm from a newer one to work. forgot about that tidbit heh.
97 Z3 2.8 Roadster
So, what are some solutions? Some people said that they had friends cut and weld it to the other side, but then that is chopped across the wind-screen.
Can't swap one over from the later year cars, either.
Current Fleet:
Past:
I don't have any issues with my 89's arm. I just buy the bosch replacment blades from Autozone and install. I need to work the normal pass side hitting the hood issue.
