I won't call it a "problem" yet because it's just annoying now. Occassionally (2-3 times a week) if the coupe has been sitting for a while (while I'm at work for instance) when I come back out to start it there is an issue. The vehicle cranks with plenty of power, and as long as you keep the key forward - it will crank alllll day without starting. Now, flip the key back to the "off" position, and crank it again - she fires right up. Seems like a fuel, or a relay issue, no?
:suscribed:
2000 Z3 MCoupe, '01 LSB E46 M3, '99 GTI VR6, '06 Audi A4, Andrew '95 Avus M3
crankshaft position sensor? Any check engine lights? Any other symptoms?
Kyle
88M3, 97 840Ci.
Nope, absolutely nothing else. No cel, performance is great, it's almost like trying to start a car with no gas.
I had exactly the same problem with my E46 M3 for over 2 years. Happened a few times a week for me but the dealer was never able to reproduce it. Ended up selling the car before I figured out what the heck was going on.
S-54, right?
Just wait one (1) second in the ignition on position before going immediately to the start position.
Problem solved.
S-54s don't maintain a pressurized fuel rail, unlike the S-52s do.
Last edited by Randy Forbes; 02-22-2010 at 12:47 AM. Reason: Automerged Doublepost
Yep, I usually wait to let the fuel pump prime the system then proceed to the 'crank' cycle as a good way of pausing on cold starts.
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: and a visit to Randy Forbes
I always wait a second or two as well.
Now, on a somewhat separate note, I sometimes noticed a delay in starting as if the battery is going out. Cleaned the battery terminals and haven't had it come back yet.
SOLD MAY '14
Mods: 6psi Supercharger kit; Rogue RSM's; DINAN strut brace; Magnaflow exhaust; Stewart waterpump; Stoneguards, Glove box fix, M Shift knob; Aux input adapter; Mesh bumper grill; Projector Z II headlights (35W Xenon), IE alu radiator, ARD wheel studs, H&R coilovers, Work VS-XX wheels/Hankook V12 tires, VANOS fix
