Page 32 of 32 FirstFirst ... 72223242526272829303132
Results 776 to 786 of 786
Thread: How to Install and Use SSS\Progman with Carsoft int.
  1. #776
    Aug 2020
    Iquique, Chile
    2005 R52 Mini Cooper S
    Hello everyone!
    I was looking to download SSS and Progman, but there's files missing in 4shared.
    As far as I've seen, files missing are:
    ProgmanV32 disc 1.part001.rar
    ProgmanV32 disc 1.part036.rar
    ProgmanV32 disc 1.part049.rar
    ProgmanV32 disc 1.part065.rar
    ProgmanV32 disc 1.part071.rar
    ProgmanV32 disc 2.part01.rar
    ProgmanV32 disc 2.part03.rar
    ProgmanV32 disc 2.part05.rar
    ProgmanV32 disc 2.part07.rar
    ProgmanV32 disc 2.part08.rar
    ProgmanV32 disc 2.part09.rar
    ProgmanV32 disc 2.part40.rar
    ProgmanV32 disc 2.part42.rar
    ProgmanV32 disc 2.part45.rar
    easydis en gt1.part01.rar
    easydis en gt1.part05.rar
    easydis en gt1.part06.rar
    easydis en gt1.part17.rar
    This is the folder I'm downloading from:
    https://www.4shared.com/dir/LfFoCBq2...s_Machine.html
    with the bimmerforums password.
    Could someone please re upload them? or are they somewhere else?
    Thank you!
  2. #777
    Oct 2020
    Moscow
    2007 BMW 6 Coupe
    Does anyone have progman 26-28?
  3. #778
    Nov 2020
    Lithuania
    BMW F11 135 kW
    Who can give a link of deskription, from where get a files : Open folder “copy files from this folder to C-EDIABAS-Ecu” and copy all files to folder C:\EDIABAS\Ecu;
    Thank you
  4. #779
    May 2019
    SC, US
    1999 BMW 323i sedan
    Is it possible to connect to the DME of a E46 when the car is in the ON position. Whenever I try to do a diagnostic on my car using an AUTOPHIX 5900 OBD2 scanner it says it's unable to connect to the DME
  5. #780
    Nov 2021
    Istanbul, Turkey
    2013 BMW 525D Xdrive
    Could you please share the current link?
  6. #781
    Mar 2020
    Eastern Europe
    BMW e39
    Hello guys! Can someone post a new link?
  7. #782
    Nov 2014
    Sofia, Bulgaria
    E60 530d
    Hello All
    My Progman cannot program because of voltage(13V) prevention. I read the problem can be solved with one of the changes pack SSS Full Start.iso/changesV32CrackFProgman.iso - can somebody help, I do not find it anywhere?
  8. #783
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by jorisimo View Post
    Hello All
    Curious why you don't use WinKFP and/or NCS Expert and a K+DCAN for this?
    It's super risky to SSS Progman or even ISTA-P with non approved interfaces for programming.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  9. #784
    Nov 2014
    Sofia, Bulgaria
    E60 530d
    I have a big problem with coding an old X5 E53 DSC module - the car has removed automatic gearbox and air suspention and now works with manual gearbox and spring suspention. I used ZEKO to generate new ZCS without automatic gearbox and air suspention, the ZCS is successfully coded to the master modules(EWS and KMB), but now the DSC got "Coding error (23)" and doesn't work. I coded the DSC milion times with NCS Expert, GT1 DIS, Launch, but the error stays I wanted to use WinKFP, but I cannot find Sp Daten which includes ZUSB files for DSC57. The Progman is my last option, but it doesn,t work!
    I will do appreciate any help for solving this problem.
  10. #785
    Jul 2004
    Houston, TX
    36 Cylinders
    That DSC does not have flashing, so WinKFP and Progman will not help there.
    It will definitely have to do with the coding, which can all be managed with NCS Expert. Progman and others are not any more special, they all use the same.
    Zeko is not necessarily accurate in generating a ZCS from nothing.
    Can you please post the original ZCS from the vehicle in a new thread here? Also post the content of the fsw_psw.trc file after doing codierdaten_lesen on DSC?
    -Abel
  11. #786
    Vestal, NY
    E30S62, E21S54, E31S85
    Hey any update on this on how you solved this? I'm doing a 6MT swap on my E53 and can't code my 0265950067 DSC57 unit. I also ironically can't find the ECU Family DSC57 in Winkfp even if I wanted to use a different ZB.
    Does anyone know what ZB would work for WINKFP flashing the DSC?
    Frank Macaluso - BMW Drivetrain Transplanter
    Frank Macaluso
    http://www.garageaholic.build
    BMW Engine Swaps
    Current Swap 2016 LT1/6 into E24 6er
    607-953-9587
    Contact@garageaholic.build
