If you look at page B12 of the PROGMAN handbook (access it from the PROGMAN home screen) it will tell you which type of interface you should use with your car, EDIC is generally for older cars like E36 and E39, OPPS will be for cars built pre 03/2007.
All the fuss with installing program I have never used it and ended up deleting it to free up some HD space on my laptop. I use NCS instead...
OK, you obviously don't want to look the PROGMAN documentation up, so I will make it easy for you - here is page B12 PROGMAN page B12.pdf from the info on that page you can see that E90 requires OPPS/OPS interface not EDIC. You don't need to reinstall the entire PROGMAN SSS program to change interface file types. Just go to the step where you install the changes.iso file and proceed from there. The entire procedure is well documented earlier in this thread.
I tryed to use OOPS didnt find my car btw i need ti tell that in firstmy post i need several interfaces because i got e39 too so its what about im talking that edic not shown in interface men after installing changes_v2
Re-install changes_v2.iso.
Can anyone set me up with a valid link to this stuff? I may have just flushed $10 on a 4Shared account to download files which have been reported and taken down...
Anyone have a link or a copy of the SSSFullStart.iso changes file?
thanks,
tmaxx445
2001 740i / S62 Swap / 6 Speed Swap / Titanium Silver Metallic / Grey Montana Leather / M Sport / Convenience Pkg / Heated Seats / PDC / MKIV Navigation / DSP / Bluetooth TCU / Dice Mediabridge / Vavona Trim / Illuminated ZHP Shift Knob / Short Shifter / Cat Delete / SAI Delete / Euro Tune / Koni Singles / H&R II Springs / Custom 3.15 25% Limited Slip Diff / Staggered OE M Parallels / 275 & 245 Firehawks / Euro City Lights / Celis Tail Lights / SunTek 70% CXP Tint
2005 M3 Coupe / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium Pkg / Cold Weather Pkg / Bi Xenons / Adjustable Bolsters / MKIV Navigation / Harman Kardon / Bluetooth / Sirius XM / Aux In / Carbon Trim / ZHP Shift Knob / Short Shifter / StreamLine Intake / SS Headers / AR20 Resonator / Exhaust Bypass Valve / P0lar Tune / Koni Yellows / Eibach Springs / Staggered OE CSLs / 275 & 245 595 Evos / Angel Eyes / CF CSL Splitters / SunTek 38% Carbon Tint
2003 4.6is X5 / Stock /
You will need to rename the attachment from a .pdf to .rar, then unRAR it using WinRAR.SSS_Full_Start.pdf
Yes, once you have renamed the file to SSS_Full_Start.rar and extracted it using WinRAR, you will have the .iso image. There is no provision for sending you the extracted file as an attachment to a forum post.
Try just renaming this SSS Full Start.pdf to SSS Full Start.iso - it will save to burning the files you have to .iso format.
I have BMW E60 525i, what is correct change iso for my car ???
SSS Full Start should be fine with your car if the build date is pre 03/2007, if it is later you will need to use this Changes_by_XDrive_v2.pdf (rename from a .pdf to an .iso file).
Does anyone have a valid link for progman 24 or 32? I'm looking for older 0pa and 0da files for WinKFP. Thanks!
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
Got a problem, i have communication in ISTA/D-P, INPA, NCSExpert, WinKFP, but my Progman v32 will not make contact. What can the problem be?
1. PROGMAN SSS only works with an OBD interface.
2. BMW Coding & Programming software is not retrospectively compatible, so if your car has been updated using ISTA, you will no longer be able to access modules using PROGMAN SSS (i.e. you will have to use software of the identical or later version to access a car that has previously been updated).
Havent updated any module yet. I need to reflash my DDE because of a failflash with Galletto. I just need to get the progman to start reading my modules
Hi all
pleas how can change externall interface from OPS to Icom? I can not retrofit now bmw X5 E53 year 2006 Thank you
hiya,
Can anyone help me with installation SSS program, I'm stuck at loading hive part. Regedit doesn't see my virtual hard drive so I can't browse the file. Any idea ? Thanks
You need to navigate to the virtual hard drive before you attempt REGEDIT
yes it´s a display problem
open regedit and open shell and tip "explorer.exe" into it
then do the display settings
start again and change the shell into the old path
start and it will work
good luck
Here's a VMware loader for BMW software. It allows you to keep VMware services off and automatically starts necessary programs as well as switch EDIABAS versions between 6.4.3 and 7.3.0.
https://mega.nz/file/1VhVkSRa#gsl-GG...O6Iux22gktufLM
