VMNet1 Host Only
- Connected - DHCP Enabled - Subnet Address 192.168.68.0 is correct
DHCP Settings: Start IP Address: 192.168.68.0 not correct, that is for subnet.
End IP Address: 192.168.68.254 is correct
it has to be like this:
VMNet1 Host Only
DHCP Settings: Start IP Address: 192.168.68.128 has to be this way to be correct
End IP Address: 192.168.68.254 is correct.
YAH.
I Have got everything working, was
Able to change a couple of settings but I don't have DRL option for some reaso :/ any idea why that specific option is not there, the whole reaso n
I got the cable was to turn off my DRLs.
Thanks for the amazing guide! Helped me alot.
Note:I used the pre-made windows xp that runs progman right at the start. It was supplied by the seller when I bought my cable
Hey Guys,
thats my first post here, so sorry for a short introdution...
I'm Robert and i'm from Germany, and i try to connect Progman with my E36 318i build 05/93...
Okay, situation has changed. Now Progman is running well, so far, but it's not able to read the ZCS.
Last edited by Rockiii; 05-02-2012 at 09:33 AM. Reason: BTW i'm using changesV2.iso for EDIC-Head
You probably need to use the SSS FullStart.iso.
Ok, i'll try
Still the same...
Did u turn on Ediabas ifhsvr32? That needs to be on and activated
Robert, you are using the correct changes_v2.iso file for the E36. Make sure that the "Interface = ****" line of your Ediabas.ini file is set to "Interface = STD:OBD" as PROGMAN does not recognise ADS interfaces.
The other way would be, to get an correct "Fahrzeugauftrag" and copy it on a virtual floppy...
But Where to get this? Instead of BMW i haven't an idea, and to be honest, that's a bad idea...
Or i will try it on an other E36...
Hello
I already setup Progman and connect to my 2006 E90, but after choose vehicle function., it showed a report to say my DSC and SMFA control module data are incorrect.
DSC control module data are incorrect
part number 6775387 (incorrect or insufficient)
part no, progr. ctrl mod: cannot be determined
part number 6926358 (incorrect or insufficient)
Can I continue to go start update? or something I should find out?
Thanks a lot in advance!
- In the Registry Editor, Click File > Load Hive
- Browse to the file Z:\Windows\System32\Config\Software
- Give the hive a name like BASE31
- It will show up in the registry
unable to browse , when i try to browse i can see the partition Z
or i try with ERDcommander2008 , there i am able to find it but when i give the name BASE31 and try to save it , says that its already in use and its not possible ,
some help please?
thank u
running x64 bit win7
inpa its working just fine
Nobody an idea for my problem?
Ok I'm ready all works for me. But my big problem is my cable frogman want ops or icom for my car. is it possible to patch the obi to work with my e60 fl
ok im using dracon's pre built vmachine with gerts cable, i have dis and inpa all working fine,when i try sss progman it wont connect to the car,iam i right in thinking i should change ediabas settings in the ini file to interface= obd,switch gerts cable to obd? .im trying to veiw the car/key memory in my evo,i cant read it in dis so thought id try progman.
Jamie, yes you need to switch the interface mode to OBD and change Ediabas.ini to Interface = STD:OBD. Dracon's PROGMAN vm does not make changes to your INPA/EDIABAS configuration. There are not a lot of configurable options for E36's.
thanks david,yes i fear once working im in for an anti climax! lol
I have exactly the same issue: Progman V32 Disc 1 doesn't start installation automatically (I am using VMWare 6 tho). champaign777 (or anybody else): do you remember what was the culprit?
Do you remember what was the problem with not starting installation automatically? I am having the very same problem right now....
Hi guys!thank you for this post,installation was a breeze! Much thanks to Randomy and ViperRunner using his base 31
Can u code windows up feature with sss? Would i need a charger or would it be a quick coding process? Or do i need to use ncs?
Your car has the I-level (E89X-10-12-503), that means it uses the SP daten files V2.40.2 or V2.40.3.
You are running the latest version of Progman V32. That means that Progman is too old for your car at this version. (Normally you can use Progman if your car wasn't updated higher than version V32).
Use NCS Expert with the latest Daten files V46 or use ISID/ISSS.
