I feel like a dweeb....I cant even get passed this error message when trying to install prog sss..
who can point me in the right direction??
You create the VM machine and use the base to load up in the ISO image but make sure you check off that the OS will be installed later on...Load should commence on startup. If not then the file that you downloaded is corrupt...You are in New York and so am I, I can give you a working copy of my Progman Vm Machine if you want to save you in the hassle, but you need an external drive larger than 25 gbs...I am in BKLYN
This program is no joke if you do a native install...It took me two weeks to get it working!
Oh then it cant be corrupt! lol Even though he sent you the discs, its still a bitch to get it working! Either way the offer stands, but if you want to try to get it working yourself, I am sure Randomy is the man to help...His posts have lead me to the promise land many times!
It has nothing to do with windows XP...As long as its a 32 bit OS you should be good..
XP isn't the issue. I installed it on my XP laptop inside vmware just like you. My CD/DVD Drive gave me issues installing so I used Daemon tools and created a virtual cd drive to load the base iso and then the 2 progman iso files.
Are u sure you are using the VMs virtual CD drive and NOT the FLOPPY drive?
I dont recall what I did, but it was very difficult to get it working..I had to use Erd Commander 2005 to get into the shell as Erd Commander 2008 did not allow me to get into the shell for some strange reason..I def dont want to relive that week of stress!
Randomy's DIY as for going into the shell via the Z drive also did not work for me...everytime I went into the utiltiy and mapped out the z drive, I could not get any further and not access the registry..Only way getting to modify the registry and the rest of embedded Windows OS was ERD commander 2005. I dunno why.
Once I got passed modifying the Windows registry and changing all the control panel apps then For some reason I had issues with my CD/DVD also...It kept ejecting for no reason and would not stay connecting...I didnt know what to do next so I just re-did the installation from the beginning, and one time I got lucky and the CD/DVD drive kept connection and finished the install...4 times the installation went to 97% and froze on me...that was the worst. The one time I got lucky and it finished installing, I was tripping with joy and I was in shock...
Is there a reason you're choosing Vista when the instructions say to choose XP professional? I'm not trying to be rude, just not sure what the drop down is giving you in VMWare, maybe its not there?
If its there you should definitely use it. Regardless if you are actually using Vista on your laptop.
I found that if you miss a single step in this install, you're in for a long night. Retrace your steps and do exactly as the instructions say. If that's not it, I'm not sure what else to look for.
Hi bimmer community
sorry because I disturb your thread but I need help and hope someone can help me
I have the easy dis v44 with update installed on 57 and everything works except when I go to test the plan will be controlled by the vanos or something dme it does not work
the diesel it does it I can dde and everything works not only in benziner. have the normal ads and obd2 obd interface and everything works inpa not only wants to dis the test plan. hope you can help me not to proceed any further
sorry my english is not good
After you map the drive to z: you should see that under "My Computer" inside the XP VM. Also make sure when you type regedit you do so inside the vm and not from vista.Originally Posted by Big Chaze
If you dont see z drive under my computer, repeat the drive mapping process.
?Originally Posted by Big Chaze
I'm trying to help with the progman install and help you find the z drive.
Lol I know your Vmware is working fine...I am giving you what you find in the virtual machines files for VMware....basically you just load up those files to your computer and you have a working copy of Progman SSS...NP...Hope you get it working, I told you it wasnt going to be easy especially a native install.
hi all just a quick one about instalation not starting i noticed after 4 days of trying.when u get the agp screen dont close it just work around it.and leve it on screen until finished dont press cancel,
try it and see its worked for me
Does a 2005 E46 require a D-Can cable to have pins 7 and 8 bridged? I tried to connect to the car and although I know for sure there is connection because Progman goes to the next screen of reading the FA/ZCS and just keeps reading and reading but never goes to the next menu where it gives you a warning to continue. I kept it reading for over 10 minutes and nothing changed. If I bridge 7 and 8, do you think it will work?
Ok. I modified my cable with a switch and have 7 and 8 bridged. 2005 E46 INPA and Dis 44 work perfect but I cant get Progman to work. It reads the FA/zcs and then after it says it requires an Edic/Icom cable connection. What needs to be done to make connection?? Do I need to change anything in the Ediabas configuration. I know my modified cable works because Dis 44 and INPA wasn't communicating and now it does. Thanks for the help
I used changesbyXdrivev2 if that matter...I didnt try SSSFullStart.iso. I think I read somewhere that SSS.FullStart.iso is for E46? IS this true??? So if I change this setting I should be good?
Problem solved! It indeed worked with only SSSFullStart.iso and not the other one I had loaded in ChangesbyXdrivev2.iso.
Got it working...Changed out ChangesbyXDriveV2.iso with SSSfullStart.iso and it worked like a charm...Coded my brother in laws car. Only problem was it took soooo long...NCS is so much better...
Here is a pic of my success and my cable that I had to modify to get it to work for the E46
you need this to be able to change emulation mode
