Dracon, I can't see a PM option on this forum, but I can open my FTP site for you to upload to.
ok will give that a try...so if we've downloaded your virtual disk files and installed all the progman software do we still have to use regedit to change the software file in windows32/conf/software etc or is that all done already in the files we have downloaded from you?
i tried to alter it like youve just said and got access denied,it seems iam locked out of any attempts to alter system 32,on the verge of giving up here
You don't need to mess with the registry at all. But if you are using a usb cable to access your car, you'll need to get to the desktop (use Gene's method above) and load the appropriate changes.iso file required for your particular needs.
All the registry does is help get you to the desktop, but Gene's method is alot easier so I would follow it.
If you are using a real DK or OPS head, nothing further is required except playing with the VMWare network settings to bridge your wired ethernet card to the virtual machine network card. It'll show up in the device list automagically.
This looks like a chipset error. The computer/vmware instance you are setting it up on is either setting up the drives as SCSI (which is bad), or as IDE. SCSI is a mess to deal with, but if it is IDE, just boot into XP on the original device, go into Device Manager via Control Panel > System > Hardware tab > Device Manager, and go under IDE ATA/ATAPI Controllers and find the Primary IDE channel (don't know what name it is, but it should mention primary in it), and double click it. Go under the Driver tab and click Update Driver.From there, when it asks you what the wizard should do, select "Install from a list or specific location (Advanced)" and hit next. Then click the "Don't search, I will choose a driver to install" and click next. From there, you should see a list with your current IDE controller and "Standard IDE/ESDI Disk Controller". Select the Standard one and finish the wizard. From there, shut the VMware instance/computer down, move the drive to the new location, and boot it up. It should boot and then change the controller back to the right controller. Hope this helps.
Rob - 2000 BMW Z3 M Roadster | 1986 Porsche 944 5.3L LM4
thanks mate i got over that problem by installing dracons files,dracon i cant get windows desk top or start up up on the screen,all i can do is get to the windows files using hd map untick the read and then explorer shows the files,the trouble is i cant edit any of then because it says i need to be an administrator,so ive hit a brick wall. how about if i install windows xp on its own from a cd and then install progman,would that give me full access to windows?
this is what happens when i do gene pooles method
ok out od desperation i have installed xp on a virtual machine,it appears i can now edit etc using regedit and have access to all the files etc,my question is now,what files do i use for installing sss/progman on it? sorry for all the posts,im close togetting it working i can feel it!
stiil no luck trying all the methods above,i found this though and it all works ok!
http://allautoinfo.org/diagnostic/
All i get then trying to install Progman V3.0 is a box with this message:
AM Installation
Please insert AM-DVD
Installation starts automatically
What am i doing wrong?
i have download from http://www.4shared.com/dir/LfFoCBq2/...s_Machine.html
programmv32 disc 2 parts part 24 part25 part38 part39 is dead can you pls new uplad this 4 parts say The file link that you requested is not valid. thank you
It is perfect, I really like it, it is easy to follow up and do it, thanks a lot, great job.
Just I have a problem on this point, I'm sure it is somewhere here, just can not find it:
As I don't have the "win" button (old IBM t30) I can not find the way to open the registry again.
When I'm trying to do it like mount hive - it is already mounted, but I can not unmounted.
Can you please help?
thx
- Open Regedit in the virtual machine (press Windows key+R to bring up run menu, type in regedit)
- Adjust the Shell entry to C:\WINDOWS\system32\ifs\install\instprg.exe –prg
Hallo
ich habe BMW 120 i , E87, I installed Progman V32 and everything going good until i connect it to my auto i got the following error
any idea how to solve this problem
all my problems installing this seem to point to vista,ive set it up on my laptop with xp and its all ok,i can map drive z etc.
i wonder if anyone else had this problem?
Finally got it all uploaded.
http://www.4shared.com/dir/IzzqCIkM/BMW_Tools.html
My suggestion for easy downloading, create a free account on 4shared and add the files from my share to yours and then use 4shared desktop to download them quickly from your account. You won't have the waiting restrictions or be forced to download the files one by one if you are a free user.
Thanks for this. I got the ERD Commander and Interface Config folder downloaded and unpacked
But have just downloaded the SSS VM - Base Install but when trying to open the ZIPX I get the error it's not a valid file. The first file (ZIPX) is smaller than the other files (38MB instead of 51)..... Could the first file be corrupt when uploaded?
Thanks, is working now with WinzIP 15
Dracon, downloaded everything (thanks again) but do you have an installation guide?
if using on an e36 do you still need an ads cable or does usb work?
