The one in the center of the pic and looks like sound waves.
Do you hear a chime every hour on the hour?
its a euro thing....alerts you to check news headlines on the hour
Yes...I do hear a chime occasionally. I'm not sure how this feature was turned on and if I did it it was not on purpose.
So, how do I turn it off?
Go to the main screen and then into set. In the set menu there should be an option called memo. Turn memo off. For any other tone that sounds the same it is probably because it is below 37 degrees F outside.
Current fleet:
1999 BMW e36 M3
1999 BMW e36 328is with rotary valve engine head
1999 Oldsmobile Eighty Eight
1990 Jeep Comanche Eliminator
1962 Austin Healey Sprite
Gracias...Pizzaman.
its for the memo as mentioned above
Good call Spazz...and Pizzaman09...you're on FIRE with the replies today!
BTW...there are only 3 or 4 "gong" tones...which you can hear if you've unlocked your OBC...then run TEST #13.
The HOUR MEMO is the only one with the distinctive 3 BEEPS (heard 15 seconds before the hour) when initiated.All the gong tones can be heard in the video below:
- Hour Memo (3 beeps)
- Ice Warning/Outside Temp (1 gong)
- Limit MPH/Low Fuel Warning (1 gong)
- All the Check Control System Warnings (Lights On; Keys In Ignition; Low Coolant: etc)
[ame]http://www.youtube.com/watch?v=LGiKE2pI6fI[/ame]
^^ I literally did that for the first time today. I finally figured out out to unlock the obc today and I tried out all the test.
Current fleet:
1999 BMW e36 M3
Fire is right....HOT
Good job...again.
Lol rtfm
Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
