where can i find bmw engines weights. for example m10, m20, m30, m50, m52, m54?
Check Google. There is one fairly famous webpage at a UK website under the "demon.co.uk" domain, IIRC.
James Muskopf
RRT Racing
DC Metro's premier BMW service and racing facility
engine weight...
I can't take credit for the below information, it was pulled from the Engine FAQ which somebody mailed to me a while back but I just forgot to turn into HTML (I'll covert it soon).
<hr width="50%">
Horsepower quotes may not always reflect US Rating
If there are two HP numbers, lower HP number generally denotes US rating
M10 - Straight 4 cylinder SOHC 8V. 1966-1987. 83kg 180lbs
Used in 1502, 1600-2, E21 316/318i/320-4, E30 316, 2002tii and 2002 turbo
1.5 (75bhp), 1.6 (85bhp), 1.8 (90-98bhp), 2.0 (100bhp), 2.0i (125bhp), 2.0tii (130bhp), 2.0turbo (170bhp)
M20 - Straight 6 cylinder SOHC 12V. Baby Six. 1977-1992. 117kg 258lbs
Used in E21 320, E21 320i/6, E28, E30, E34, E21/30 323i, E30 325e and E28 528e
2.0i (129bhp), 2.3i (143bhp), 2.5i (170bhp), 2.7e (125bhp)
M30 - Straight 6 cylinder SOHC 12V. Big Six. 1973-1993. 143kg 315lbs
Used in E12 525/528, E28 525i, E23 725i, 2800CS, E28 528i, E23 728i, 3.0CS/i/L, 3.0Si, E12 530i, E23 730i, 3.3Li, 633, 732i, 733i, 535i, 635i, 735i, E12 M535
2.5i (150bhp), 2.8i (184bhp), 3.0 (185-208bhp), 3.3 (200-206bhp), 3.5 (218bhp)
M102 - Straight 6 cylinder SOHC 12V Turbo. Big Six Turbo. 1984-1986. 145kg 320lbs.
Used only in the E23 745i
3.2L or 3.4L Turbo (252bhp)
M40 - Straight 4 cylinder SOHC 8V. Replaced the M10. 1987-1993. 81kg 178lbs
Used in post 87 E30 316i/318i, E34 518i, Pre 93 E36 316i
1.6 (102bhp), 1.8 (122bhp)
M42 - Straight 4 cylinder DOHC 16V. 1989-1996. 100kg 220lbs
Used in E30 and E36 318is, Z3
1.8 (138-142bhp)
M43 - Straight 4 SOHC 8V. 1993-1998. 83kg 183lbs
Used in post-93 E36 316i/318i, E34/39 518i.
1.6 (102bhp), 1.8 (115bhp)
M43TU - Straight 4 SOHC 8V. 1998 on. 83kg 183lbs
Used in E46 318i
1.9 (118bhp)
M44 - Straight 4 DOHC 16V. 1996 on. 102kg 225lbs
Used in E36 318iS, Z3
1.9 (142-150bhp)
M50/M50TU - Straight 6 DOHC 24V/Straight 6 DOHC 24V with Single VANOS. 1989-1998. 136kg 299lbs
Used in E36 320i/325i, E34/39 520i/525i, Variation of this was used in the Early US E36 M3
2.0 (150bhp), 2.5 (192bhp), 3.0 (240bhp) Sometimes referred to as S50US. Engine shares more common parts with M50 than Euro S50, but is a motorsport engine.
M52/M52TU - Straight 6 DOHC 24V with Single VANOS/Straight 6 DOHC 24V with Double VANOS. 1996-1999. Iron Block in US, Alloy Block in Europe. 118kg 260lbs (alloy) 140kg 308lbs
Used in E39 520i/523i/528i, E36 323i/328i, E38 728i, Variation of this was used in late US E36 M3.
2.0 (150bhp), 2.5 (170bhp), 2.8 (193bhp), 3.2 (240bhp) Sometimes referred to as S52US. Engine shares more common parts with M52 than Euro S52, but is a motorsport engine.
M54 - Straight 6 DOHC 24V with Dual VANOS. 2000-present. 126kg 277lbs
Used in late model Z3, all E39 and E46 six cylinder models
2.0 (150bhp), 2.2 (170bhp), 2.5 (184-192bhp), 2.8 (193bhp), 3.0 (231bhp)
M56 - Straight 6 DOHC 24V Dual VANOS with ULEV. 2002-present. 127kg 280lbs
Used in some E39 and E46 six cylinder models
2.5 (184bhp)
M60 - V8 DOHC 32V. 1992-1996. 146kg 321lbs
Engine blocks were made of Nikasil (Silicone Injected Nickel) which were prone to failure over time. Many have been replaced with the newer Alusil (Silicone injected Aluminum) engines/
Used in E34 530i, E32 730i, 740i, 840i
3.0 (218bhp), 4.0 (286bhp)
M62/M62TU - V8 DOHC 32V/V8 DOHC 32V Single VANOS. 1996-present. Alusil Engine block. Pre 98 engines were non-VANOS. 140kg 308lbs
Used in E38 730i/740i, E39 540i, X5 and 840i
3.5 (235bhp), 4.4L (286bhp), 4.6 (340bhp)
M70 - V12 SOHC 24V. 1988-1994. 155kg 341lbs
Used in E32 750il, 850i
5.0 (300bhp)
M73 - V12 SOHC 24V Single VANOS. 1995-2001. Pre 98 engines were non-VANOS. 150kg 330lbs
5.4L (326bhp)
S14 - Straight 4 DOHC 16V Solid Lifter Valvetrain and Individual Throttle Bodies. 1987-1991. 106kg 234lbs
Used in the E30 M3 and Italian only E30 320is
2.0L (195bhp) 2.3L (192-200bhp), 2.5L (215-238bhp)
Original S38 (Also known as M88 and M88/3)- Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1979-1980, 1986-1990. 146kg 321lbs
Used in M1, E28 M5, M6, SA E23 745i
3.5L (277-286bhp)
Updated S38 - Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1988-1996. 151kg 332lbs
Used in E34 M5
3.6 (315bhp), 3.8 (340bhp)
S50 - Straight 6 DOHC 24V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies. (Dual Vanos on 3.2Ls) 1992-2000. 152kg 333lbs
Used in non-US E36 M3
3.0 (286bhp), 3.2L (321bhp)
S54 - Straight 6 DOHC 24V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 2001-present. 148kg 326lbs
Used in the E46 M3 and the last of the Z3 M-Coupe and M-Roadster.
3.2 (321-343bhp)
S62 - V8 DOHC 32V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 1999-present. 158kg 348lbs
Used in E39 M5 and Z8
4.9L (400bhp)
S70 - V12 SOHC 24V. 1995-1997. 165kg 363lbs
Used in 850CSi
5.6L (380bhp)
S70/2 - V12 DOHC 48V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies
Used in McLaren F1 (Was originally developed for M8)
6.1 (627bhp)
M21 - straight 6 SOHC 12V Diesel. 1983-1991 126kg 278lbs
Used in 324td, 524d/td
2.4 (112bhp), 2.4 Turbo (115bhp)
M41 - Straight 4 SOHC 8V Diesel. 1995-on. 108kg 238lbs
Used in E36 318tdS
1.7 Turbo (90bhp)
M51 - Straight 6 SOHC 12V Diesel. 1995-on. 132kg 291lbs
Used in E36 325td/S, E34 and E39
2.5 Turbo (115bhp), 2.5 Intercooled Turbo (143bhp)
M47 - Straight 4 DOHC 16V Diesel. 1998-on. 117kg 258lbs
Used in E46 320d
2.0 Turbo (136bhp)
M55 - Straight 6 DOHC 24V Diesel. 2000-on. 132kg 291lbs
Used in E46 and E39s.
2.5 Turbo (170bhp), 3.0 Turbo (183bhp)
M67 - V8 DOHC 32V Diesel. 1999-on. 192kg 423lbs
Used in E38 740d
4.0 Turbo (245bhp)
N44TU - Straight 4 DOHC 16V Dual VANOS with Valvetronic
Used in E46 318i
1.6 (115bhp), 1.8 (143bhp)
N62 - V8 DOHC 32V Dual VANOS with Valvetronic
Used in E65 745i
4.4 (325bhp)
N73 - V12 DOHC 48V Dual VANOS with Valvetronic
Used in E65 760i
6.0 (438bhp)
W10 - Straight 4 SOHC 16V
Used in Mini One, Mini Cooper
1.6 (90-115bhp)
W11 - Straight 4 SOHC 16V with Eaton Supercharger
Used in Mini Cooper S
1.6 Supercharged (163bhp)
<hr width="50%">
Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
Greetings; 1st post and I have a request (of course)...
I realize this is a 20 year old thread, but if anyone's still paying attention, I'd like a bit more info on engine weights. In the post above by @Kevlar, does anyone know what's included in the weights? It seems very unlikely that exhaust manifolds would be included, but what about intake systems and/or accessories (starter, alternator, etc)? In other words, are these weights for bare longblocks, or complete, running engines, plus ?? accessories?
Thanks for any assistance. I tried to PM Kevlar, but haven't discovered how on this forum.
