You would be surprised how many people have this and don't know it... It's like HIV
Any way, A tear in your intake boot usually throws off codes, but not always.... In my case it did, untill i taped it up nicely and cleared the codes.... In most cases a tear or crack in your intake boot DRASTICALLY reduces torque in your car as well as overall performance, distribution of power, low end torque, etc....
In this case, i had a crack and a gigantic tear in my lower intake boot, i temporarily duct taped it until i got a new boot to replace my old one....
Many E46 guys get hyped up about VANOS and the seals replacement, believe me, if you have a crack in your intake boot, VANOS is the least of your problems, you won't even feel the VANOS job until your intake boot is replaced.....
In addition to replacing this boot, I replaced a couple of key vacuum hoses (sorry for no pictures) which tend to get soft, brittle, and over all just don't work as well...
I also cleaned, lubed, and put sealant on the internal parts of the adjuster unit as seen in the below diagram. The seals on this unit are not replaceable as they are built in the unit, they didn't seem in perfect working condition so i just put some sealant on them before i put it back into the intake manifold.
It is Number 7 in this diagram...
I also replaced a pulley which is infamous for making noise on our cars, the old pulley was loose and spun easily, the new pulley was tight and stiff, the new pully doesn't make any noise.....
These are pictures of the torn intake boot.
I rebuilt the Vanos just before this and noticed a slight difference. After replacing the boot and the vacuum hoses however, my car drives completely different. Low end torque has increased drastically, i notice this especially on the freeway. The VANOS works better also, i was driving it pretty rough and had a nice wide smile on my face after i shifted into second and the car jerked like a SOB
Moral of the story: check your intake booted gentlemen, get a flashligh and reach deep in there.
Signs of this that i was having before hand:
1. Obviously a service engine light
2. fluctuating cold idle (up and down up and down)
3. power surges after 3K RPM's (similar to VANOS issue)
4. Dampened torque especially on low end
5. Uneven and sometimes random distribution of power
6. A loud suction sound after shutting car off
If you have similar issues, definitely have this checked out, its murderous to the performance and overall well-being of your car...
Very Respectfully,
David Abdi
