rare modern (i.e. this decade, not e28 or early e34 535i manual) 3.46 ring and pinion set for any 188mm case/diff from 2001 Z3 in great order.
this ring and pinion set would plug and play into any e36 case as well; remove your lsd and extract the pinion from case, re-fit the 3.46 pinion and bolt on the 3.46 ring gear to the differential unit.
I can include the pictured 2001 Z3 case with nice pinion bearings and 4 bolt flange as well for free if you would like to pay for shipping- (ideally you'd pick it up local in san francisco)
pinon bearings are still installed- very nice shape. This case is plug and play into e30's with 6 cylinder engines and z3/mz3's with 6 cylinder engines.
R&p have been sold
output stubs from diff to axels avail seperate: $50 shipped for pair (z3 6 bolt paired style)
Z3 rear cover: $35 shipped
z3 rear speed sensor: $25 shipped
z3 speed ring $15 shipped
Wanganstyle Powertrain
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
Still avail
bump!
bump to the top
Will this 3.46 ring and pinion fit directly to the oem torsen lsd(z3 3.0 3.07)???
