car is shaking violently now and pulling hard to right...bent rim,suspension,alignment?its got 17x8 alutec rims..these easy to bend?thanks scott
Start with the rim, most likely bent.....if that fixes it you're on your way. If not control arms, etc......
http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
"The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
ok..if its the rim i found some from a 06 750li locally for 495.00,they just dont have the tires...
it does have a visible curled out place on the outside..im assuming a tire dealership can confirm its the rim...
by the way,my names scott..i work for the bmw manufacturing plant in greer sc...
Welcome here Scott.
Your wheel can probably be fixed. Look up wheel repair in your area.
Been there..done that....
They can fix almost anything.
Also check the tire, if you hit it hard enough could cause a bubble.
Welcome Scott.
My Car Build – The BimmerWorld E36 Office Project
Lynn Campbell
Race Proven Performance
www.bimmerworld.com
www.bimmerworldracing.com
Shaking and pulling does not sound like a rim, or tire.
An egg shaped wheel you dont think would cause some shaking? lol
It Im sure is also knocked out of alignment...
But he knows the wheel is damaged...so start there...
Well once the wheel is fixed, then you can check the driveability and further suspension/alignment problems.
Unless you can like see a broken suspension piece.
How big of a pothole did you hit? It must of been massive if you bent a rim. We once hit a hole, which was actually where the road washed out that was about 10" deep, not sure how wide ( probably less than 2ft ) with the 740 doing about 40-50 mph (must of jumped the gap). The impact was extremely violent but there was no damage. Considering my experience, I am surprised you are ok. I am sure your lower profile tires didn't help either.Hit a pothole last night..help
car is shaking violently now and pulling hard to right...bent rim, suspension,alignment?its got 17x8 alutec rims..these easy to bend?thanks scott
Current fleet:
1999 BMW e36 M3
1999 BMW e36 328is with rotary valve engine head
1999 Oldsmobile Eighty Eight
1990 Jeep Comanche Eliminator
1962 Austin Healey Sprite
could i switch the front and back wheels on that side and tell if thats whats causing it?
You absolutely can bend a wheel bad enough to violently shake and not loose air.
I know.
And if the rim is egg shaped....teh tired will conform to the egg. It may or may not lose air.
OP..You can try swapping them...only if you dont have a staggered set.
If you were going to swap...swap sides....in front and see if it pulls that way then.
But seriously...fix the wheel first. You know its bad.
Or....Idea Put the spare on.
Take the wheel off, roll it & see if it's bent and visually check your suspension components while you're at it.
Replace that wheel with your spare, or switch it to the left side to see if the problem moves with it.
Contact the city also! Where I live if a pothole is reported by multiple people, any damage to car is paid for by the city. You might be able to get them to pay for the damage.
