Originally Posted by
David Mc
Streets, have you followed this:-
Push the Administration button in DIS and from the DIS menu choose The Calibrating touch screen button (second from the bottom). Enter the 5 digit dealer number password you chose during installation (the recommended password was 12345) and wait for the utilities menu to pop up. When it does, choose Option 7 (SCOADMIN NETWORK).
A window will pop up showing 2 green driver icons – at the top of the screen will be the SCO TCP/IP Loopback driver – DO NOT TOUCH THIS DRIVER.
Below this you will see a second driver – AMD PCNet-PC1 Adapter Compatible –PC1 Bus#0, Device #17, Function #0. The configuration settings assigned to this device may not work with your particular machine so left click on the AMD PCNET – PC1 Adapter Compatible line to highlight it, then from the Hardware Menu at the top of the screen, choose “Remove network device”.
The next step is to re-add an AMD PCNet-PC1 Adapter Compatible that your machine will recognise by again going to the Hardware menu and choosing Add new LAN adapter. A window will pop up showing AMD PCNet-PC1 Adapter Compatible devices found on your computer – this is an important step as in my case, the original adapter was set to work off Bus #0, Device #17, Function #0 whereas my computer requires the adapter to work off Bus #2. Choose the first AMD PCNet-PC1 Adapter Compatible on the list then yes to add the new adapter and a pop up will ask what protocol you want to add to the adapter – choose SCO TCP/IP from the options displayed and a settings panel will pop up. The first line “Local Host Name” should already be populated with gt1ap. The next line is where we need to enter the IP Address, which is 192.168.68.30 . When you tab to the next line, the Netmask address (255.255.255.0) should back populate, as should the Broadcast Address 192.168.68.255, TCP connections and Pseudo ttys lines. Hit OK to accept these adapter settings and return to the SCOADMIN NETWORK page where you will see your newly created adapter listed in place of the one you deleted.
Before going further, hold down CTRL + ALT and hit ENTER to pop up the toolbar of your Virtual Machine and press the CTRL + ALT keys together to pop up the Windows mouse pointer.
From the Virtual Machine Edit menu, choose Virtual Network Settings, then on the Next Screen, Select the Host Virtual Network Mapping Tab. Now Click on the > symbol located on the Right hand side of the VMware Network Adapter VMnet1 line and choose Subnet... to view its IP Address and Subnet Mask. Ensure that the IP Address is listed as 192.168.68.0 by altering it if necessary and that the Subnet Mask is 255.255.255.0. When this has been completed, click OK and then click the Apply button at the bottom of the screen before choosing OK to exit the editor and save your settings.
