Results 1 to 22 of 22
Thread: Taping the oil filter housing for three ports.
    Aug 2009
    Stamford, CT
    3.2l Turbo
    I just read a whole bunch of threads regarding this. The TRM dist block provide only one port. I need ports for oil supply, oil temp, oil pressure. So I think the best solution here is to tap the oil filter housing and make three ports and then run an inline filter for the turbo.
    What do you guys think. Any specific location? Or should I just tap where it will look good?
    Jul 2004
    Pluto
    93 325iS
    Tap wherever. I have found no issues.
    Phoenix, AZ
    E30 S50 Turbo
    Would tapping just the oil filter cover work?
    Jul 2004
    Pluto
    93 325iS
    Perhaps but it'd look ugly. Its maybe 1-1.5hr to R&R the housing off and tap it..
    Aug 2009
    Stamford, CT
    3.2l Turbo
    Anyone else have experiance doing this. I know I have an option of going to oil presure sending switch behind the filter housing but I would rather do the oil filter housing as long as there is nothing wrong with that.
    Is the oil filter housing always full of presurized oil when the car is on?
    Apr 2006
    Minnesota eh?
    86 325es
    Outer Heaven
    '92 TRM E36 / '05 325ci
    Re: Taping the oil filter housing for three ports.
    See post 16.
    Aug 2009
    Stamford, CT
    3.2l Turbo
    You are right about the junk in there, I was going to use a small inline filter right before the turbo. Also I didn't know that the housing is plastic. Isn't it aluminium?
    Apr 2008
    Orlando, FL
    02 330ci, 95 ///M3
    just get the uuc oil center lid. thats what ill be using.
    Aug 2009
    Stamford, CT
    3.2l Turbo
    those are on back order for another 3 months I was told by UUC.
    Outer Heaven
    Even with an inline filter, that oil is going cycle through all the crap in the old filter first and take some with it. I dont like the idea of having the filter that close in the oil circulation system to the turbo.
    Edit: Sorry was picturing wrong engine configs, limited page info, responding from phone.
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by sjpgoalie View Post
    So then you'll have a lid that can take gobs of pressure, and a housing that can't. I'm just saying that its probably the weakest, dirtiest part of the system. So why dick with it's integrity when there are much safer and reliable things to tap into.
    Dude wut? An OBD1 oil system has no plastic lids... and the housing is never plastic...
    Outer Heaven
    Damn my bad guys, the app I use on my phone for vBulletin doesn't show users vehicles. I'll have to keep that in mind. Your sure the housings weren't changed over to plastic too? I could swear BMW started implementing plastic housing into the OBD2s on the inline sixes at least. I've definetely squeazed a couple...they flexed.
    Sep 2002
    USA
    BMWs
    Damn my bad guys, the app I use on my phone for vBulletin doesn't show users vehicles. I'll have to keep that in mind. And I'm pretty sure BMW started implementing plastic housing into the OBD2s on the inline sixes at least. I've definetely squeazed a couple...they flexed.
    What app?
    No plastic on any of the cars we turbocharge!
    Jul 2004
    Pluto
    93 325iS
    Tapatalk doesn't show cars/locations/etc.
    No, the OBD2 housings are aluminum too. They simply have a plastic cap/lid. Not even the current cars have plastic housings
    OP, pull housing, tap, clean, install fittings w/ sealant, reinstall housing, install inline filter. 2hr later, done!
    Outer Heaven
    Tapatalk. It's awesome, waiting for some other forums to catch on to it. Only issues I have with it is that it I can't see join date, post count, location, etc. And it doesn't show which forum you are in once you select a thread out of it.
    And I stand corrected sir, all of the housings so far from BMW have been metal. What a brain fart, shit. My bad sigma take it easy, I realize this after looking at double checking my e36, e46, and e90. I don't like posting misinformation. We are in this forum to learn, correct?
    Jul 2004
    Pluto
    93 325iS
    Yes I was just trying to help, sorry, I come off condescending often.
    I wish BFC was just using the Mobile profile these days, I have Tapatalk but I don't like it near as much as the Mobile VB profile... Oh well.
    Outer Heaven
    It's cool man. The only reason I don't mind tapatalk is due to how condensed it is. Pages load fast, no banners, text boxes fit the screen so I dont have to scroll around, zoom-in/out and navigating (both of which piss me off when viewing any site I frequent), etc. But it clearly has a couple minor issues that need to be resolved.
    But vBulletin does have a great mobile profile compared to most others.
    Jul 2004
    Pluto
    93 325iS
    Yeah, if you had used the vB Mobile theme, you'd like it better. Tapatalk on my iPhone 3G is slower than the Mobile theme was on my 2G. Go figure. I wish Kevlar would get on the ball and set up the Mobile theme again...
    Atlanta,GA,USA
    93 325IS/89 325is/E46 M3
    uuc oil center
    Quote Originally Posted by wojtek86 View Post
    We have a few in stock. unitedbmwonline.com
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Bam!!@
    Aug 2009
    Stamford, CT
    3.2l Turbo
    Ordered one, thanks.
    Quote Originally Posted by jskicet View Post
