I have a 2002 330Ci and my factory Bi-Xenon lights are flickering and the left xenon wont start.
I went ahead and ordered new Depo Xenon (low beam) + halogen (high beam) w/LED Angel Eyes. (did this to save money instead of ordering OEM replacement parts_
I am having a problem trying to re-wire and install.
THE Factory Bi-Xenon has 2 seperate plugs going into the factory ballast.
Wire Plug #1 has 3 smaller wires going to the factory ballast in plug #1 are colored (brown/yellow, green/blue, purple/white).
Wire Plug #2 going to the ballast has 2 larger wires are colored (green/yellow & solid brown)
Can you please explain how to re-wire this. I'm pretty good at wiring stuff I'm not sure which wires go to the positive (red) and negative (black) on the aftermarket xenon Ballast [there are only 2 wires red & black] and which wires go to the positive & negative on the halogen high beam.
I got the angel eyes figured-out. My challenge is putting the factory bi-xenon wiring to hook up to the new single xenon (low beam) Depot Auto Lamp headlight assembly with (halogen) high-beams.
THANK YOU - Ps the model of the Depo Lamp assembly is 444-1137PXNDAM2
