The M3 had been sitting for over a week (it sits a lot). I pulled it out this morning because I need to put a new diff seal in it because it has a slow leak. Well I pull out and can't help but notice a puddle that was at least six inches wide but not very deep. I put my finger in it and it smelled like gas. From my guess it's coming from the driver side right around the front wheel, maybe a little behind it but definetly on the driver side half way from the wheel to the center of the car. Anyone have any ideas on what it is? I wonder if the race gas I had put in it a few weeks ago had anything to do with this. Help me figure out what this is before I take it to my mechanic later this morning. I want to at least give him some ideas if I can. Tia.
Btw.. where is the left side fuel sending unit located? Could this be my culprit?
He who hesitates is not only lost, but miles from the next exit.
Look at the fuel filter lines/hose clamps right under the driver seat/footwell
#54 GTS-3/CM E30 Race car
90 Porsche 964 C2 Daily driver
05 BMW 325XiT Kid hauler
04 Chevy 2500HD Duramax
Perpetual hopeless, unfinished projects
Thanks! I'll have my mechanic check it out. What you described could very well be the culprit because that is exactly where the drip appears to have come from. Any idea how major this is? And what replacement parts I may need?
It's common for power-steering fluid to leak there as well.
Keith
1998 Hellrot ///M3 Coupe
ECIS Intake,Dinan software,Rogue SSK,UUC Tranny Mounts
X-brace,GroundControl coilovers,ZKW w/DDE Lightning Enhanced
Clear Corners,Kumho MX,UUC Pulleys,UUC Sway Barbarians,UUC/Wilwood BBK
What color is the fluid that was leaked?
Can this be multiple choice? What do I have to choose from? I didn't really pay tooo close attention to the color but it did smell like gas.
If it's right under the driver's seat, check the rubber hoses going in and out of the fuel filter.
Here's my thought. If it was really gasoline that was leaking from your fuel filter, it would not have made and stayed a puddle for days. Unless the leak is still occuring and you would see it. The longest that a small puddle of gasoline would last at temperatures above 50 degrees is about 2-3 hours and it would all evaporate away. It would also stink like gas and you will know it because you think you were choking. A large puddle emits a LOT of vapors.
If it is still there and there is no leak, I'm thinking it is another fluid. The only other common leak on E36 cars is the power steering fluid. This can be clear or red (clear if power steering fluid was used, red if ATF is used). This will stink like machine oil. If your power steering components are stock, my bet is that you have a power steering hose leak (even if this puddle is not from your power steering).
Check those first. Let us know.
PM is full. Do not PM me. EMAIL me to communicate!!
*** SF Bay Area ***
SRS Light Reset $15 (first 10 ppl, then free after that for everyone)
The only replacement for displacement is technology.
E46 03 325i
E36 98 M3 Vert
E36 95 M3
E36 93 318IS
E30 89 M3
When it rains, it pours! Maybe you damaged something during the last fender bender?
"The older the boy, the bigger the toy!"
<img src=http://pages.sbcglobal.net/dinan3/ar15firing.gif><img src=http://pages.sbcglobal.net/dinan3/offwall.gif><img src=http://pages.sbcglobal.net/dinan3/rocketwhore.gif>
Modifications
if it was gas ur garage would smell of it like GQ said... the fuel filter is under a plate right under the drivers seat.... u can jack up ur car or soemthing and take off the plate ad inspect the fuel filter, hoses and clamps.... it might be teh power steering as someone else mentioned... but i dunno anything about that...
The liquid that was on the ground has evaporated and is almost completely gone. So that points to gas and not oil.. right? My mechanic said the fuel filter hoses looked pretty brittle and needed to be replaced and he suggested I swap out the fuel filter as well. How often should you switch out the fuel filter?
Is this pretty common? Is there anything else I should replace while I'm down there?
I like to change mines every 30K. That's about all you can do while you're in there...
Modifications
Yes, the lines dry-rot and crack. Replace them ASAP. You can buy BMW high-pressure fuel hose by the meter at most dealers, or you can get it in 18" sections at the local AutoZone or Advance Auto. Other small-chain auto parts stores usually have 5/16" (8mm) Gates fuel injection hose by the foot.
James Muskopf
RRT Racing
DC Metro's premier BMW service and racing facility
Replace the hoses and the filter. Sounds like your mechanic is on the right track...
- John
Thanks guys the parts are already in. Can anyone explain why I haven't seen it leak since that day?
