if any of you guys that have S54's ever need to adjust your valves, I have the shim kit. I found it this weekend while I was out in the garage. i forgot I had it......
I can rent it out to you along with the feeler guages and the micrometer, or i can do the job for you if you need it done. I also have a spare S54 valve cover gasket left over from a spare parts order.
coming soon, S54's for everything....
Whats the service interval on the S54 valve adjustments? 15k miles like an S14?
my 02 had them done at 60k miles, and when i checked them at 100k only 2 were out of spec, and they were only .02mm out I swapped almost all of them out to take them all down to the lowest end of the spec for the intake and exhaust. just for the additional lift.
Its pretty easy, just need the tools and shims.
http://m3forum.net/m3forum/showthread.php?t=113415
Sean
yep, it's easy, just time consuming.
if you rush, you will drop a shim in the pan.
