Results 1 to 20 of 20
Thread: interior light dimmer E32 E34 - special production
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Guys and Gals,
    my bestseller for E34 and E32 is still the interior light dimmer module. So far it is installed in E32, E34 and Ferrari F430. installation instructions from the German 7-forum with pics http://www.7-forum.com/forum/24/dimm...ung-82846.html
    One unit installed behind the front interior light works on all interior lights, on normal lights and also LEDs. There is a switch inside the module where you can select your preferences:
    AUS/OFF = LED
    EIN/ON = Glühlampen (Serienlampen) serial bulbs
    Schalter/switch 2: Einschaltverzögerung/ switch on delay dimmer
    AUS/OFF = 0,5 sec.
    EIN / ON = 2,0 sec.
    Schalter/switch 3 Schalter/switch 4 Ausschaltverzögerung/switch off delay time
    AUS/OFF AUS/OFF 2 sec.
    AUS/OFF EIN/ON 4 sec.
    EIN/ON AUS/ON 6 sec.
    EIN/ON EIN/ON 8 sec.
    All controlled by a program.
    some pics of the units ready for shipment http://infinitier.ddo.jp/e32/images/etc/room7.jpg
    single parts under assembly http://infinitier.ddo.jp/e32/images/etc/room6.jpg
    attached/connected to the interior light http://infinitier.ddo.jp/e32/images/etc/room1.jpg http://infinitier.ddo.jp/e32/images/etc/room2.jpg
    stick behind the cover of sunroof motor http://infinitier.ddo.jp/e32/images/etc/room3.jpg http://infinitier.ddo.jp/e32/images/etc/room4.jpg http://infinitier.ddo.jp/e32/images/etc/room5.jpg
    The secret of the complete module is a programmed chip, especially made.
    Installation instructions from the E34 forum http://forums.bimmerforums.com/forum....php?t=1515137
    Here the detailed installation instructions and youtube by IT Jedi http://forums.bimmerforums.com/forum....php?t=1515137
    10 units available now. EURO 85.00 incl. shipping by non registered airmail, in case you want to have it shipped by registered airmail, add EURO 10.00
    Nov 2007
    Montreal, Quebec, Canada
    Coming soon? 2001 e46
    Hi Shogun,
    I'm thinking of adding LEDs around the car (inside), like at the door panels and footwells. I think I might feed the LEDs off of this apparatus. What do you think, and what kind of LEDs should I go for ? (amps, etc.) I'd be more than happy to modify the shipped circuit as required since I'm pretty handy with an iron. Plus it's a lot of fun!
    Jan 2005
    Japan
    our unit has in sleeping mode a consumption of only 1 mA (0,001 A)!
    But calculate all the consumers connected to the unit, the interior light with (maybe) reading lights in rear, door lights for example like in E32 etc. consume quite a bit. Plus the stuff you want to add, and that is up to you to the max A as shown below.
    We have layed out the unit quite generous, and that is the difference to what one might be able to buy from other sources, but there is of course a limit.
    this unit can control in total up to 200W lamps, because we made digital software for this special IC.
    they are including
    1) complete unit(ready made)
    2) connector for interior lamp cable set
    3) cable color information and setting infomation are linked online above.
    Nov 2009
    Hudson Valley NY
    90535ia 09MuranoSL
    Thumbs up
    That installed with NO PROBLEMS
    I have installed LED's for all my interior lights (Blueish-White for entry/exit and slightly warmer yellowish-white for map). They are bright. Really bright. So instant on and off was overly harsh.
    Shogun's dimmer kit was easy to setup and took about 15 minutes to install. Most of that time was using Google Translate on the install page and re-re-reading the result. I'll write up the same instructions in English. Sadly it was all so fast that I only snapped two pics.
    All the install bits come in the kit. Pliers, wire tool and a pry tool (I prefer the plastic kind vs a screw driver) are all that's needed. Soldering is optional but not needed. The kit is complete.
    Top notch. And the results are outstanding. My fiancee described the improvement as more elegant and graceful.
    This may not top many lists of import "fixes" but its a tremendous aesthetic upgrade.
    BMW CCA #434501
    [ 127k Miles | Dinan Engine & Trans chips | LSD | AFE Pro 5 R Air Filter | ANSA Exhaust | BavAuto Springs | Bilstein Sport shocks | | Racing Dynamics front strut brace | BavAuto DTM Lip | Driver-side wiper arm upgrade | Euro LKM ECE-B | French Market E1 Spec Hella Lows (HID 4500K 55w DDM Raptor v2) and Highs (Osram Nightbreaker +90)
    | HID Projector Fogs - 3000K 35w DDM Raptor v2 | LED Interior lights with Shogun's Dimmer kit | 7 Series Rear Map lights | Euro clear parking, tail and signal lamps]
    Jul 2010
    Boston, MA
    1994 BMW 525i
    The dimming happens in my moms X3. Always wanted it for my car. I might have to bite once I get some more money for parts.
    the batcave
    batmobile
    wow ...great little product
    West Coast
    two 3's one 5 three 7's
    Quote Originally Posted by DrPatTCakes View Post
    From a great guy, what else would one expect?!
    Nov 2007
    Fantastic! I'm really looking forward to it!
    Nov 2007
    I am flabergasted at how fast this has been delivered. Thank you!
    Na
    Na
    So by connecting this into the front dome light, this will control dimming with all lights in the interior? rear map lights included?
    "...there’s nothing like the scream of an old straight six, a sound only comparable to a monster that eats children and rocks for breakfast and howls like a banshee when the loud-pedal is mashed." - Mike Burroughs
    Na
    Na
    Pm'd!
    Nov 2007
    I've attached a pdf file with a diagram with instructions I made from IT Jedi's translation for installation. It was a fun project and easy to install.
    Can also be downloaded from :
    Google Drive - InteriorDimmerModule.pdf
    Enjoy !
    Attached Files Attached Files
    Jan 2005
    Japan
    thanks a lot for this very nice installation instruction.
    and here copied from Ferrari Chat forum, as they also now use my dimmer in their Ferrari F430:
    I tested many dimmers and studied several electronic schematics. None of them where satisfying enough to be implemented in a Ferrari and especially behind the M032 ECU. Dirtly electronic modules would seriously mess up this ECU! My specs were quite severe: I wanted it programmable and configurable, ground based control (I initialy thought that we would need a +12V based control), almost no power consumption in standby mode, limited heat at the heat sink and a PWM based control (Pulse Width Modulation).
    On a good day, I discovered on a BMW forum a guy from Japan who is making what seemed to be the perfect dimmer.
    I got in contact with him and after many email exchanges and studying his schematics, I got convinced that we have here the right product. His module is entirely programmed using a PIC12F629, just perfect! The MOS FET used is a 2SK3140 using a 4V gate and is attached to a small heat sink.
    Here a the characteristics of this dimmer module :
    - Support of normal bulbs or additional LED’s
    - Maximum control of 200W (15A)
    - Standby current drain of 1mA
    - A noise signal is applied to prevent line noise from generating false-starts or miss-functioning
    - Uses a digital IC (PIC12F629) to realize control by PWM adjustment
    The dimmer module has 4 wires
    - white : OUT ground to the dome light and LEDs
    - yellow : IN delayed ground from the M032 ECU
    - red : +12V HOT (module power)
    - black : ground (module power)
    The dimmer module can be configured using DIL switches :
    - SW1 OFF : LED + normal bulbs
    - SW1 ON : normal bulbs
    - SW2 OFF : Fade In time of 0.5 secs
    - SW2 ON : Fade In time of 2 secs
    - SW3 OFF – SW4 OFF : Fade out time of 2 secs
    - SW3 ON – SW4 OFF : Fade out time of 4 secs
    - SW3 OFF – SW4 ON : Fade out time of 6 secs
    - SW3 ON – SW4 ON : Fade out time of 8 secs
    Justin, Tx.
    1993 740I
    Howdy Shogun,
    Have any of those dimmers for a E32 740i just laying around?,
    if so, box one of those critters up & send it to the Republic of Texas.
    PM me with any details. arigatou gozaimasu
    Justin, Tx.
    1993 740I
    Quote Originally Posted by shogun View Post
    Have some on stock. I just sent you a PM so that I get the address to send it to Texas.
    Sorry it took me so long to respond, I travel a lot.
    I can't access my PM's for some reason, want to e-mail me?
    Dec 2011
    Carmicael, CA, USA
    2007 328i
    Dear Shogun,
    I would very much like to have one of your dimmer modules. Please pmail me tell how to complete the transaction.
    Thank you,
    Justin, Tx.
    1993 740I
    Just got around to installing Shogun's mod in my E32, in two words..........
    Thanks Shogun.
    Mar 2011
    Vancouver, BC
    too many, see sig
    Got my kit today; thanks again Erich!
    My Current Cars:
    E70
    2010 X5 4.8i Xdrive Spacegrau
    E90
    2008 M3 6MT Silverstone II
    E34 1992 M5 3.6 J-spec Calypso
    E34 1990 535/5 turbo Bronzit
    E32 1990 750iL Highline Delphin
    E30 1988 325i M54 swapped Schwartz Convertible
    No longer with me:
    E46 2001 330Ci Titanium Silver
    E32 1993 740iL Lazurblau
    E34 1992 525iT Kashmirbeige
    E34 1990 535/5 Cirrusblau - Former Miller Performance Stage 2 Test Mule Car
    E34 1989 525i Cirrusblau - the Slug
    E21 1981 320i w/ M20 swap Arktisblau
    E21 1979 320i Turmalingrun
    Jan 2005
    Japan
    10 units available again, subject to prior sale
    Jan 2005
    Japan
    only a few modules left on stock
  1. E34 F/S Shogun's Interior Light Dimmer Kit
    By shogun in forum E34 Classifieds (closing soon)
    Last Post: 06-15-2019, 02:29 AM
  2. Interior light dimmer - new production
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 02-03-2015, 06:16 AM
  3. interior light dimmer for E34 special
    By shogun in forum 1988 - 1996 (E34)
    Last Post: 08-21-2010, 09:26 PM
  4. E32 Owners -- Anyone replaced an interior light dimmer switch?
    By Ben Carufel in forum 1988 - 1994 (E32)
    Last Post: 03-19-2005, 02:28 AM
  5. interior light dimmer switch problem
    By DoubleShot in forum 1991 - 1999 (E36)
    Last Post: 12-27-2003, 02:30 PM
