Um, connect the wire for the BMW alternator light (X-20 pin 25 is as good a place as any) to any switched 12 volt source...
Rob
Prior projects:
1998 540i with 6.6 LS2/T56 Chevy Power
- pictures and details
1992 325i with 6.6 LS2/T56 Chevy power - pictures and details
1995 M3 with 6.6 LS2/T56 Chevy power - pictures and details
Ok, yea but I'd light for the alt. light to come on when the alternator is crapping out or not putting out 12+ volts.
The 1999' F-body GM PCM red conn. pin 15 (wire color red) is labeled "Generator Turn On Signal". Of course I only have schematics for the 98' F-body but it appears this wire is for the dash lamp signal. I was thinking it's not as simple as connecting this wire the BMW alternator light dash wire?
What I said will do that.
What you are taking about is an entirely differnt thing - it is a unique 98 LS1 item that turns on the alternator.
Rob
Prior projects:
Do you know how the dash light is set up to illuminate whenever the voltage drops below a predetermined range?
Essentially connecting it to any switched 12v source won't immediately let you now when the alt. has stopped charging. It will let you know once your battery has been pulled down below 12volts due to a dead alternator.
Just want to understand exactly how this works and not blindly follow what someone else has done even though I'm sure you set up works fine.
No problem - ignore my posts
Good luck.
Rob
Prior projects:
Connecting the bulb to just any switched 12V source defeats the purpose of the charge light and is not the correct way to do it. One end of the charge light is connected to 12V and the other end should be connected to the alternator "turn on terminal" (Terminal L)
When you turn your key to the on position without running the engine, the current flows from the 12V source through the bulb and grounded at the alt. This illuninates the charge light.
Once you start the engine, the alt is turned on and it sends 12V to the bulb. Since there is 12V on both terminals of the bulb, the charge light will no illuminate.
In the event the alt fails, it will not send 12V but rather will ground the circuit and hence the charge light will come on.
the 1998 F bodies are wired differently than the 99+ cars. In the 99+ cars, the PCM turn on the alt and when the alt fails, the PCM send a signal to the F-body cluster
here is a very useful thread on the tech
http://www.ls1tech.com/forums/conver...aq-thread.html
2003 M5 LSx l 6 Spd Manual l 4.10 LSD
Build Thread
The chassis must always be regarded as a means to an end and never as an end itself
Great info.
Now which wire from the 99' GM PCM should connect to the BMW alt. light?
I don't see anything called out on the PCM pin out sheet that gives any indication. Maybe I missed it?
The alternator has a red wire on the L terminal that runs back to pin 15 (red conn) on the PCM and that's the only place it goes.
did you think of just getting a battery gauge?
2010 - BMW 335i M-Sport - Lemans Blue Metallic
BMW PPK2, JB4 with NLS, Backend Flash, BMW PP Exhaust, Misc Appearance Mods, Boost Addictions Diff Brace, BMS DCIs, BMS Clutch Stop, VRSF Catless DPs
Previous:
1995 M3
1998 323is
Build Thread
Would it be fine to just splice into the red wire connecting it to the charge bulb and leaving it connected to the PCM too?
If I cut the wire away from the PCM then will it no longer activate the alternator? I'm not familiar with how the PCM activating the alternator works.
I already have aftermarket oil temp and pressure gauges. I'd be happy if the Alt. light would just work. No need for additional gauges.
When the car cranks, the alternator needs power to "excite" it. The red wire from the PCM supplies this power in a GM car. Once the car starts and the alternator spins up and produces power, the voltage from the PCM is cut off.
If you want the alternator light on the dash to work, abandon the PCM red wire, and route power to the alternator using the BMW circuit that is already in the car. Look at the ETM (BMW Electrical Troubleshooting Manual) page covering the Charge Circuit to figure it out. You will run a new wire from the plug that used to connect to the BMW alternator, and connect it to the terminal that the GM alternator uses.
E30-LS1 Swap Guide and Kits, email us at e30ls1@gmail.com !!! or check our website e30ls1.wordpress.com
As luck would have it the exciter wire to my alternator snapped today
My battery light came on immediately (I also have a volt meter so I knew the alternator was not working). I will have to check my notes and see just how I wired the light - at least I now know that it works
Rob
Prior projects:
Following the description that Schitzo gave in post #8, if the alternator goes out while connecting the light as per Rao's (any switched 12+ volts) Shouldn't the light come one within a minute (as it did for Rao)?
There is only one source of charge within car's circuit. As soon as you take away the charge the voltage drops right away as battery cannot sustain running car for more than few minutes.
I think you can do it both ways, the only difference would be is your light comes on right away when Alt. fails or within a minute or so, which I don't thing makes a lot of difference at this point. Of course if you can connect it the proper way it would be better option.
Not entirely true. A good battery will keep a car running for a quite a while with a dead or non charging alternator. I did it each time mine died.
The second time I had a new Optima battery and drove around for a whole day (a few hours) with a bad alternator.
Hence my reasoning for wanting to connect the charge lamp the correct way, which should indicate when alternator is not charging not when the battery is below 12 volts.
Conventional alt light works like this:
12v direct from battery to ignition switch to charge light on dash
Current from light to wire on alternator
Alternator provides ground for light circuit when not turning (engine not running)
Alternator spins up, 12v from light excites it; it starts to charge
Ground for light no longer effective when alternator spinning and producing "enough" voltage: 12v is being fed back to the light -- the light now goes out since it has 12v on both of its wires.
See:
http://www.familycar.com/Classroom/charging.htm
While finishing up the LSx M3 wiring, got to the charge light and being gun shy from horror stories in the past of short lived late model GM alternators due to improper wiring, did a bit of searching and found many sources confirming garretvs advice.
For the E36, the charge light is powered +12v from the key in run and start position, so just take pin 25 from the X20 connector, (BLUE wire), and connect it directly to the “B” terminal of your F-body/Truck alternator and that’s it.
John from Speartech advice;
Another great post with diagrams;
Hope that helps.
I just found this thread when searching about hooking up my GTO alternator in place of my F-body alternator.
I was told that the GTO alternator is self exciting and mine is stamped with 140A. Hopefully this will be enough to power my stereo and all my other electronic gadgets.
Thanks to everyone who posted in here for explaining it in extremely simple terms.
Great info.
96 M3 | Forged LSx | Twin S366 | Injector Dynamics | E85 | AEM Infinity
90 Schwarz 325i
IG : sdobart
