Exterior: Cosmos Black, Racing Dynamics Front Splitter, JT designs underpanel, M3 LTW replica rear wing, TC design folding front and rear tow hooks, Silver LTW flags.
Interior/Safety: TC Design Custom Welded Cage, Sparco Corsa Seat with Sparco Carbon fiber head restraint, VAC Aluminum Seat Mounts w/Sparco Sliders, SPA fire system with 2 nozzles, Momo Competition steering wheel with radio PTT and quick release, Momo aluminum pedals, Diamond plate aluminum floor pans, aluminum door skin panels, functional power windows.
Engine/Drivetrain: recent used s52 motor installed with OBD1 electronics, Conforti intake, Euro HFM, Shrick cam kit, 24 lb fuel ingjections, Conforti chip, Fluidyne Radiator with custom aluminum shrouding, Samco slicone hoses, Metal impeller water pump, Spal electric fan, Victory Product Designs Oil filter adapter, 2 quart Accumsump with electric valve, Setrab racing oil cooler, HIOP headers, supersprint resonator, UUC Twin Silencer Exhaust, 96-99 5 speed transmission, 8.5 lb Lightweight flywheel with M5 Sprung hub clutch, UUC Short Shift Kit, Custom built 3.73 differential w/Rogue Diff Cooler, UUC urethane engine and transmission mounts
Suspension: Custom valved Bilstein GroupN coilovers, Eibach springs, Ground Control rear weight jacks, Ground Control camber plates, Ground Control front sway bar, Ground Control rear shock tower mounts, UUC rear camber arms, M3 LTW shock tower brace, Powerflex urethane suspension and subframe bushings, welded front and rear subframe and rear sway bar reinforcements
Wheels: 18x8.5 BBS RC wheels (2 sets), selection of H&R spacers front/rear, wheels studs and H&R aluminum nuts
Brakes: UUC 332mm 4 piston fronts, UUC 4 piston rears(uses 750i rear rotor), Stainless steel lines, BMP front bumper brake inlets, Bimmerworld brake duct backing plates
Gauges & Electronics: Optima light weight deep cycle battery, electro luminescent IP, VDO water/oil temp/oil pressure at eye level, VDO volts, trans temp, diff temp below HVAC controls, roof antenna wired ofr race radios
older NASA log book included, Great car for the money!
$19,900 OBO
http://www.flickr.com/photos/3213390...7623022524213/
2014 Audi S4, Monsoon Grey , Titanium Package, 6spd
2019 Ford Mustang Bullitt, Dark Highland Green
2018 Dodge Ram 3500, White, 4x4, Cummins, Aisin, crew cab
2020 Kia Telluride SX(wife's ride)
2002 Ford Thunderbird (wife's ride)
2015 Dodge Hellcat, Phantom Black, 6M
2010 Spec Iron Race Car, Mustang GT Candy Red #55
bump...
bump
interested - can you post your contact info? Evidently I've not been around here long enough to send you a private message.
Chris, I got your email - awaiting your response to mine (you might look in your spam folder). thanks
Mark,
Sent you an email and additional pics...
Chris
Thanks for all the interest, looks like a sale is pending... if it falls through, I will post the compression and leakdown numbers for the motor which was completed on Monday night...
Thanks again!
If the sale falls thru, please call me! I'm in Chicago, looking for exactly this kind of car. Thanks!
773-983-5594
