Page 2 of 2 FirstFirst 12
Results 26 to 26 of 26
Thread: Reduced the Negative Camber on my Rear Wheels - Very Pleased!
  1. #26
    SC
    2010 E60, E34, E46
    Quote Originally Posted by bimmerfiver View Post
    It's the big eccentric bolt. Numbers 15, 15 and 17:
    http://www.realoem.com/bmw/showparts...19&hg=33&fg=30
    The bolt/nut in question...it's the one you see when you're parked behind your e39; they are very visible and easily accessible...like Britney on crack.
    Just wanted to let future readers know that bolt #15 primarily adjusts the toe in. The one he mentioned above as being visible at the lower rear is bolt #11 which adjusts camber and also affects the toe. Adjust 11 first for desired camber and then set 15 for proper toe. The E60 is the same basic setup.
