Page 3 of 3 FirstFirst 123
Results 51 to 60 of 60
Thread: Are m and non m steering racks the same after 1995?
  1. #51
    Nov 2007
    Central IL
    95 M3/10 Avy Z71/more
    Quote Originally Posted by bluptgm3 View Post
    What is the ‘catch’? Does the non-‘M’ rack not ‘feature’ the end notch to accept the inner tie rod locking plate?
    The non-‘M’ installation uses a flat sheet inner tie rod locking plate and ‘M’ (at least M3) uses flat sheet with a 1/8th inch horse-shoe ‘stop’ that limits rack sector gear travel.
    Yea, that's what I was referring to, it's been a while.
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
  2. #52
    West V
    1995 M3
    So...the answer is yes it will? lol
  3. #53
    Nov 2007
    Central IL
    yea they'll work, I'd just look at the locking plate/washer and make sure you have or get the correct one if need be.
    I'm not sure this is the case for all Z rack (Pelican parts shows the horseshoe shape for Z and E36), but mine had the other style IIRC. (Again, it's been many years now).
    1995 M3
  4. #54
    West V
    1995 M3
    Thanks for the input.
  5. #55
    Jun 2005
    Concord, NH
    08 E90M3; 99 E36M3 Turbo
    It's E46 yellow tag isn't it? The ZHP rack (712 part #). It's not quite as short as the Z3 rack but still linear and significantly shorter than the stock M3 rack. It bolts right in and takes E36 outers.
    http://www.zhpmafia.com/forums/showt...are*-different
    Maybe yellow or purple? Someone will have to double check that.
  6. #56
    Aug 2013
    1999 BMW M3 Coupe
    Yeah the yellow tag 712 ZHP rack is the E46 rack everyone gets (when they don't get a non-M Z3 rack). I'll be installing one next week. Some people also use the Z4 rack which is really short but requires some modification to fit in an E36. There's an old thread on that around here somewhere.
    1999 M3/2/5 - Titanium Silver - Daily Driver and Track Toy
  7. #57
    Jun 2005
    Concord, NH
    When you do the E46 rack do you remove the restrictor in the rack to pump line because the rack has a check valve in the banjo bolt? What does that check valve in the upper banjo bolt do?
  8. #58
    Aug 2013
    1999 BMW M3 Coupe
    I'll find out next week, but everything I'd read online from people who've installed ZHP racks says that it's just a bolt-on with no modifications needed other than using E36 outers.
    I'm planning on using my existing E36 banjo bolts and line:
    https://www.fcpeuro.com/products/bmw...em-32411141953
    https://www.fcpeuro.com/products/bmw...lt-32416852469 - these are on both ends of the rack to pump line above
  9. #59
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Moron95M3 View Post
    The M3 tie rod locking plate (w/horse shoe ‘stop’ works on all E36 racks as they are virtually all the same rack (except non-‘M’ Z3).
    Do they fit non-‘M’ Z3 or E46 racks?
  10. #60
    Kennesaw, GA
    95 M3, 87 535is
    E46 racks don't have locking plates.
