http://www.beisansystems.com/procedu..._procedure.htm
Remove rivet at each top corner of fan shroud. Pry out rivet center pin (tack lifter), then fully pry out rivet from base (tack lifter).
Hi, guys.
When you describe the procedure to exchange the transmission mounts on a L6 engine, are you talking about an automatic transmission? So you don't need to remove the crossmember bar?
And... can the transmission mounts be exchanged without removing the engine mounts? I recently changed them and now I only want to do the tranny ones in my '02 530iA. I mean, can I jack it up without loosening the engine mounts?
Thanks!
For trans mounts:
- Support the Trans with floor jack (use a piece of wood under the trans)
- Remove the trans support bracket
- Replace the trans mounts and put the support bracket back.
- That is all.
E36 DIY but essentially the same for E39:
http://www.pelicanparts.com/bmw/tech...nny_Mounts.htm
A lot of thanks. Removing the bracket makes much more sense as you don't need to force anything out of its position to replace the mounts.
Did you find any difference in engine sound inside the cabin when replaced the tranny mounts?
I recently tried to replace my transmission mounts (5-sp manual) and failed.
With the tools I had (socket set & swivel extensions), I couldn't find a way to get the right-side top nut off; everything kept bumping into the flex disc nuts. Left-side mount top nut was easy but I just put it back on and decided to buy a set of rachet-type box wrenches someday soon, then try again.
Wha? It's piss easy! Get a ring spanner on it and that's it. Also, use some WD40 before hand and it should go off like a treat.
Did this on mine last week, the engine mounts were a bit tricky, it's best to do one at a time, so the engine can tilt a bit and you can get one out a bit more easily.
The tranny mounts, as said, leave the top nut be, just put it on, if you tighten it before lowering the tranny it won't want to seat in properly.
I expected it to be easier than the engine mounts I replaced back in late summer. So, I need to remove the bracket and lower the trans a little bit first to get to that top right mount nut? Wasn't too sure I wanted to be torquing away at the side of a jacked transmission, but that must be the way....
MehMan, ring spanner = offset box wrench? Okay, thanks!
Ah... how do ya'll get a torque wrench in there on the top nuts after the bracket is back in place? Seems improbable......
What are the symptoms of worn motor mounts? I keep noticing a "groaning" sound (subtle, not loud) when engaging 1st gear at low rpm.
(2000 528i, M52TU, 5Spd)
2001 E36 Z3 3.0 5MT/Sport - back to 3 pedals, current FUN car, part time DD
2000 E46 323iT 5AT/Sport - damned AT lost reverse, sold on an project car
2009 E92 335i 6MT/Sport - escaped the PRC, sold to a good home, sorely missed
2000 E39 528i 5MT/Sport - escaped the PRC, sold to a good home, missed
is there a DIY write up for the e39 528i ?
.. 1999 528i .. Cold and Premium Package ..
