When my car is idling my low oil pressure light flashes periodically, and has been getting worse day by day.
It's to the point where the second my rpms drop to idle it comes on for a good few seconds, and does this multiple times, including flashing.
Is this probably a sensor or is it something serious like my oil pump.
There is oil in the engine.
1995 318is
violet on black
5 speed w/ lsd
268.xxxkm
Mine did this for a long time -- drove me nuts! I even switched to a heavier weight oil thinking I had issues with my engine internals.
I replaced the oil pressure sensor (switch) -- it's on the back of the oil filter housing.
Problem solved (for me at least)!
1999 ///M3 TiAg | Heated Power Vaders | DDM Projector36 5000K 55W HIDs | DDM 3000K 35W HID Fogs
DDM Smoked Corners | DDM Weighted Shift Knob | K&N CAI | Mishimoto AL Rad w/Zionsville AL Shroud
Stewart HiPo Water Pump | Samco Hose Kit | 16" SPAL Puller Fan | Viper 5701LE Security
E36 OBC is now open! Join the effort: BF.C Thread | openOBC Wiki
could very well be a sign of a failing oil pump.
I don't remember what page, but in the owners manual it says it's normal as long as the light goes off as soon as you rev the engine.
