post here links, point to threads/posts..
Here's an Index I started out to try and categorize the DIY's for handy reference.
Basic Maintenance
Oil Filters, Air Filters, Belts, Ignition Rotors, Spark Plugs,
Ignition Wires
____________
E24 E28 DIY Links (ALWAYS CHECK IN HERE!)
Listed by topic..
Online Manuals
____________
Online Factory Repair Manual
Electrical Wiring Diagrams PDF
Online Repair Manuals
E24 Factory Manual PDF (must have acct. to download)
1985 BMW 635 Csi Electronic Troubleshooting Manual Online
Body, Windows & Seals
Paint, Exterior Trim, Seals, Body Weatherstripping,
Emblems, Grilles, Bumpers
____________
Window stuck down?
DIY E24 Front Bumper Shock Compression
DIY E24 Rear Wheel Arch Rust Repair Saga
E24 Euro Bumper Conversion DIY
Listed by topic..
Interior
Repairs, Replacements, Seats, Leather Care, Power Seats
____________
Recaro Seat Upholstery
Listed by topic..
Transmission Swap Info
____________
Auto/Manual Swap '88 Euro E24
Update the shifter linkage for a Getrag 265!
Brakes
Pads & Rotors, Lines & Hoses, Master Cylinders
____________,
Listed by topic..
Suspension & Steering
Shocks & Struts, Bushings, Ball Joints,
CV Joints, Axles, Steering System
____________
E12 (early E24) Engine and Suspension DIY Links
Listed by topic..
Electrical
Ignition, Lights & Lenses, Charging System, Fuses,
Gauges, Switches & Motors
____________
DIY E24 Turn Signal Relay Repair
Listed by topic..
Transmissions, Clutches & Driveshafts
Clutch Kits, Flywheels, Shift Linkage, Short Shift,
Bearings, Driveshafts
____________
Sheet Metal Shifter Modification
Driveshaft Rebuild DIY E24
ZF 4HP-22/24 Automatic Transmission Overhaul Manual
Listed by topic..
Engine
Oil Circulation, Camshafts, Cylinder Head & Valvetrain,
Main Components, Camshafts, Pistons... Teardowns & Rebuilds
____________
M30 Valve Adjustment
E24 (E28) M30 ECU DME repair - chip install DIY
E24 M30 Engine Mounts DIY
Listed by topic..
Fuel & Intake
Intake System, Air Filters, Fuel Injectors,
Fuel Pumps, Fuel Filters
____________
Fuel Pump Replacement
DIY '85+ E24 Injector Replacement / Upgrade
AFM Air Flow Meter service repair DIY pdf
Listed by topic..
Water Cooling System
Radiators, Sensors & Senders, Water Pumps,
Fans, Thermostats
____________
the "heater won't turn off" problem
Heater Valve Repair
Listed by topic..
Exhaust
Mufflers, Exhaust Pipes, Catalytic Converters
____________
Euro M exhaust project
Listed by topic..
Ventilation, Heat & A/C
Compressors, Receiver Driers, A/C Hoses
____________
Heater Blower Repair
Listed by topic..
Miscellaneous
Belts, Wipers, Emblems, Antennas, ,
Bleeder Valves, Jack Support
____________
Vin Decoder Thread
Listed by topic..
Here is a great link to M30 Valve Adjustment. Its from an E34, but its all the same on all M30s.
-Jeff
1983 633csi a.k.a. Wolfie - M30B35 Swap - Getrag 265 - 3.73LSD
I also forgot about this one that was just brought up in another thread,
Ricks No Start Page
-Jeff
links updated
Here's a great Motronic Basic/1.1 troubleshooting guide. It has certainly helped me!
http://www.hiperformancestore.com/Motronic.htm
1989 (10/88) 202k E34 535i/5 Schwarz/Natur
1989 165k E34 535i/5 Schwarz/Natur (Gone)
1989 220k E34 535i 3.0 M60 Swap Weiß/Schwarz (Gone)
1988 159k E28 528e Schwarz/Pearl (Gone)
1985 270k E28 525e Import Arktisblau/Blau (Gone)
1987 125k E24 L6 Schwarz/Natur (Gone)
1987 210k E30 325is Delphin/Beige (Gone)
1985 190k E30 325e Alpinblau/Beige (Gone)
Hello!
My name is Santiago and I live in URUGUAY, South America.
I´v just bought a 1987 L6 and I´m extremely delighted with the car!
Unfortunatelly, the original Factory manual was not included when I bought the car
I need your assistance as I am trying to download the E24 Factory Manual PDF (must have acct. to download) that has been posted upwards, and although I´m logged in, the systems keeps telling me that I need a valid user name or password.
Can anyone please help me downloading this PDF file?
THANK YOU VERY MUCH IN ADVANCE and I am really glad that there are forums like this one in which we can discuss and help everyone!
HAPPY, HAPPY, HAPPY 2013 for everyone!!!
Kind regards,
Santiago
Santiago welcome.
Sorry no one has answered.
Online Manuals
____________
These are the best i've seen
The first is the one. Malloc, I use.
Jay
'88 M6 Cinnabar Red / Nappa Natur Highline Interior (10-87) Santa Ana, California. USA
My NEW Website, Link : https://www.jaysbmwparts.com
Booster repair
A/C Wingcell Compressor leak repair
e31 Door Handle Fix,
Thanks Jay for your reply!
But I still can´t download the E24 Factory Manual PDF (must have acct. to download)!!
When I try to dowload it, being logged in, it redirects me to another page that requests my user Id and password and when I enter it, it sais that the info that I entered is incorrect...
Is that link working?
Has anyone uploaded that user manual in any other server where I can download it from?
THANKS!!!!
Santiago.
Santiago: That manual link is to the BigCoupe.com and not bimmerforums.com. So you have to join BigCoupe first. Joe
Many retired links here, this needs to be updated.
Hi, I'm reassembling the under dash of my 1987 L6, which I did not disassemble. Can anyone tell me where the 5 blade relay goes? It was just lying on the floor, and I can't find a matching wiring plug. Second, bundled with the Onboard computer plug is a flat, wide and thin plug with 3 female connectors, a blank, and a 4th female connector. I can't see where that connects, either. Any thoughts?
The 5 blade relay may be the flasher relay that goes under the steering column. THere is also two large relays that are behind the drivers kick panel up and to the left to the right of the large white junction. I have my entire 635 apart right now cleaning up the wiring and labeling everything. if you have any 635 questions, I probably have the answer.
feel free to email me directly at cipherbmw@protonmail.com. now is a great time because i can send you all the under dash pictures you could ever want.
I have too many BMW's
85 635CSI
92 850i
2000 X5
2000 M5
2005 745Li
2014 428i (wife)
