Results 1 to 6 of 6
Thread: Faultcodes 2760 & 2761 secondary air system bank 1 and bank 2
    Mather, Ca United States
    2003 BMW 745i
    Hi Fellas,
    I threw a check engine light shortly after performing a routine oil change on my 03' 745i. My odometer is 79k and I generally run 6k miles between oil changes and have never had an issue. This code popped up on a cold day while accelerating mid pedal up a small incline. If anyone can lend advice of a similar event or has knowledge of these codes I appreciate any help you can be.
    Valley Motorwerks - Ranch
    1999 540i sport, 89 325i
    Changing your oil and the fault codes are not related. IMO clear them and see if they come back...
    Sep 2008
    alabama
    2002 bmw 325
    first thing i woudl do is activate teh sec air pump to see if it is pumping air. I have seen them get full of water and then teh frist freeze kills them. I do it with a GT1, so you will just have to put 12v on it.
    Second the dirvertor valves are behind the intake and i have replace thousands since 02. They are a pain to do but dooable as a DIY.
    having both bank 1&2 makes me think you have a pump issue or hose issue since each bank has its own valve usually i see one bank or the other.
    02 BMW 325
    13 MB GLK350
    94 GMC sonoma 4x4 - hpd30/8.8 - toy
    15 MB GLA250 (wife's)
    01 Pontiac WS6 - Garage Queen
    12 RAM CC Hemi powered - new DD
    GOIN BROKE BUT N STYLE
    2003 BMW 745i
    Thanks, I'll check the valve first.
    Jun 2008
    Greensboro, NC
    98 M3 Coupe
    yeah good luck checking the valve itself.
    get the codes cleared and see if they come back, simplest thing to do and the best way to rule out a fluke code( seen that too many times)
    98 Alpinweiss M3: Dinan CAI, HFM, Big Bore throttle kit, exhaust and Stage 4 software, short shifter, shiny long tube headers, koni, H&R HP#'s unknown...
    Mar 2019
    winnetka ca 91306
    bmw x5
    my e46 code 2761 is cost not thing see how i do in youtube thank you
    https://www.youtube.com/watch?v=YHgxVorGk5U&t=50s
