Results 1 to 11 of 11
Thread: Oil Filter Housing Seal Replacement (528i)
    West Michigan
    98 540iA (Prd 11/97)
    The first DIY doesn't mention disconnecting the battery's positive terminal, but the second DIY makes a big point about it. Better safe than sorry.
    DIY-oil filter housing seal
    Oil Filter Housing Leak Repair
    Omaha, NE
    1998 528i 5-spd 102K
    Thanks James,
    People need to know that fixing the O.F. Housing Rubber Gasket is only one issue.
    Another separate issue is the 2 Aluminum Plugs on the back side of the O.F. Housing can leak too. Here is the thread on it:
    http://forums.bimmerforums.com/forum....php?t=1341719
    Anyone has a used (Leaking Recessed Plugs is fine) M52 Oil Filter Housing laying around so I can use as a guinea pig? I will return it in repaired condition (if the guinea pig is still alive LOL)
    Here is what I am getting at, for those familiar with NPT (National Pipe Thread Tapered Thread) concept, it is basically Tapered Thread for good sealing.
    The 3/4" Blue Anodized NPT Plug I just received has the standard NPT dimensions:
    - Inner Groove: 24.80 mm
    - Outer Thread Tips: 26.67 mm
    Therefore, on the O.F. Housing Side, the bore size must be around or less than < 24-25 mm, this way I have room to tap the threads.
    Again, I NEED A GUINEA PIG please!
    West Michigan
    cnn,
    I saw that thread and your possible solution. Thanks for adding that.
    Omaha, NE
    I just posted the Oil Filter Housing OVERHAUL: from O.F. Housing Seal to the Repair of leaking "Freeze Plugs":
    http://forums.bimmerforums.com/forum....php?t=1350178
    Indy--->Chicago-->Atlanta
    2003 530i E39
    Quote Originally Posted by jamesdc4 View Post
    Why do people say disconnect only possitive terminal..
    Dont' you need to take the negative off first? Else, well... die?
    Dec 2010
    Sterling, VA
    98 540i e39
    is this the same procedure for the v8?
    Sep 2009
    Sheveport, LA
    1994 318is; 2001 525i
    Quote Originally Posted by rcatank View Post
    You have to disconnect the positive cable from the alternator to reach the housing.
    2003 530i E39
    Post
    Quote Originally Posted by shlalaw View Post
    I was just going to disconnect the negative and positive from the trunk first before I start anything.....
    Tons of work to do next week.
    - Oil Filter Housing seal
    - Spark plugs + boots
    - Valve Cover Gasket
    - Tire rotation <-- Hardest
    Sep 2009
    Sheveport, LA
    The reason is the alternator wire is still "hot" until disconnected at the battery. Good luck on the oil filter housing seal. Did mine last weekend. Be sure and follow the tip to write down where the six housing bolts go. They are of different lengths. And don't mistake the idler pulley for the tensioner. I did at first. A PITA, but do-able.
    2003 530i E39
    Did you have to use a T50?
    Sep 2009
    Sheveport, LA
    Eventually. Before I wised up, I was cranking on the the bolt on the idler pulley. Wouldn't move the belt a damn bit!
