I have some updates to make later today, but I wanted to first share some video of an AST racer's E30 that I thought you guys might like:
Bob Ederer's LS1 powered E30. 2300 pounds, 411 whp, AST equipped, race car
Bob Ederer's LS1 e30 Racecar on the dyno - made 411 whp
In-car video from Hallett - Comma GT Feature Race - April 25, 2010
E30 LS1.... that's a neat idea!
His car has the target weight we're shooting for, and similar wheel/tire/flare package we are going for, but it has a tick more power than we'll have in July at UTCC.
Bob is an awesome cage maker in Oklahoma City, so if you have a BMW that needs some bars, he's the man.
Good stuff!!!
Terry Fair @ Vorshlag Motorsports
Awsome!!!!
Anybody know where to get the fenders like that rather than trying to fab..
Update for April 24, 2010: Couldn't get any takers for last Thursday night but Jason popped by to help me a bit on Saturday, after we went to Ft Worth to look at this heap of crap he wanted to weigh and possibly buy... [insert 3 hour distraction]
Mazda 323 GTX, AWD turbo rally car built in 1989. 1.6 Mazda motor with a turbo, intercooler, cockpit selectable center diff, tiny little thing. Seems GREAT on paper and it looked classed very well for SCCA Solo, so he wanted to see what it weighed. We heard 2600 but its so small (95" wheelbase, 63" outer track) so how could that be? We had bench raced it to 2400 pounds in our minds... but reality was worse than we had feared. 2703 pounds for this little PoS?! Uhh... this is NOT the car to oust the Civics in ST. Back to the shop we went.
So that burned up most of Saturday morning. We got back and started cutting up the trunk floor. I found some 2" x 2" scrap tubing on the steel rack that looked perfect for the rear diff mount. We just needed to get the old structure out of the way first. Jason started with the plasma cutter and I was on "fire duty", dousing the flames caused by the burning undercoating. That crap is super flammable! I can see why racers go to such lengths to get it off the bottom of the old street car chassis...
Left: The stock trunk floor. Right: Time to cut all that up!
Left: Stock rear diff mount structure coming out. Right: Its gone
He had to bail after a bit of this nasty, smelly work so I kept at it, stopping to put out the flames every few seconds. 3 dirty, smoky, flaming hours later I managed to cut this out:
Left: What was removed. Right: Rear E30 trailing arm beefed up
Got the rear trailing arms beefed up (see above), and we'll be painting those Thursday night, and pressing in the E36 rear hubs and old bearings soon. The remnants of the sunroof structure are all gone now, too. The handful spot welds came out easily (Thanks Sean!) and the rest of it just fell out. Not much weight was left, just looked ugly. Now its pretty and clean in the roof. Dave has the sunroof panel and is doing his surgery now.
We also worked the previous Saturday, with Chris and McCall (is that right? I can't remember that far back) pitching in a lot of work. We test fit 3 different struts and even the E30 spindles and struts again, checking droop, bump travel, ride height, and strut lengths. What we learned after selveral hours of testing was - we really need E36 front struts that are 1" shorter than stock E36 lengths, so if anyone has any used E36 Bilstein SPORT front struts for sale cheap please PM me.
Left: E36 ASTs and E30 stock struts at full droop. E36 AST struts are probably too short for an E30. Right: E36 AST at full bump
Some of the inner fender structure was cut/clearanced to clear the 275mm tires at full lock up front. Yea, the wheel is not perfectly centered - to hell with that for now. We've got to get it going and we don't have time (or budget) to totally re-engineer the front suspension to center the wheel. We can make the flares look right and everything clear the 275mm tires.
Still have a lot of work to do on the body, but its coming along. The main rust patch in the firewall is patched and we have two more rust patches to do on the floorpan. We should have the E30 diff with the E36 rear cover mocked up in the car Thursday night so we can figure out where the 2x2" tubing should go, then we'll get to welding that in place and fabbing the rear diff mount brackets. We lack one little clutch fitting to get the motor/trans back into the car for header mock-up and construction, too.
More soon,
Update for April 29, 2010: The shop was a buzzing hive of activity last night! We had four people working on the E30 project (Derek, Chris, Sean and me) and we got a lot done in only 4 hours. First up we took a lot of measurements then sketched a design for the Nylon rear trailing arm bushings. Chris first cut several round blanks from a chunk of scrap Derek got for free a while ago. Meanwhile Derek made four steel sleeves (the M12 bolts will slide through these to prevent wear to the Nylon as they pivot) from some 5/8" OD steel tubing I bought last week for another fab project. I whittled down the round blanks into press-in bushing halves, pretty much spending the entire night on the lathe. I didn't quite finish all 8 pieces, but its close...
The 6 steps to making homemade trailing arm bushings - for cheap!
As you can see no exotic machinery was used to make these bushings - just a hole saw on a drill press, our cheap manual lathe, and a band saw were about the extent of it. Some clean up was done with a bench grinder and pneumatic die grinder. Probably 5 hours of work to make them - but time is free. Derek had a box full of Nylon scrap somebody gave him so we're going through the whole car making Nylon bushings to replace anything rubber... the car is slowly morphing into a race car it seems?
Sean spent the evening (his first GRM work night!) cutting the trunk floor to bits. After we laid out some ideas on the horizontal bracing we want to add between the frame rails (2x2" square tubing) and mocked-up the diff to see where everything should be placed, he and Derek cut the spare tire well out of the floor. It was just in the way of where everything needed to be. Dropped over 10 pounds from removing that, but we'll add some of that back when we make the "plug" for this massive hole as well as the structure for the rear bracing (the section of 2x2" tubing was 11 pounds all by itself - but its pretty beefy).
Sean then used a pneumatic air saw to cut a precise slot for the square tubing to protrude up through. It will stick above the trunk floor not even 1/4" - just enough to give us a landing pad for any additional bracing we may want to add (like some tubing between the shock towers and this brace?) The tube can be stitched welded to the trunk floor to add plenty of rigidity, and we'll mimic Bob E's spare tire well reinforcement tricks he shared with us.
That was some LOUD and messy work - the floor is a mess!
Derek and Chris spent the rest of the evening pressing the old floppy rubber subframe bushings out. Wow, those things are nasty! The factory presses in these two steel/rubber/void filled bushings into the subframe housing then uses a pinch press to stake the housing, keeping the bushing from falling out. This makes it a REAL bear to press out the old bushings. It took cutting the centers out with the SawsAll, making a press sleeve to push against the bushing's outer metal sleeve, and it deformed the press sleeve during the press-out process. This now custom shaped press tool made the 2nd bushing press out a LOT faster, though.
Left: Press sleeve we made is now the perfect shape for pressing out stock subframe bushings. Right: Semi-completed trailing arm bushing
We then sketched up the design for the 2 Nylon subframe bushings that we'll replace the flimsy rubber stock units with. Those new bushings plus our dual eared mounting structure/mounts should firm things up quite a bit and stabilize the rear differential and subframe. With the subframe bolted in place at the two stock rubber bushing mounts it takes almost zero force to pivot the rear subframe up and down at the rear. Couple that with a single rubber rear mount and its no wonder these E30's break subframes, rip mounts out of the trunk floor, and have all sorts of slop out back. That would be scary with 350 whp and 275 Hoosiers. Not a problem for long!
More work on Saturday, then a 2 week break on the project while I'm in Spain. If you are at the Barcelona F1 race, look for the Vorshlag crew. We'll be sticking Vorshlag decals on everything I can and snapping pics in the paddock. When I get back it will be a mad thrash to get the drivetrain in and running by.... the end of May?
Cheers,
I was under the impression that some movement was needed in the RTAB, at least in the E36. Hence the RTAB limiters. Is the E30 different or do you guys not consider it a problem?
Also, I can't wait to see the finished product. I'll be there in Gainesville this October.
Looks great! I ran a e36 last year and have ran dsm's 4 years previous. Can't wait for this year, should be a good one.
This is such a cool build, and there's something about doing everything yourself that makes it just that much cooler.
Keep up the great work!
1997 BMW 328is Alpine White // Dove Grey
ZF Swapped | 3.23 LSD | FK Coilovers | 17x8.5 Borbet Type C | 75mm Wheel Studs | 12mm Vorshlag Spacers | 5000k HIDs | Euro Taillights | Suede Headliner/Pillars
Update for May 1, 2010: Last day of work on the car for the next 2 weeks, so we made it count. Costas showed up early and we analyzed and brain stormed on the front suspension. He was worried about caster, and he had reason to - we measured it and it was nearly +15°. We put the 15x10 wheel and 275mm tire on the front and compressed the suspension to ride height, then turned the wheel. WOW. Way too much weight jacking when turning - not good. We needed to ditch a lot of caster... so we mocked up a new strut position (all the way forward within the stock tower hole) and got it down to +12°. And improved wheel position within the fender opening by about 1/2", too.
If we notched more room on the top of the strut tower it looks like we'll get the alignment under +10° caster and move the wheel forward even more. Better and better. But to lower caster more and still have negative camber would take a little more work. The goal is to get under +8 or +9° of caster.
We have plenty of room within the stock tower to move the top of the strut forward another full inch and still room inboard to re-gain the negative camber, but this would require complete strut tower top replacement. After cutting most of the top of the strut tower out we could replace it with steel plate, then make a place to bolt the upper spherical bearing to - that's no longer that difficult given the scope creep of this project. Costas was adamant that lowering the caster would be worth the effort, so more fab work is coming. We also managed to keep the LCA level at ride height and still got 4.5" of clearance to the bottom of the K-member on the short 275/35/15 Hoosier. That'll work.
Paul M arrived fairly early as well and I showed him how to run our little lathe. Its a far cry from the "real" lathes he was used to running in the past but he picked it up quickly and spent a few hours finishing the 8 Nylon rear trailing arm bushings I had started on Thursday. He also machined the OD on the steel inserts down so they are a smooth fit within the bushings. Lots better than my first finished piece. He's now officially our new Team Machinist.
McCall was there by 10 am and he worked most of the day on the front fender structure. Costas was already deep into one side so Jason took the other. They beat, ground, cut and wire brushed that sheet metal for hours.
We also came up with a plan to add some tubing to this area to help distribute suspension loads to the firewall from the strut tower area. Prepped those areas for plate and tubing also. Most everyone had left by 4 pm, and I worked until 5. Took a break and looked at 2010 Camaros and Mustang GTs with my wife, grabbed some dinner, and met McCall back at the shop at 8 pm and we worked until midnight solely on the trunk area.
I spent most of the day and into the night in the trunk. I was cleaning up the mess that plasma cutting leaves behind, prepping the frame rails for reinforcing plates (1/8" steel plate) that needed to be welded in (to weld the 2x2" steel beam to). Got the gap between the beam and the front of the trunk floor very tight. Spent a long time cleaning up the rear factory frame rails to be able to weld to them, and it was still a fiery mess to weld to them. Ground and brushed a lot of paint and primer away to be able to weld - but there always seems to be some around when the welder fires up. Total PITA to weld to painted, primed or undercoated sheet metal.
As I was cleaning the remaining rear trunk floor section I noticed a lot of rust the deeper I went past the "paint".... some knucklehead had spray painted OVER a lot of old rust. Eventually I cut out most of the rest of the trunk floor, as there was no "metal" left to stitch weld the beam to. I suspect a previous owner had let a leaking trunk seal go for too long and standing water sat in the trunk for months if not years. Nice. Oh well, we'll have room for a fuel cell if we can find room in the budget for a bladder (we'd just make the steel can it resides within). Probably cannot afford even that, though.
I measured a consistent flange around the back trunk floor section and cut out most of the rest of the trunk floor sheet metal. We'll rivet an aluminum sheet in place, as the structure will be more than made up for in our massive 2x2" steel cross beam. McCall cut up the 1/8" plate using the templates I made from cardboard and bent them into 90° sections. Got those suckers welded to the frame rails (with lots of clamps, tack welds, hammer forming the to the very UN-flat frame rail sections) then we fit the 2x2" beam between them. We got it in there with no gap to the front trunk floor, level, and perpendicular and flush to the frame rails. Tacked that in place then called it a night at midnight. Wow... what a long day, but we got a lot done.
That's it for a bit. Hang tight - after McCall and I are back stateside in 2 weeks work will resume on this project.
Adios!
Good update Terry. Any plans to get that tierod level?
We'll see if we can find the $ for a home-built bump steer repair, yes.
Mini Update for May 5, 2010: Just a quick shot of the rear cross beam we added with the diff bolted in place. The brace and diff are perfectly aligned and fitted. We'll start adding the new rear mount structure when I'm back from Spain.
Adios!
incredible!
(see attached) Use that lathe to create rack spacers, or in a pinch, use a stack of washers.
Hope your vacation went well.
Since they are running relatively small wheels for the challenge, that might be one of their only options. Depending on what motor/pan they ultimately use, the spacers might require the motor to sit a tad higher than they want.
I had to space my rack down for oil pan clearance. Well, I didn't have to but to get the motor as low as possible, I did have to move the rack down and put the spacers on top. Because I'm running e30/m3 front end parts and 18" wheels it was easy to get the tie rod geometry correct.
Updates?
Update for May 24, 2010: Not very glamorous work this time, but its all necessary for this project. I was out of the country for a couple of weeks (read my Barcelona F1 race write-up, with pics from the F1 Paddock and a tour of the McLaren pits/garages here) but four of us on the team got back to work on the car again this last Thursday night, and I spent all day Sunday welding on the E30 as well. Chris, Sean and Matt worked on some things after work one night when I was out of town, which was a nice surprise. They finished the trailing arms - cleaned, primed, and painted them then pushed the cleaned up hubs and bearings in place. Excellent work on the trailing arms, guys! Looks as good as new.
L: The bushings and sleeves are pressed in. R: Who knew 25 year old bits could look this good!? With enough elbow grease, anything is possible.
So this last Thursday night it was Costas, Chris, Sean and me. We had the 4-point roll bar bolted together in the car, ready to go in, but we realized I needed to repair the big floor pan rust hole before the bar could be bolted down. When we pulled the carpet out to fix that floor panel patch, we found all of the factory glued on insulation and some other crud that needed to go. We were looking to remove at least 60 pounds from the interior - to offset the 60 pound Kirk Racing 4-point roll bar we were adding - and we've found it before even including the front seat replacements we have planned.
L: Kirk Racing 4-point sitting in the car. R: This can't be good...
We discussed the extent of the weight removal for the project and decided that - yes, we wanted it to still be street legal and "street usable". The final final plan is to keep the heater functional, blowing through the defrost vents only, while the the rest of the ducting and the A/C bits were slated to be removed. There's no reason to keep A/C in this "racey" of a car, but it will still have a working defrost, door windows, wipers, horn, lights, turn signals, carpet, upholstered front seats, and all of the factory glass.
Pulling the dash and lightening the HVAC bits
In all we pulled out over 40 more pounds of insulation and junk from the interior. Sean scraped off the under-carpet sound insulation that was bonded to the old floor pan repair and cleaned the goo from that sheet metal. Removing the back seat itself dropped a full 30 pound. The front and rear seats have already been sold, as has the engine and trans, so the car is valued at $0 and we've even gone negative by a bit. We've sold off more in parts from the car than we paid for it by $75 - but zero is as low as we can show for the car on the $2010 GRM Challenge budget. We've even got some more parts from the original car to sell... not to mention off of the V8 engine (which I won't mention).
The guys got the dash pad out intact, without having to drop the column (which is held in place with lame security bolts), which isn't supposed to be possible. Likely we'll put that back in place after dropping the column (and replacing the snap-off-head bolts), because it was a bear to remove. Once the dash pad was extracted the HVAC system was partially pulled away from the firewall and torn into. We were after the A/C evap core and its 6.1 lbs of dead weight...
L: Evap core was 6 lbs. R: The carpet, center console, & interior panels are to be reinstalled
With the evap core removed we had a big hole to cover up, so I made a block off panel that will be bolted in place. My new electric sheet metal sheers ($35 at HF) made quick work on the 20 gauge sheet metal scrap, then I started on the floor panel repair work. The remaining wiring harness will be left alone; there's probably 5-10 pounds of unused wiring left, but we're not going to spend too many hours chasing that.
Little cover made to cover the hole left by the removal of the evap core. We'll shoot it with paint then screw it into place
As we tear into this Texas car we keep finding little spots of rust, not from road salt, but from long ignored leaks (the sunroof and trunk seal), which probably went unattended for years. Sean prepped the big hole in the left backseat floor pan area for a patch I began and finished welding on Sunday. He pulled the old patch panel (that was bolted and held in place with spray foam!) then sanded the surface to bare metal on both sides. I've still got a little stitch welding there to finish then I'll prime it top and bottom.
One of our team members (who shall remain nameless) tried to patch a small rust hole in the passenger front seat firewall/floor pan, also from another leak that was left for too long. Anyway, this team member tried to weld in a series of small patches - using the wrong welding wire and settings - and ended up making a mess of the whole area. By the time I saw it 3 hours and lots of welding wire had disappeared, and the remaining holes were bigger than the original. Hehe.... we gave him lots of grief.
L: This was the aborted repair I found. R: I tried to salvage the 3+ hours of work already burned on this "repair", to no avail. Time for a mulligan.
I tried to salvage the already started repair, and got most of a small patch panel tacked into the largest remaining hole, but the steel in this area was too compromised. Eventually I made a bigger patch panel that covered up all of the bad area here, hammer formed it tight to the original steel, stitch welded it in place, ground is semi-smooth (nobody will ever see this hidden area), and primed it. More than good enough for this project. Sure, its in a car show at the GRM Challenge, but not that kind of car show.
There was too much "weld" and not enough steel left, so I covered the whole mess with new steel
OK, that's all for this week. I know, its kinda boring stuff, but it all had to be done.
Up next: We're still awaiting one stinking fitting to allow us to put the entire drivetrain back in, but I'm going today to find that myself instead of waiting on the supplier I have tasked for this. The floor pan is repaired so the roll bar can be bolted in place, then I'll attack the finish welding on the custom rear cross brace and make the dual eared diff mounts. Once we correct one small error on our trailing arm bushings (waiting for our "team machinist" to return from working in Ireland to tweak some bushings), then we'll put the refreshed rear trailing arms in place and start cutting the rear fenders for tire clearance and mount the rear brakes. This weekend I'll also patch the holes we made in the front inner fender areas for tire clearance (at full lock), then add tubular braces to tie the strut towers to the firewall. I am dying to bolt the 18x11" wheels on the car (which we'll use at the UTCC event) so I might go get some junk tires mounted to them this week.
More soon,
Update for June 1, 2010: We worked a little last Thursday night, and I worked all 3 days over the Memorial Day weekend on the project, with some assistance Monday afternoon from Chris and McCall. We got a lot knocked off the list on the E30 project, but we're quickly running out of time.
Tire clearance was gain at full lock by cutting this corner section out
The front inner fender areas had some tire clearance issues at the rear edges when the 275mm tires were turned full lock, so we cut away a triangular shaped section, made patch panels to cover these/reinforce these areas, and finally welded those in place.
Patch fully welded in place, then spreader plates added, then a reinforcing bar
The diagonal reinforcement tubing (see above) was meant to help transfer cornering/braking loads from the inner fender structure to the firewall - to keep flex under control. We've seen this done on other E30 builds, and it was suggested by Greg S., who came by a month or two back. It cost almost nothing in materials - just a lot of time. Welding to the stock sheet metal is never fun, and when the backside is inaccessible (and covered in paint and/or undercoating) it makes a huge smoky mess when it gets hot.
This is the patch tack welded in place. It was then fully seam welded
There was also some crash damage on this car we found a while back which I worked on this weekend. One part of the strut tower sheet metal was buckled so badly it had pulled away from the firewall at the spot welds. I hammered at this section with body hammers, dollies and drifts for an hour and got the area back into its original shape, but that part of the panel was fried. I cut it out, made a patch, cleaned the surrounding area of paint and undercoating as best I could, and welded in a new 20 gauge patch panel. I then seam welded (or tried to!) the various remaining stock panels in this area. Welding through the stock seam sealer is also NOT fun. Anyway, its stronger than stock now and back in the right location. Spent way too much time on that stinkin' patch.
L: Diff mounting bar stitch welded to trunk floor. R: Floor pan patch re-re-patched
On Monday I worked in the trunk and on the big floorpan patch panel some more while Chris and McCall prepped the floor for and installed the Kirk Racing 4-point competition roll bar (+60 lbs). Got the main diff mount 2x2" tube fully welded in place and ran a stick weld across the entire length of the trunk. I also cut out some more of the trunk floor aft of this bar that was crusty - now its a big 2' x 2' square that will have a simple sheet metal panel screwed into place.
The biggest floor patch panel I made last week had some edges that were still too rusty to seam weld the patch to, so I made two progressively smaller patches to cover these areas up. The "right" repair would have been to bead blast the entire area and cut out all of the rot - but we're so far behind on the schedule that we have skipped proper patch panel repair methods.
Roll bar install is always fun - it takes two people, some patience and several trial fittings before you even start drilling holes. Chris and McCall smoothed out the floor where the main spread plates mounted, they trial fitted the 4-point, marked the holes, drilled them all, primed/painted the new patch panels, then bolted the bar in place. It was about 3 hours work, start to finish. They also painted and drilled the evap core patch panel.
Still need to get to the sunroof patch panel welded in place, then we can concentrate on the rest. We've taken the car as far down to the bare shell as we'll be going, now its time to really start putting it back together.
These pictures sort of show why we did all of this front inner fender re-work; the 285/30/18s are significantly taller
More soon,
This build just gets better and better....can't wait to see the final results!
On thing...a bit OT.....Do you have any future plans on making an all metal/poly rear shock mount for the E34? Like the one you have available for the E30?
Are you tweaking the fender well to run both 18s and the 15x10s?These pictures sort of show why we did all of this front inner fender re-work; the 285/30/18s are significantly taller
Andrezbim
Yep.... for the UTCC we don't have the insane $2010 budget restriction, so we're running a set of 18x11" CCW 3-piece wheels and 285/30/18 Hoosier R6 tires (that are worth more than the car!). For the actual GRM $2010 Challenge that was the original sole purpose of this project its going to be shod with some $400 circle track steel 15x10" wheels and some throw away 275/35/15 Hoosiers.
Our autox steel wheels are very low buck
Why 18x11's? Because they were out of 18x12s...
The steel wheels are lug-centric, the bore diameter is different, and they not exactly 5x120mm bolt circle, so I'm pretty wary of bombing around VIR at 150 mph on those wheels. For autocross they'll be fine, I'm sure of that. The CCWs and 285s will have more grip and safety for road course use at UTCC. The 285/30/18 tires are a good bit taller than the 275/35/15s, so we are making the fenders clear the wider/taller 285s.
Good lord! those wheels are ridiculous!
When are you planning to showcase the new engine choice?
Andrezbim
