Results 1 to 25 of 65
Thread: Wagon Subwoofer DIY
    S.Florida
    99' 5Sp 528IT/10' Maxima
    Wagon Subwoofer DIY
    I think I remember somebody building a box in the factory space of the Wagons crappy Nokia sub. I am tired of this big ported box I have in mine. Any idea of where that thread is? I checked BavSound and the sub for the Wagon is no longer being sold and in either case I dont have the money to buy it anyhoo.
    1999 E39 Touring Sport and 3 pedals
    socal
    528itouring
    I'm with you on this. I need more knock but I don't want to compromise the factory look too much
    Sep 2009
    Anderson, IN, USA
    03 525IT wagon 5MT sold.
    Subscribed. I'm wanting to do the same thing. I checked with BSW and they will eventually have the wagon sub back, they are just currently sold out. I don't think I want to spend the money either, but it would be nice to have a drop in sub.
    I'm also considering a little different route. I've got a JL stealth box from a Mk IV Golf, that looks like it should fit under the spare tire, and be totally hidden. This box uses a 10" sub and sounds good. The issue with my wagon is the self levelling suspension air pump that is currently located there. If I move this pump, it should work really well...
    Boston, MA, USA
    540 IT
    I use an Infinity Basslink sub in mine, it does take up a small footprint, but not anything like a ported box. IMHO, it's pretty decent, 10 times better than the stock box.
    Tan
    <img src="http://members.roadfly.org/thematrixz/twin.jpg">
    540IT, Dinan CAI, DME and Tranny software. M5 rear sway bar, M-Technik Aerodynamic, Phatbox, MBQuart all around.
    528IT, bare bone stock.
    07 530XiT, need this for bad NE winters.
    Album: http://forums.bimmerforums.com/forum...hp?albumid=174
    Sudbury, MA
    2002 530i w/sport
    If you are looking for improved bass but don't need to feel your bass, consider an armrest subwoofer. Not sure if this will work for the wagon but it is a great fit for the sedan. I mounted a Blaupunkt ThB 200A powered subwoofer in my armrest pocket. This sunwoofer has a small 8" driver so don't expect to feel your bass. However, it is entirely adequate for most listening and is a huge improvement over OEM sound. This installation is totally hidden from view yet provides good bass response and fills the current void. It is quickly & easily removeable and stored in the trunk when you need to carry a fifth passenger. The installation takes about an hour with common handtools. I got mine for $160 but current total cost is less than $200 installed. Do a search for my DIY on this forum.
    Sep 2002
    Shadyville, NJ
    '17 Durango, '10 Panny
    Here's my Thread with what I did...
    http://forums.bimmerforums.com/forum...d.php?t=627674
    But it has changed since I last updated that thread...I'll take pictures and update it tonight.
    BMWCCA #389756
    e39 Touring SOLD.
    S.Florida
    Quote Originally Posted by TheMatrixz View Post
    Tan
    Do you have pics of your set up? This is mine. I want to install the amp under the loading floor(was scared of heat buid up) and I want something in the stock location. Need me my cargo space again!
    Boston, MA, USA
    540 IT
    Infinity Basslink
    S.Florida
    Diffently smaller. I think I might build a ported box that fits in the stock location. I just need to match it up with 10" Sub.
    Boston, MA, USA
    540 IT
    Quote Originally Posted by xpcgamer View Post
    I really wanted to do that but the project just never realized, and per advises from my friend who builds speakers for a living, I need at least 1 sq ft box to get any decent bass. There's not enough room above the battery for that.
    Tan
    S.Florida
    oekunder is dealing with under .50 with his 8" and he loves the way it sounds. What I installed a passive radiator thingy to the box.
    Boston, MA, USA
    540 IT
    I have a pair of Focal Utopia 5WS (JMlab) subs (5.25") to do this project but didn't get to it, anyone interested? These are high end subs that put out a decent amount for air movement, very good for space saving.
    Here's some specs:
    Like nothing else! This is a 5-38 inch SUBWOOFER. Thats right! Utopia 5 WS Subwoofer for small bass reflex enclosure Woofer 5 WS 136mm (5-3/8) subwoofer, special long excursion subwoofer 40mm (1-3/8) v.coil, 100mm (4) magnet Midrange - Tweeter - Crossover - Impedance 5 + Max. power handling 160 W Nom. power handling 80 W Sensitvity (2,8 V / 1 m) 87 dB Frequency response 45 Hz * - 2,5 kHz * Depend on load Fs 44,6 Hz Re 5,2 ohms Qes 0,38 Qms 5,51 Qts 0,36 Dia 10,5 cm Mms 14,8 g Lvc 1,05 mH Hbob 17 mm Hgap 6 mm Xmax 5,5 mm Sd 86,6 cm2 Vas 9,0 l BL 7,5 N/A Folding diameter 116 mm Mounting depth 74 mm Sealed enclosure (l.) - Bass-reflex enclosure (l.) 5 - 7 litres
    polk momo is a great 10" subwoofer, not the loudest but one of the clearest I have heard. wont drown out the other speakers but still adds a nice depth
    http://www.crutchfield.com/p_107MM21...04.html?tp=111
    its discontinued on crutchfield but you can still find them
    PRICE CUT on ALL FABRICS
    Dec 2007
    Palm Beach/Winter NYC/Summer
    2000 540iT SW
    Someone need to make a nice box that'll fit in the stock position. It appears they'd have quite a few customers (myself included!).
    If I had access to a mold I would not be afraid to make one. Would it be possible to make a wooden box that would fit under the stock panels? I am not sure how the wagon is designed.
    Dec 2007
    2000 540iT SW
    Quote Originally Posted by blackxs View Post
    Theres a good amount of space in there for a wooden box, yes. The factory nokia box is on a hinge so you can access the battery, but as long as the box is secured and removable, I see no real issues. BSW makes one but it's $$$
    How much would people be willing to pay for a pre-made box? I know a local guy with a touring who *may* be willing to let me take some measurements, ill talk to him with enough interest.
    socal
    528itouring
    I'm not sure. Of course we have to see the quality , build, and measurement of the box before we will put a tag on it.
    But I'm interested and it seems like a few others might be too. Keep us posted!
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi all Touring owners!
    I have a Trade contact here in the UK who makes bass boxes for pretty much most of the UK's car hifi dealers at his factory. A few months ago I visited him to start the ball rolling on getting E39 Touring bass boxes made up as a cheaper alternative to the BSW kit - not to take anything away from that solution as it's a very well engineered product. However, I want to supply a more traditional solution whereby customers can choose their own Sub woofer driver and have it powered by their own choice amplifier. Of course, the subwoofer needs to be of the correct type and be able to work in very small enclosures, as such this means only a few manufacturers of such subwoofers will have a suitable driver. I started the ball rolling with my own Touring and you can see the results below. As my car is Ex Police, the 'right hand' side of the car has a twin battery setup, and also some leftover wiring and various Ex Police fittings. As such I've decided to tackle that area at a later time. I looked at the 'left hand' side. As my car came with no DVD/SatNav etc, I have a totally blank space there. I got my contact to create a box for me to 'fit' snugly into the space. For final mounting, I'll still need to secure it, but the fit as it is sits very well indeed. From memory it's 0.3 cu Ft (I'll need to call him up again to confirm exactly)
    Pics
    The speaker hole is enough for an 8 inch subwoofer - there's a few makers of 8 inch shallow mount subs. A 10 inch would fit, however the compromise would be in the required volume. I've been told however, by using some of the acoustic 'wool' material, that would help fool a larger subwoofer into performing as though it was in a bigger enclosure. So some 'tuning' can be done here.
    I do know for instance that Earthquake do a 6 inch subwoofer - I need to look into those and their specifications, but from initial thoughts, being Earthquake, they should have good power handling etc.
    The enclosure itself is CNC machined and glued together. I 'beleive' there is some strengthening to the assembly of the pieces - dowel I think? I'll have to ask him again. It feels very solid indeed, more than enough for a 6 or 8 inch subwoofer. This solution is for a modest amount of power and low frequency output and of course at a very reasonable price.
    I shall get onto making a similar solution for the right hand side in due course, I do know of other Touring owners here in the UK to use as a test bed. The factory flip out trim pieces will be used and I have two options. one is to punch some holes in the back of the piece whilst retaining the external carpet material to 'allow' the air to move through. the other option is to cut out a hole and re-trim a 'grille' piece to fit into the hole as per say a home speaker.
    Price wise, a completed box, with terminals would be around the £59 range, so 'currently' around $90 or so. Once I have the 'design' for both sides finalised, I'll be showcasing them on my forthcoming website. I will of course be able to send over to you guys in the USA and worldwide and can work out pricing to suit - as it'd be international.
    Finally, I'd be working in conjunction with my supplier and as such these enclosures will be at a professional level of research and manufacture. They will not be units just knocked up at a back street garage!
    Let me know what you guys think, and any suggestions are more than welcome!
    Cheers! Dennis! West London UK!
    S.Florida
    Thats something like I was thinking of doing.
    Sep 2009
    Columbia, SC USA
    1999 540iTa
    That's very nice Dennis. I would be interested in replacing my stock Touring sub woofer. I can't even tell if it does anything. Sure doesn't create bass. I removed the sub once, and it weighs almost nothing.
    Dec 2007
    2000 540iT SW
    Quote Originally Posted by jdt10768 View Post
    that's very nice dennis. I would be interested in replacing my stock touring sub woofer. I can't even tell if it does anything. Sure doesn't create bass. I removed the sub once, and it weighs almost nothing.
    +100
    Falls Church, VA
    '90 325iX, '00 528iT spo
    Here you go:
    Touring rear subwoofer setup(s)
    *I've seen mad dog 20/20's setup in person ... it is nice.
    Jason
    '90 325iX 5M, '00 528iT 5M Sport (mfg. 5/1999)
    BMW CCA member #130075
    JScott Racing
    Sep 2009
    Anderson, IN, USA
    Dennis sign me up for one, that is exactly what I'm looking for! I'm not sure you will need to add an opening for the side panel as the top is already vented (at least on my wagon). You don't so much hear the sub as you do feel it, so an opening in front of the speaker is not necessary, as long as there is space for the air to move... Keep us posted on when everything is ready.
    S.Florida
    Jason Insaw that thread. I want to know more of Jo's setup. Was it just free aired behind the cover? Or did he mount a box?
