Please Help!!! The fuel pump on my 2004 325iT has gone out and i only have 20,000 miles on the car. I can't seem to find any info on the extended warranty on these SULEV vehicles. Can anyone point me in the right direction?
Thanks, frogdogHI
No special warranty... after 5 years, you are on your own unless you have purchased an extended warranty through an aftermarket company or through your local bmw dealer.
Your car is low mileage, but it is the time factor that got you, not the mileage.
Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
Ouch! Seems i read somewhere that there was an extended warranty on all parts having to do with the low emissions. Shoots. Thanks for the help.
Your BMW SULEV has a 15 year/150,000 mile no deductible warranty on the fuel pump that is embedded inside the fuel tank, which has to be replaced...it's a $6k+ part and part of the emission chain making it SULEV . As long as you perform service within a state that SULEV's were sold....you are good to go.
E46 SULEV has the M56 engine....the fuel filter and fuel pump reside in the fuel tank....if one fails, you have to replace the entire tank....
See diagram
Actually, this is where forums are at their best. Two heads are better than one, and 2 million are certainly better than one. You have to filter more information, but you're much more likely to find the correct answer somewhere.
I was unaware of any special warranties pertaining to SULEV vehicles that arent' available in my state.
That's just a normal fuel tank. What am I missing?
it's all in one tank, and yeah it's like 7000 $, but it's part of the emissions system and they should warranty it longer than the standard warranty
The term badge whores is not allowed on bimmerforums, because badge whores don't like it
The SULEV fuel tank is made of stainless steel and is completely sealed except for the hole you put the gas nozzle into to fill it up. So when you replace it, it's the tank, filler neck, pumps, level senders, the whole assembly in one piece. (I did some research just for you Screwdriver. Hope I made you proud)
Which oddly enough, has nothing to do with the car being an SULEV, but rather so that the vehicle can also carry a "Zero Evaporative Emissions" label in addition to the SULEV nomenclature.
look up the SULEV radiator......about $800. It eats smog as you drive.
you can replace the sulev radiator with a regular one
I dunno if anyone has tried that with the fuel tank
Learn something new everyday... would never have thought you had to replace the entire thing. You would think something like this would have been brought up numerous times before.
This and another E46 forum is where I first read about the SULEV fuel tank...just do a search for SULEV in the E46 section.
I own a CPO 2005 325i SULEV. Great car until I found out about the gas tank. When I took it to my indy, a 30 year BMW repair shop, he thought I was nuts when I told him about the tank. He called his contact at BMW NA and it was confirmed. The good part is the regular E46 tank and plumbing can be swapped in if needed. Parts and labor about $2,500....beats $8k for parts and labor. So with a 15yr/150,000 mile no deductible warranty and the option of swapping out the unit for a standard one after that...I can sleep soundly at night that I am also saving baby seals with my SULEV, since it has the pollution impact of a Toyota Prius.
Many thanks... I will add this to the oddities list so those that ask in the future can be better informed.
Yep, my mom bought an '03 325i SULEV last year. I haven't told her about the $6,000 fuel pump/tank assembly, mainly because as it's been said here...if it fails, it's under warranty.
It's pretty straightforward. There is a reason that fuel filters and pumps are replaceable separately on 95% of BMWs sold. That's the logical way to do it.
The M56 E46 was built for a special purpose; to be a SULEV & ultra-low EVAP emissions vehicle. This is why it's got a special fuel system.
