Results 1 to 25 of 41
Thread: M56 SULEV Motor Warranty
    Nov 2009
    Honolulu, HI
    325iT
    Please Help!!! The fuel pump on my 2004 325iT has gone out and i only have 20,000 miles on the car. I can't seem to find any info on the extended warranty on these SULEV vehicles. Can anyone point me in the right direction?
    Thanks, frogdogHI
    Holly, MI
    2005 325Xi
    E46 vehicles don't have an extended warranty on the fuel pumps like the E90s do, if that's what you mean. I'm not aware of the SULEVs having any other special warranties just because they're SULEVs either.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Quote Originally Posted by triggrhaapi View Post
    "Come see 'bout me" is a challenge to physical combat, not unlike "come at me, bro." The OP is just extra ghetto. You know how they have "extra crispy" at KFC? If you multiply that by watermelon and divide by grape soda, you get the OP.
    Feb 2001
    Fort Lauderdale, FL.
    2011 M3 Sedan
    No special warranty... after 5 years, you are on your own unless you have purchased an extended warranty through an aftermarket company or through your local bmw dealer.
    Your car is low mileage, but it is the time factor that got you, not the mileage.
    Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
    Nov 2009
    Honolulu, HI
    325iT
    Ouch! Seems i read somewhere that there was an extended warranty on all parts having to do with the low emissions. Shoots. Thanks for the help.
    Feb 2001
    2011 M3 Sedan
    Quote Originally Posted by frogdogHI View Post
    That would be the catalytic converters I suppose... those are warrantied for 8yr/80,000 miles.
    North Hollywood, CA
    E46
    Your BMW SULEV has a 15 year/150,000 mile no deductible warranty on the fuel pump that is embedded inside the fuel tank, which has to be replaced...it's a $6k+ part and part of the emission chain making it SULEV . As long as you perform service within a state that SULEV's were sold....you are good to go.
    Dec 2002
    auf dem Nürburgring
    535xi
    Quote Originally Posted by Screwdriver View Post
    Your BMW SULEV has a 15 year/150,000 mile no deductible warranty on the fuel pump that is embedded inside the fuel tank, which has to be replaced...it's a $6k+ part and part of the emission chain making it SULEV . As long as you perform service within a state that SULEV's were sold....you good to go.
    $6,000.
    The part is about $200 from a dealer, plus installation. I don't know what the dealers charge for it, but you just pull up the rear seat cushion and swap out the pumps. Shouldn't take longer than 30 minutes.
    North Hollywood, CA
    E46
    E46 SULEV has the M56 engine....the fuel filter and fuel pump reside in the fuel tank....if one fails, you have to replace the entire tank....
    See diagram
    Holly, MI
    2005 325Xi
    Actually, this is where forums are at their best. Two heads are better than one, and 2 million are certainly better than one. You have to filter more information, but you're much more likely to find the correct answer somewhere.
    I was unaware of any special warranties pertaining to SULEV vehicles that arent' available in my state.
    Dec 2002
    auf dem Nürburgring
    535xi
    That's just a normal fuel tank. What am I missing?
    Aug 2003
    georgia
    135i, R53 jcw, x5d, E39
    it's all in one tank, and yeah it's like 7000 $, but it's part of the emissions system and they should warranty it longer than the standard warranty
    The term badge whores is not allowed on bimmerforums, because badge whores don't like it
    Holly, MI
    2005 325Xi
    Quote Originally Posted by ss109 View Post
    The SULEV fuel tank is made of stainless steel and is completely sealed except for the hole you put the gas nozzle into to fill it up. So when you replace it, it's the tank, filler neck, pumps, level senders, the whole assembly in one piece. (I did some research just for you Screwdriver. Hope I made you proud)
    Which oddly enough, has nothing to do with the car being an SULEV, but rather so that the vehicle can also carry a "Zero Evaporative Emissions" label in addition to the SULEV nomenclature.
    North Hollywood, CA
    E46
    look up the SULEV radiator......about $800. It eats smog as you drive.
    Aug 2003
    georgia
    you can replace the sulev radiator with a regular one
    I dunno if anyone has tried that with the fuel tank
    Feb 2001
    2011 M3 Sedan
    Learn something new everyday... would never have thought you had to replace the entire thing. You would think something like this would have been brought up numerous times before.
    Aug 2003
    georgia
    Quote Originally Posted by Kevlar View Post
    it has been
    Feb 2001
    2011 M3 Sedan
    Quote Originally Posted by MrBlah View Post
    it has been
    Link to more information? This is the first I am hearing of it...
    North Hollywood, CA
    E46
    This and another E46 forum is where I first read about the SULEV fuel tank...just do a search for SULEV in the E46 section.
    I own a CPO 2005 325i SULEV. Great car until I found out about the gas tank. When I took it to my indy, a 30 year BMW repair shop, he thought I was nuts when I told him about the tank. He called his contact at BMW NA and it was confirmed. The good part is the regular E46 tank and plumbing can be swapped in if needed. Parts and labor about $2,500....beats $8k for parts and labor. So with a 15yr/150,000 mile no deductible warranty and the option of swapping out the unit for a standard one after that...I can sleep soundly at night that I am also saving baby seals with my SULEV, since it has the pollution impact of a Toyota Prius.
    Feb 2001
    2011 M3 Sedan
    Many thanks... I will add this to the oddities list so those that ask in the future can be better informed.
    Jun 2002
    San Diego, Cali
    A Few With Roundels
    Yep, my mom bought an '03 325i SULEV last year. I haven't told her about the $6,000 fuel pump/tank assembly, mainly because as it's been said here...if it fails, it's under warranty.
    Dec 2002
    auf dem Nürburgring
    535xi
    Me too.
    This is interesting. You would think that BMW would have foreseen the consequences of not even having a replaceable fuel filter, let alone fuel pump.
    North Hollywood, CA
    E46
    Me too.
    BMW....amazing cars built by people on meds......
    Jun 2002
    San Diego, Cali
    A Few With Roundels
    Me too.
    It's pretty straightforward. There is a reason that fuel filters and pumps are replaceable separately on 95% of BMWs sold. That's the logical way to do it.
    The M56 E46 was built for a special purpose; to be a SULEV & ultra-low EVAP emissions vehicle. This is why it's got a special fuel system.
    Atlanta, GA
    '11 328xiT/6, '99 M3
    Quote Originally Posted by Critter7r View Post
    Spot-on. Mike Miller had a letter about a failed SULEV tank in his Tech Talk maybe six months back. He said that they are becoming real headaches with lots of related problems.
    -Denton
    Nov 2009
    Los Angeles
    2004 BMW 325i
    ....I can sleep soundly at night that I am also saving baby seals with my SULEV, since it has the pollution impact of a Toyota Prius.
    Hahahahah classic. I am very grateful for your post. I also have a 2004 325i SULEV with 75k miles on it and while everything is tip top right now, I was worried about the fuel pump going out down the line and if the retrofit was possible. thank you
