Page 3 of 3 FirstFirst 123
Results 51 to 62 of 62
Thread: What modifications to make E21 transmission mounts fit on an E36?
  1. #51
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    Cuz forums?
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
  2. #52
    Jul 2003
    I dunno
    '90 Ford Tempo
    Opinions. Some are moderate, and some are strong.
    The pro Urethane guys make a stronger point 2 years on, as the E21 mounts now cost about the same as the poly.
    The argument about reverse ability was incorrect, as only the holes in the brace needed to be enlarged....Nothing else.
    m
  3. #53
    Sep 2004
    new york
    01 540i, 88 carrera 3.2
    Just can't believe people are getting flamed for upgrading parts by modifying and swapping with factory parts. What's next. Am I gonna get offed for doing a m50 intake instead of a $1000 shrick manifold?
    If your not pinging you not running enough boost.
    Current cars : 03 Saab 95 aero , 97 M3/4/5
    retired : 88 carerra coupe 3.2 , e30 m52 Vert, boosted e34 535i, e39 540i sport, r53 cooper s......
  4. #54
    Nov 2009
    Riverside, CA
    97 M
    Didn't want to start a new thread - what year e21 (or part #) are these mounts from?
    "Gratitude is the open door to abundance"
  5. #55
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Quote Originally Posted by andrewtp View Post
    https://www.bimmerforums.com/forum/s...0#post18234410
    88M3 AW 43k miles Project FS
  6. #56
    Nov 2009
    Riverside, CA
    97 M
    The bmw genuine mounts under that part # run like $50 almost everywhere, but uro brand only 8$- anybody using these?
  7. #57
    Dec 2013
    MA
    There were two different part numbers for the E21 mounts for some reason. I went with 23711109173. Honestly I don't think it made a difference between fresh OEM mounts and the E21s. The E21 mounts may last a little longer.
  8. #58
    Jan 2002
    Central Pacific
    I've heard very few compelling endorsements of the URO brand.
  9. #59
    Nov 2009
    Riverside, CA
    97 M
    Quote Originally Posted by hli View Post
    I noticed that too, I’ll probably just get the the stock ones if there is little difference between stock.
    and yes I’ve also not heard good things about Uro but i thought i would ask anyway.
  10. #60
    Jul 2004
    Lake Havasu, AZ
    2013 Ferrari F138
    I see the attractiveness to installing 320 mounts because its an OE part,
    but due to having to modify the original transmission bracket I highly recommend UUC black mounts,
    since once drilled out you won't be able to go back. Don't use the cups, not a big deal if fitment is an issue, still better than stock.
    Tried URO things a few times, with horrid results. Their rubber and plastic does not hold up long.
  11. #61
    Mar 2006
    SF Bay Area, California
    edirtysex
    If we want to be really exact, drilling out larger hole through "support beam" aka cross member and then stuffing stiffer than OE bushing is ass backwards way of doing things. Not only do you weaken the support by making holes larger, but now on top of it you install a stiffer bushing so the support is made even weaker. If anything just install a stiffer bushing but leave the crossmember alone if you want to have tighter box
    '95 M3 cosmos, sold
    '96 M3 boston gree, sold
    '00 M5 jet black, sold
    '01 M3 Ti Silver, sold
    '07 335i jet black, sold
    '00 M5 Silver, sold
    '03 M5 Carbon sold
    '02 M5 Carbon black, sold
    '97 M3, white, sold
    '02 M5 Sterling gray, sold
    '03 530xi wagon, sold
    '91 M5 black, sold
    '99 M3 cosmos, sold
    '11 335i, gray, sold
    '09 M3 silverstone, sold
    '02 330i, sold
    '02 M3, steel gray, sold
    '02 325xi, BSM, sold
    '09 335, Montego, sold
    '97 M3, dakar II, current
    '97 M3 estoril
  12. #62
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by malter View Post
    1 - The E21 mounts have larger bolts, so the cross member has to be drilled out. The transmission points can be left alone.
    B - The OE E21 mounts are rubber and not any stiffer than the original mounts. Hardly any difference in load that the cross member sees. People often run solid metal bushings here without an issue.
    III - This thread is suuuuper old.
