What exactly is the difference between the turbos we are familiar with. And the reverse rotation ones. I know that they rotate anti clockwise. But why? whats the use?.. and I've been reading on some forums, that If a car is using a reverse rotation turbo, and want to upgrade to a clockwise rotating turbo, lots of modifications should be done, and its a little hard. why is that?.. Any info, pix, links!!
You know how when you are below the southern hemisphere, the toliet water rotates in the opposite direction than if you were in the norther hemisphere. I think its like that.
There are applications like a v8 where you'd be running a twin turbo setup, one on each bank. If you want symmetry between banks you'd need a reverse rotation turbo.
Go ahead and bite. Plenty for everyone.
its just a matter of packaging.
Two reasons: geometry to fit space constraints, or symmetrical twin turbo setups. Either way it is geometric or aesthetic. I have read of no performance differences. They just cast the housings in mirror images and cut/cast the wheels to correspond.
There is another reason besides packaging, someone mentioned why an oem would pick a counter rotating turbo as opposed to a std. Flow path (Fluid dynamics) are affected by the port entry and path geometry. So in a perfect world, you would have a single spiral arc starting from the center of the cylinder, and rotating (Counter clockwise) out the exhaust port and ending on the turbine blade. This will reduce turbo lag in most cases.
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
