When I bought my e39, the driver's side headlight adjuster was broken. So for three years I have used five, eleven inch zip ties available here:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
http://alliedlocksafe.com/shop/index...469#googlebase
I was blind at night as my driver's side headlight was aiming straight down, perhaps just a few feet in front of my own bumper.
Triangles.
Most sturdy structures.
Using a high tech formula of triangulation and 5, 11" zip ties, my driver's side headlight is spot on.
I used them and then, BEFORE I made my final calculations, aka pulling on the zip ties to dial-in the headlight's aim, I drove to a brick wall at night with:
1). Flashlight
2). Chalk or masking tape
3). Tape measure
There is a procedure and if adhered to, you can tug/pull aka shorten ZIP TIE NUMBERS 1 AND 2 in order to have the lamp properly aimed both vertically and horizontally (see photos attached below).
1). Zip Tie # 1 is key and should be first. It goes under the intake tube and uses a metal bracket behind/under the fresh air intake. Leave it long, but zip it together to make a loop.
2). Zip Ties # 4 and 5 are next. Criss-cross them around each other on the fresh air intake tube. Make them snug, but leave them loose enough that your finger could slide under them.
3). Zip Tie # 2 slides under Zip Tie # 4. Leave # 2 long, but zip it.
4). Zip Tie # 4 and 5 are now tightened very tightly.
5). Zip Tie # 3 loops around the base of the bulb's housing and loops through Zip Ties # 1 and 2.
Drive to wall at night, adhere to BMW headlight specs above and snug down/tighten zip tie numbers 1,2 and 3 accordingly.
Cost is $2.00
Time is 15 minutes
DIY scale of 1-10...this is a ZERO.
Longevity? Mine work for 3 years in a row.
There is enough attachment areas on the passenger side to do the same. I do not have to as my passenger side is fine.
I would prefer buying real adjusters from EAC Tuning and will do so in the future. Still, I need better lamps overall as my bulbs (H7) are weak...
Good luck
gettho me like it
96 318is Sport --sold
96 528ia Premium Comfort seats --sold
98 528ia euro sport pack BR41880-- sold
01 530ia Premium CE52247
02 540ia Individual GG91507
This is high-tech stuff xisco. I am using German-made zip ties.
NOTE: To those in Panama etc who think, "I can do better. I can do this with 4 zip ties" understand that zip ties 4 and 5 need to be there. You can't have just one of them and eliminate # 5. The #5 zip tie keeps it all together and prevents the zip tie assembly from sliding around.
So xisco, don't ghetto-up this process!
1). Zip tie # 2 makes the vertical adjustment.
2). Playing with # 1, 2 and mainly 3 make the horizontal adjustment.
i have the duct tape and epoxy method is a little more permanent thou
so if your bulb dies there is no replacing it
I don't know why, but I think Xisco may really love this DIY................![]()
E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
PANAMA, CIUDAD DE PANAMA
i dont celebrate halloween thats the devils fest
send me a pm with the how much
LOL!
Good stuff!
way better than paying 100 + to fix adjuster
Should this go in the DIY section? Hmmm.
Thanks for sharing this, Keith.
May someone explain how to do this a little more clear please as my headlights are in dire need of adjustment?
You own a 540 and under it's hood isn't something I look at/own. Oh I dream of v8 engines, Jennifer Connelly, Joanna Krupa (worth google-imaging fyi) egg rolls with duck sauce and winning the Tour de France,but it's something I don't own. Specifically, the area around your headlights might very well be different than my own. So let's do this...gaze deeply at the photos above, grab some zip ties and make it happen.
Also, aside, it would be, "May someone explain how to do this a little more clearly."And it'd sound even better with, "May someone explain more clearly how to do this..."
My friend, a bunch of wildcat pilots flew to the moon in a can of tuna with some rocket boosters and a ham radio. You can do this. Necessity is the mother of invention. Watch The Right Stuff (when you have 4.5 free hours as it's epic in length) order some zip ties and I have faith in ye. Since the Red Sox suck, you can always drive down to NY for a game and we can fix your headlights in the Bronx.![]()
You're new here. At least attempt a shot at wit before your mouth exposes the lack of keenness. You're asking to have zip-tie-solutions prepared for you a). more clearly b). when the thread clearly states it's not for a 540 only I6 engine bays and c). all you truly need to do is grap some zip ties while making an attempt to fix your own headlights where d). golly gee you can then post about it and contribute to the forum.
Fix your headlights. Spend time using the most important tool, the brain, combined with a few, cheesy zip ties and I imagine you might be able to help yourself.
This is for the passenger's side. 1997 528i with Hella AAs.
It's even cheaper because I only had to use 2 zip ties, and made in the US, not German
Resident Third World Country Advisor
Thanks for this DIY! I was trying to figure out a way to ghetto rig it myself. My wifes car has both messed up and I read up on replacing the adjusters...way too much work. I need to get some zip ties. Right now I have both lights rigged up with some extra long twisties that came off a hose I just bought. Man, I was about to buy her new headlights!!
1997 528i: My intro to Bimmers
'99 ///M3: I.LOVE.THIS.CAR. - SOLD... why did I do that?
2002 325xi Wagon - SOLD
2004 325xi Wagon - New Wagon, Same Old Issues
do you sell these in a kit?
Thanks for the DIY.
I've been using mini-bungie chords which lose their tension after about 6 months.
Not a firearms expert
