Page 4 of 22 FirstFirst 1234567891011121314 ... LastLast
Results 76 to 100 of 543
Thread: How to use CarSoft cable with INPA and DIS
  1. #76
    Jun 2008
    Denver CO
    96 328i, 07 E91 328xi
    What is the exact error you are getting? Try setting both the send and receive FIFO buffers to 8 under the com port settings for Com1 (also make certain you are using Com1).
  2. #77
    the Netherlands
    E38 728i sixstraight
    carsoft nterface on inpa
    i am running vista and use the interface with an usb-serial adapter
    and on com setting i can't find anywhere the fifo settings
  3. #78
    Jun 2008
    Denver CO
    press the advanced button on the port settings tab.
  4. #79
    Feb 2010
    france
    330d e46
    Hi, and thank you for all thoose excellent informations !!!!
    Sorry for my bad english, i am french.
    I've got a ELM327 connexion
    Is it possible to use DIS with this cable ? Or i have to purchase carsoft cable ?
    Thank you !!!!
  5. #80
    Randolph NJ/Harrisburg PA
    1999 Ford Explorer Sport
    As far as I know, no one has reported success using an ELM type interface with any BMW software.
  6. #81
    USA
    (OO=[][]=OO)
    And it is better to get VAG KKL cable.
  7. #82
    the Netherlands
    carsoft interface on inpa
    hi there again
    i was looking for the fifo setting but i cant find them anywhere
    i made a screenshot of the edvanced setting
    please help i can't find it
  8. #83
    Feb 2010
    france
    330d e46
    Ok, what is the better solution to use DIS ? KKL VAG cable or Carsoft cable ?
    And those cables ahve to be modified or it is not necessary ?
  9. #84
    USA
    (OO=[][]=OO)
    CarSoft cable you need to run CarSoft each time you use it then use DIS, etc. VAG KKL cable that is not needed, but you will need to modify it.
  10. #85
    Feb 2010
    france
    330d e46
    Ok, i understand.
    VAG KKL and Carsoft cables give the same level of access/informations to the module ?
  11. #86
    IcemanBHE's Avatar
    IcemanBHE is offline ¿pǝpɹɐʇǝɹ noʎ ǝɹɐ
    Wichita,KS/FortCollins,CO
    (4x7)+8=36
    I cant verify the VAG performance, but the Carsoft setup works for read, clear, and code funtionality.
    VAG will be my next mod to try.
  12. #87
    Feb 2010
    france
    330d e46
    Ok, thanks for your work !
  13. #88
    IcemanBHE's Avatar
    (4x7)+8=36
    Of note....
    Carsoft interface confuses INPA with battery voltage being ZERO, but works fine, same with DIS, and 100% correct with SSS/Progman.
    Its not really a problem, but this is why Im going to try VAG next. Just to see the differences....
  14. #89
    USA
    (OO=[][]=OO)
    The VAG KKL cable and be properly modified for the voltage. Some obscure test modules in DIS I think might need it. Also you can do auto vehicle ID and that is the main reason.
  15. #90
    Mar 2010
    Singapore
    Hi Randomy
    Quote Originally Posted by randomy View Post
    Try typing "INIT 6" (without the quotes)
    Hi Randomy;
    Can you help me on setting up a FULL laptop with all the Tools needed.
    Example : INPA, DIS etc...
    Mar 2010
    San Diego, CA
    2002 m3
    No, I'm also getting an error
    ______________________________
    BMW HID Kits
  17. #92
    Chicago South IL
    2003 530i Sport
    hey guys
    my mouse stuck in VMware on a first Language page for Easy DIS ... memory issue ?
    i did all according to video ...
  18. #93
    USA
    (OO=[][]=OO)
    Do you click the mouse and then move it a little? Did you try press Ctrl + Alt to release the mouse from VMware then click to lock it again?
  19. #94
    Chicago South IL
    2003 530i Sport
    ya i tried all Cntl Alt - Cntr G
    if it pass this step it stuck on another step ...
    I have 512 Operation and 20Gb virtual memory assigned as per Video .. do i need to change operation to 1024 ??
    my laptop is Lenovo T61 2Gb RAM
    last update :
    after reinstall with VMware v7 on 1024 memory issue resolved
    Last edited by champaign777; 03-09-2010 at 01:16 PM. Reason: Automerged Doublepost
  20. #95
    Feb 2010
    france
    330d e46
    Hi,
    I have receive my carsoft cables.
    Carsoft is ok but after I install INPA, it do not want to launch because "API.DLL is missing".
    In the directory C:\INPA\BIN , there is not de api.dll and api32.dll !
    I have copied the api.dll and api32.dll of the C:\EDABIAS\BIN dirfectory in C:\INPA\BIN directory but it doesn't work (error 135 api.dll).
    Could someone send me api.dll and api32.dll of INPA by mail ? @ patmolinat@gmail.com
    Thank you very much in advance for your help !
    I have installed another version of INPA/EDIABAS and now, it works for all cars without E46 !! And my car is an E46. Can anyone send me the PRG files (in directiry EDIABAS\ECU) for E46 ?
  21. #96
    Jun 2008
    Denver CO
    You need to setup your environmental variable PATH to include the folder "C:\EDABIAS\BIN"
  22. #97
    Feb 2010
    france
    330d e46
    I done that but it doesn't work.
    I have installed another version of INPA and it runs good. But in the liste en cars, i don't have E46 (F3) ...
    But on the E83 there is the same DDE that mine (moto M47 New). So when i choose E83, i have an error message :
    ifh-0003 DATATRANSMISSION TO INTERFACE DISTURBED
    I had done all configurations same that explained on the 1st page ... help !!!
  23. #98
    Jun 2008
    Denver CO
    Quote Originally Posted by kaokao77 View Post
    then you done it wrong
  24. #99
    The Netherlands
    '06 e61 535dA Touring
    Hi,
    I could use some help. I have a carsoft adapter which I got to work fine. Problem is with INPA I am missing the ODBSetup.exe. Anyone who can help?
    By the way: I have carsoft running fine on a Mac using Parallels
    Best,
    Liam (04 e61 530dA)
  25. #100
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    Liam,
    You will find the file in c:/EDIABAS/Hardware/OBD . If you don't have it, PM me with your email address and I will send it to you.
