I have manage all software to work, and the api test works now, i haven't been able to test it in my car, because the car its in the mechanic and i found some issues, i couldnt find the lambda sensor, and after i switch the gasket from the valve, but now it just smokes a lot, i really want to put this working in order to see the errors from the car, thanks from your answer, i know that my car works only in ads, so i set all things to ads, but in dis, i only made the test successfully, by changing the translate to fisten.
yes i have, here it is....
http://cgi.ebay.com/ebaymotors/ws/eB...m=160499165761
I had a bad installation of the carsoft, i fixed it, but now i will test it soon, and let you guys know how it was.
Were you able to resolve the conflict with the 192.168.68.0 and the netmask of 255.255.255.0? I get the same complaint when trying to set these values in the TCP/IP properties tab of the VMnet1 (VMware Network Adapter). I set the IP to 192.168.68.1 and it seemed to work, at least on one of my cars (530i, an E34). The same setup with only the OBD cable changed (from round type under hood to rectangular type under dash) does not work with my X5 (E53). I seem to connect and all based on API test, but can't read any modules. Not sure, but was thinking that I may have created an IP conflict with the diag unit, which is a carsoft setup. Does anyone have any advice regarding the allocation of IP addresses?
maybe you have to change under the ediabas.ini the type of adaptor, and the ipconflict, i solved by restarting my pc, and antivirus and firewall disconnected. The api test also ok, after uninstall the network cards into gt1, and installed the first one that appear to install to my computer, and didnt made any changes to the other setting that its there in network, but, i cant connect to my car still!!! in theory all its working... i think i may have a bad com, but this week i tried with a real machine from a professional, and in the beginning it was giving an error on the dme, saying it was damage but dont know how he fixed it, later on he could access all sort of data, unfortunately he could not erase my dashboard errors, don't know why he couldn't do do it will try another time to conect.
Thanks for the info guys. I've gone through this entire thread but can't seem to get my setup working. Problem is, I have an E90 on which I replaced the switch column. Now the Steering Angle Sensor needs to be initialized, but of course the module has to be coded. I have the yellow GT1 and the orange OPS head and they work well for all the diagnostics, car and key memory settings etc I've done so far. But for this particular situation Progman keeps making up a measures plan before it can code the switch cluster that involves replacing the IHKA unit as it's not the right part number according to Progman. a) Can I get around this problem with Ediabas, INPA and NCS? b) How do I get the yellow or orange diag head to work with Ediabas etc.?
Thanks in advance...
Alison Moyet said it best: "Is this love!"
1995 850CSI RHD, Active Rear Kinematics, 94k miles.
Im not the best person to answer you, but ediadas its a program, and the dighead, ip, that we have to put into gt1, its an alternative to your expensive hardware, so since you have the right hardware, try first to contact some one that sells and works a lot with that, if that didnt worked, i think you should search a little more, because i have seen some answers, dont know where, that shows how to work with the NCS you must search the link to a shared folder that as the instruction and documentation...
Just to clarify
for a 99 E39 i should install INPA with the ODB option even though i am to use the ADS connector?
If you are installing INPA and/or DIS v44 and intend to use an ADS interface, you should set "Interface = ADS" in Ediabas.ini. This will be done automatically if during the installation of INPA you choose ADS as your interface type.
If your interface is a switchable ADS/OBD type, when you switch to OBD you will need to restart INPA after modifying the "Interface = ***" line in Ediabas.ini to "Interface = STD:OBD" and running the OBD setup file in c:\\Ediabas\Hardware\OBD.
There is no ADS connector. There is either the BMW 20-pin connector, or the OBDII standard compliant connector, or both. You should use the 20-pin if there is one.
As for interfaces (the piece between the computer and the car connector), the most common are OBD and ADS. If you have an OBD interface, set INPA to OBD. If you have the ADS interface, INPA can function in both modes, but it can do more in the ADS mode.
I've done this over and over.I'm using a Carsoft West adapter and OBD2. It works fine with Carsoft. It seems to stop with INPA. I installed exactly as directed onXP. After I run Carsoft I run INPA as directed in the instructions. That is where it ends, it comes up with a communications error. As a fact I cannot run Carsoft afterwards without a complete disconnect and restart?
Looking for suggestions or experience. Thanks.
What is the name of this interface and where is it obtained? Thanks
I have an OBD2 reader that has an interface. Think I will try that with INPA.
Try something like this http://cgi.ebay.com/ebaymotors/NEW-E...motiveQ5fTools a normal OBD2 reader won't work with INPA.
Some machines are really picky about Carsoft interface retaining some system settings and not releasing them for when your trying to use INPA. Usually its easier to just get a different interface.
Well, 2 new serial adapters and the ebay INPA interface on their way.
Anybody have an average shipping time for the interface coming from China?
Update:
Acquired a Dell D630 with a native serial port.
Ran Carsoft DME diag, closed it, tried INPA, no go.
Ran again, kept it open ran INPA and found success.
So yeah as noted, very finicky.
Hello.I bought a laptop with native serial port and an ads interface on serial.I tested it on inpa 6.4.3 and I can acces all modules except dme 1.7.It says sys-0012:identification error.The car I tested is a 93' e36 bmw 318is.
Any suggestion?
you shouldn't have buy the inpa on ebay, i have one... couldnt conect it for months..., but good luck... there are many solution from members that belong to this forum, its a bit more expensive, i really need one of those but i already spend on this one i have, so im waiting... time $$$, and that i have patience enough to start all over again....
You can read the DME using Tool set 32 from the INPA program set. The SGBD file to load is DM172K20 for the DME in the M42, DM173K20 for the M43 or DM524S0 for the M44.
Thanx.After i load dm17k20 in tool set 32 what should I do next?Is toolset 32 the only way to acces dme in inpa because the menu is in german and are many codes there(jobs)?Will it acces engine in dis/gt1?
I have not tested it, but have been told that you can access the DME using DIS/GT1. Change the language of your Toolset 32 to English (by selecting the Toolset 32 option from the Konfiguration menu and ticking the Englisch version box.
Hello
I seek hopelessly a version of DIS in French.
Excuse me for my bad English
Thank you in advance
What Error compiling script file means? I got INPA connected to my car when I switch on ignition key. but not able to do anything!What does that message mean???
From the list of programs choose INPA(_.IPO) as the one you want to run, not INPA(_.IPS)
