Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
Thread: Foam Carbon Fiber Wing...DIY
  1. #26
    Lexington, Ky
    1995 BMW M3, 1973 MGB GT
    Hey OP thanks for stealing my Thunder!!!
    This is fantastic! Beautiful work sir, I am very impressed unfortunately I haven't even tested mine yet I am glad it worked and I am going to copy you and make some similar end plates for my wing at the instruction of some other bf.c members!
    DIY Wings FTW, if I make it down to ATL anytime soon I would love to see it in person!!
    -Ian
    for those of you who haven't seen it, here is my thread
    http://forums.bimmerforums.com/forum....php?t=1249500
    OPs design is much more practical than mine, prettier too!
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
  2. #27
    Sep 2001
    EC
    cars
    Nice,Finish look great! Did you test to see how well it does under load? Sometimes the foam core only wings fail pretty quickly under higher speeds/loads.
  3. #28
    Mar 2006
    Monrovia, CA
    E36
    Bravo!!! Excellent work and DIY.
    The difference between 'involvement' and 'commitment' is like an eggs-and-ham breakfast: the chicken was 'involved' - the pig was 'committed'.
  4. #29
    Nov 2005
    Alpharetta, GA
    '95 M3 IP #595, '07 Z4MC
    Quote Originally Posted by clopez95m3 View Post
    Two questions. I stitch welded my uprights. I figured this was a good idea to relieve some of the stresses in the joint. My welding instructor suggested it to reduce warping but with 1/4 aluminum that wasn't my concern. Thoughts? Any concerns that it may crack due to vibrations?
    2nd, size of the end plates. Those bad boys are huge. Thought about experimenting with end plate size? I'm going to guess it was the easiest part to fabricate (flat sheets).
    Sorry, I can't speak for the welds. I'm not a welder which is why I took it to Robinson Racing for that part of the build. To avoid warping, the welder did do sections at a time.
    As for the end plates, I saw a thread a while back suggesting that larger end plates improve the "lift" characteristics of the airfoil up to a point, then they just add drag. The reason you want them to extend below the wing and not above is that this prevents air from coming in from the side to fill the vacuum created by the airfoil on the underside of the wing. You want the vacuum to pull the wing down. Without end plates working like a dam, the air would rush in and negate the effect of the low pressure area under the wing, at least at the ends of the wing, but this is where you have the cleanest airflow. As I stated, I was quite surprised to see how effective the end plates were, as they were getting sucked inward as my speed increased. I don't see this as a problem, but may try a thicker sheet of aluminum. And yes these are very easy to fabricate. I just started with a couple of 12"x12" pieces and cut off a corner. Sometimes simple solutions are best.
    Quote Originally Posted by Steve J. View Post
    This was a one-off garage job, so no testing. However, with three plys of carbon fiber I doubt this wing will break. It's very stout.
  5. #30
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Great looking wing!
    One recommendation, it's hard to tell, but it doesn't look like the rivets you used are the captive pin variety(not sure of the "official name"). In my experience, with heavy vibration and loading(like you'd see in a wing), they'll eventually loosen up and then things start to get ugly. Yes, they can have a high loading capacity when new, but without the pin in there they are not happy when cycled many many times.
    Captive pin rivets from CherryQ or the like are almost indestructable from a fatigue/deformation standpoint. Would be a shame to see those rivets potentially fail from vibration on track, so just a suggestion.
  6. #31
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    I like the step of using the car as the oven.
    Me too! That was truly ingenious.
    Neil
  7. #32
    Feb 2009
    Sterling, Virginia
    99 M3, 92 civic
    love your ingenuity. excellent work.
  8. #33
    Savannah, GA
    SpecE30, Mini Cooper JCW
    WTG Michael, that's really nice work.
    See you in a couple weeks at Oktoberfest.
    And start scheming now on how you are going to get a Lemons car for next Spring. It's the most fun that can be had racing.
  9. #34
    Jun 2005
    Charlotte
    e46 M3
    Michael - I always look forward to seeing your car and the great work you do on it. Thanks for the write up and can't wait to see this in person!
  10. #35
    L.I., NY
    IP#145, 11 E92, 2500 HD
    Vey Impressive, nice job. Did you make the dive planes as well?
  11. #36
    Nov 2005
    Alpharetta, GA
    Yes, I'm still kind of experimenting with those. They seemed to work fine, but I'll probably fab up a fence on the outside edge.
  12. #37
    Sep 2001
    EC
    cars
    Cool. Another suggestion is to put some strakes on the sides of the diveplanes to help keep air from spilling over the egde. You can also go a bit more vertical on the trailing edge.
  13. #38
    Def's Avatar
    Aug 2002
    SW22, Volt
    I'd probably cut back that triangulating support to at least allow air to try to stay attached over more of the surface. It's also going to generate lift by stagnating any air flowing underneath the dive plane.
  14. #39
    Jun 2001
    No. VA (Police state)
    '95 M3, '94 325is
    you are awesome!!!
    David Ortiz
  15. #40
    SIN CITY
    MANY TO LIST
    I believe this is the most useful thread I've seen in a very loooong time.
    Excellent work, so detailed, with pics and tips.
    You should write a book " CF Wing making for Dummies".
    Road racing addict.
    Juker008 don't send pm soliciting or advertising, against forum rules!!
  16. #41
    Jan 2006
    Charlotte, NC
    Too many...or...NOT
    Mike - Good to catch up a bit at O'fest....sweet wing man!!
    Nitin G. Shanbhag
    BMWCCA #101510
    87 951, 88 M3 2.5, 88 E30 S52 Project, 95 M3/2 Slicktop, 96 E36 "TrackBeater", 97 M3/4 Slicktop, 97 TJ, 98 M3/4 Daily, 00 F150 7700
    E36 TrackBeater Project Thread: http://forums.bimmerforums.com/forum...d.php?t=884145
  17. #42
    Jun 2005
    Nor^Cal
    95 Avus Blue M3///96 Boston Green 328i
    Looks great! I bet that foam was a major PITA!
    ----Dave----
  18. #43
    Dec 2003
    Bay Area, CA
    1995 M3
    Very cool, exactly the way i made my first efforts. Based on your specs, I think your setup should be plenty strong with that foam and that amount of carbon and resin, albeit a bit heavy, but plenty strong. Great finish you managed with wet sanding - almost looks as good as a mylar/vacuum bag finish. If you ever build another one give me a shout and I have an idea or two i can share.
    Brooks
  19. #44
    phoenix az
    1995 F150 5.8L
    rivets through the carbon
    I'm currently working on a very similar build. Could you please explain how you used the aluminum plates on the foam? Did you drill through the carbon after it was fully cured? What was your entire process for mounting?
    -Thanks guys
  20. #45
    Nov 2005
    Alpharetta, GA
    Quote Originally Posted by fordman95 View Post
    -Thanks guys
    Essentially, you end up with aluminum plate sandwiching the carbon fiber. As you can see from the pictures, base plates are epoxied to the foam, but this really only holds these in place. The carbon fiber laid over them is what creates the strength in these mounts. The outside mounts are riveted to these plates through the carbon fiber. Yes, you drill through the carbon fiber after you test fit and ensure placement. The only thing I would do differently would be to use thicker material on the vertical plate that runs down along the stanchions. This would probably be a little more stout.
  21. #46
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Wow you did a great job!!
    I could make all the aluminum stuff at my work really easy. Have you ever thought about an aluminum diffuser? I want to make one.
    Where is the seam of the carbon? At the sharp edge of the wing?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  22. #47
    Nov 2005
    Alpharetta, GA
    Quote Originally Posted by 3literheater View Post
    Hiding the seam is a trade secret...
    I planned the layers to overlap and then had the last layer end at the trailing edge (the sharp edge of the wing). The trick is to trim it close before it sets up and then smooth it down. You couldn't find if you looked at the wing.
    Oh, and as an update, I've run the wing at Road Atlanta and twice at CMP and it's worked great. Even had Mike Skeen drive the car Friday at CMP and he complimented me on the cars' aero. He was turning 143's and I've just got a little old stock cammed S50.
  23. #48
    San Diego, CA
    05 M3, 87 325is, 01 740i
    Quote Originally Posted by Michael9218 View Post
    Having mis-spent my youth as a beach rat in Encinitas, CA building skateboards and surfboards, I figured it couldn’t be too difficult. So the research began (it’s nice having free time with kids in college).
    Congrats from a current "Encinitan" for a job well-done!
  24. #49
    South Bend, IN
    '95 M3/'98 328ic
    Very cool project! Wish I had the patience to do the same!
    -Zach
    2013 NASA Midwest Time Trials "B" Champion and Rookie of the Year
    EFFEKTIV Motorsport #188 TTB - E-fab / Motorsport Hardware / NOS Energy Drink
    Visit us @ https://www.facebook.com/EffektivMotorsport
  25. #50
    Dec 2008
    Rosnotreallywell, GA
    Several E30s
    So after a few years, is the wing holding up well?
    Bitsy: 1987 325i 4dr specE30
    Blue (aka Sapphire): 1989 325i 4dr
    Rosie: 1991 318is 5sp
    Goldi: 1990 325i vert; best $450 ever spent
