Results 1 to 25 of 35
Thread: Open and LSD Limited Slip Differentials diffs
    Michigan
    2005 BMW 330I ZHP
    I have one of each of the following differentials:
    These are all OEM items.
    Limited Slip
    E28 3.46 LSD
    E23 3.46 LSD
    E24 3.91 LSD
    Open
    E30 4.10 Open
    E46 non-M3 2.93 Open
    $500 each + shipping (about $100)
    Feel free to make an offer if something is over priced.
    *****UPDATE******
    I now have:
    an E46 M3 Limited Slip unit (this is just the guts that go inside the diff housing / carrier)
    a factory E46 M3 Ring and pinion for sale
    Factory output flanges from the E46 M3: SOLD!!
    Stock E30 3.73 LSD units from an 86-91 e30 325i/is standard shift and up to 9/88 automatics
    --These can be used in E30, E23, E24, and E28 with different stud axles and rear cover.
    This is the E23 3.46 LSD
    Michigan
    2005 BMW 330I ZHP
    Feel free to make an offer.
    Michigan
    2005 BMW 330I ZHP
    Prices are flexable
    Michigan
    2005 BMW 330I ZHP
    bump
    Michigan
    2005 BMW 330I ZHP
    Atlanta GA
    97 S54,94 M-Technic,SE36
    I have a mint condition 3.23 diff for e36s if anyone needs.
    Good luck on the sale of these rare diffs!!! GREAT PRICES TOO!!!!
    May 2010
    Acton, MA
    1991 318is
    Is the e28 3.46 lsd still for sale?
    Is the E28 3.46 LSD still for sale?
    Last edited by gapatterson10; 11-30-2010 at 12:03 AM. Reason: Automerged Doublepost
    Michigan
    2005 BMW 330I ZHP
    Quote Originally Posted by gapatterson10 View Post
    Yes, I still have that diff available.
    Let me know
    jp
    May 2010
    Acton, MA
    1991 318is
    If you SURE its a lsd I am deffenetly intrested. Its very important to me that it is. You wouldn't happen to know the part number? Im kind of new on this forum and am not sure how to send you a PM. So if you could e mail me at pattersongrant@rocketmail.com I would appreciate it. Thanks
    Michigan
    2005 BMW 330I ZHP
    I sent you an e-mail.
    JP
    Michigan
    2005 BMW 330I ZHP
    bump....
    Jul 2011
    Ma/Nh
    95 325is m52 obd1 swap
    This may be a long shot but is the e28 dif still here?
    Michigan
    2005 BMW 330I ZHP
    Quote Originally Posted by Matt325e View Post
    Yes, it is.
    JP
    Toronto
    Black MCS
    hi there,
    Interested in the 3.73 LSD (E30)
    is it direct bolt onto 1998 M roadster? i read from forum that i might need to change the drive shaft flanges to fit e30 to z3.
    But doesn't M roadster has different rear axis than normal z3?
    thanks
    Michigan
    2005 BMW 330I ZHP
    Quote Originally Posted by wuj15 View Post
    hi there,
    thanks
    to make that E30 3.73 L/S diff fit the M roadster, you would use your roadster output flanges and rear diff cover.
    jp
    Sep 2002
    Nashville, TN
    E53, E30/M50, E90, 2002
    Interested in a 3.46 if you still have one. What is the difference between the E28 and E23 versions? Thanks-
    E53 X5
    E30/S52
    E90 325i
    Michigan
    2005 BMW 330I ZHP
    Quote Originally Posted by RenaissanceMan View Post
    I believe the main diferences are in the output flanges and the diff cover.
    What model car are you running? Trans, year, etc...
    Are you looking for an open diff or Limited slip?
    jp
    Sep 2002
    Nashville, TN
    Quote Originally Posted by jpjp View Post
    jp
    EDIT: had the wrong tranny info- It's an E30 racecar with M50 conversion. I'm currently running an E30 3.25 lsd. Trans I believe is an E34 ZF, and driveshaft is E30 M3. I need a limited slip that is operating properly, as this car is only run on the track. Thanks!
    E53 X5
    E30/S52
    E90 325i
    Michigan
    2005 BMW 330I ZHP
    I should have an answer for you by Monday when he guys gets back from Mid-Ohio.
    JP
    Michigan
    2005 BMW 330I ZHP
    I have a 3.46 a 3.73 and a 3.91( stock L/S) .
    If the car has an overdrive 5th gear I would run the 3.91
    An e36 M3 or 325 gearbox will have a 1 to1 5th gear and the 3.46 would be used.
    Some things to think about:....
    How light is the car?
    How much horsepower is the engine?
    Turbo or supercharged?
    Will the car pull redline in 5th gear?
    These all effect what ratio would be ideal.
    Let me know what you decide.
    JP
    Jun 2008
    sterling, va
    2002 525i 1992 325i
    do you have anything for an e34 530i?
    Michigan
    2005 BMW 330I ZHP
    Quote Originally Posted by ditaniumm3 View Post
    Tell me what you are looking for.
    What ratio do you want? Open diff? Limited Slip? does the car have any other mods? Manual? Auto? turbo or supercharged?
    jp
    Nov 2011
    White Rock, BC
    1991 525i, manual
    You have a diff for a stock 91 525i, manual tranny, open or lsd, 3.23 ?
    Michigan
    2005 BMW 330I ZHP
    Quote Originally Posted by iceneweb View Post
    Nothing like that in stock right now.
    JP
    Jun 2010
    Delray Beach, Florida
    E36 Stancer Dancer
    Any 3.73 LSD from an E30 or anything e28 or e30. I'd prefer the 3.73 but pretty much it's whatever comes first.
    PM me a price shipped.
    Thanks!
