Data logging question.....
I did some data logging tonight and noticed that I am hitting 100.0 load% by 6200 rpm but my MAF readings continue to climb upward to my 7200 rpm redline. At 7100 rpm I am getting 432 gms/sec.
How is this affecting my fuel and ignition? Should I try to adjust the orientation of the MAF so that 100% happens closer to redline?
Any ideas?
