Results 1 to 16 of 16
Thread: Riddle Me This: Gas Door Won't Lock
    Jan 2006
    Perry, GA
    E36 M3, X5 4.6is, E85 Z4
    My car is a 1998 M3/4 (9/97 build) and I've owned it since May 2000. The problem I'm having is a minor one and it's been "broken" for a long time. I've just finally decided to do something about it.
    The little pin that locks the fuel filler door won't extend and lock the door. I did some troubleshooting the other day and this is what I know so far:
    If I extend the plunger on the actuator by hand, it will retract when unlocking the doors.
    It doesn't matter if I use the remote control, key in the door, or button on the console - the plunger will not extend to lock the gas door.
    I extracted and disassembled the actuator and it's remarkably simple; just a plastic box with a motor and worm gear inside. I applied 12V directly to the motor and it runs in both directions just fine.
    I connected a voltage tester to the connector for the actuator and there is voltage when unlocking, but not when locking (probably should've done this first before cracking open the actuator but I was certain the actuator was the problem).
    Looking at the wiring diagram in my Bentley manual, it appears that the gas door actuator is on the same circuit as the door lock and trunk lock actuators and doesn't have any separate fuses or relays. And everything else works fine.
    So, why would there not be any voltage going to that particular actuator on a lock command, but there is for unlock?
    1998 ///M3/4/5 | 1999 528iT | 2003 Z4 3.0i
    West Chester PA
    Widebody 95 & 97 M3s
    I have the exact same issue, would like to know the answer to it!
    Jan 2006
    Perry, GA
    That makes two of us!
    Mar 2006
    Bay Area, CA
    '97 Hellrot E36 M3 coupe
    +1
    Copperas Cove, TX
    GMT400 Z71
    Good job on the PMCS. My fuel door lock could have been broken for the entire time that I owned my M3 and I never would have noticed it. Good luck fixing it.
    Lake Orion, MI
    a white one
    Bad actuator? Did you check to see if the input voltage to the actuator was present and correct during both unlocking and locking? If the signal is right, the only thing that can be wrong is the actuator.
    Jan 2006
    Perry, GA
    I did check for voltage at the actuator. There is none when locking. But there is voltage for unlocking. The actuator works. I applied voltage directly to it in both directions. It will lock and unlock when I hotwire it.
    Hence my confusion. Why would there only be voltage in one direction when every other actuator works and they are all on the same circuit? Unless they're not on the same circuit.
    Oct 2003
    Ridgewood NJ
    1998 M3
    Same issue as well. Been like that as long as I've owned my 2nd M3.
    Apr 2006
    CT
    1996 M3, 2000 I30
    I had the same problem when i got my car....i put a strong magnet on the inside of the door and its held up great, no problems the last 4+ years
    09 135i
    Stock
    96 M3 (Sold)
    Stage 2 AA C-38 S/C, M50 Manifold, Dinan BBTB, TMS Headers, AA Track Pipe, UUC System U
    Bilstien shocks, H&R springs, TMS Limiter kit, UUC Evo SS, Southbend stage 2, JB Racing FW
    Feb 2008
    Atlanta/ATHENS(UGA)
    1995 M3 Avus Blue
    gots the same problem. Subscribed
    BKLYN, NY
    98 M3/4/6, 16 M3/6
    just replace the actuator.
    Jan 2005
    Gold Coast
    BMW E39 M5
    Quote Originally Posted by hc1001 View Post
    there ya go... check fuses in the rear as well i cant recall which one it is but those blow typically when the actuator goes bad.
    01 BMW ///M5 DINAN
    Nov 2007
    San Diego, CA
    01 740iL, 87 560SL
    same here
    Hi Guys, sorry for resurrecting an old thread but I have the same problem. Replaced the actuator, still no luck. And on top of it, the alarm won't engage anymore either. I get the turn signals to indicated locking but no alarm function, no engage chirp.
    Anything else I could do/check?
    Thanks,
    Adil
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Pull the actual alarm brain. (usually tucked up behind the glove box) Check all fuses and connections.
    Herndon,VA
    97 M3
    Funny, I didn't even know my car HAD a locking gas cap till I pulled the carpet out of the way inside the trunk. Mine's not working either. Not even sure how to activate it. I did manipulate it manually and the pin doesn't stick out which leads me to believe someone snapped the pin off.
    Nov 2022
    San Jose, CA
    2000 Z3
    Sorry to necro this thread, but did anyone ever figure out this issue? I see +12V but not -12V on my gas cap actuator connector (2000 Z3). Actuator can be moved in both directions by a 9v battery.
