Page 7 of 40 FirstFirst 123456789101112131415161732 ... LastLast
Results 151 to 175 of 977
Thread: How to install DIS w/ EasyDIS v44 step-by-step
  1. #151
    Feb 2010
    Augsburg, Germany
    M3 E46 Cabrio
    So now I have coding/programming working also, it was straight of the bat once I selected Fister as profile with vm off.
    Perhaps this should be emphasized more in the READ THIS FIRST guide that this is the settings not only for ADS interface but also for a serial BMW modified KL interface like the EBAY do-it-auto INPA interface.
    Thanks Katvis for the tip.
  2. #152
    Jun 2008
    California
    E46 M3
    Do you have the wire schematic for powering on the E31's On Board Computer?
  3. #153
    Oct 2007
    milwaukee, wi, usa
    750 IL 1990
    E31 OBC wiring
    u can download the Diagrams by year here: http://e38.org/e31/
    that should tell you how to hook a OBC up on the bench??
    or am I misunderstanding your question?
  4. #154
    Nov 2009
    USA
    2000 328Ci AW
    VMWare 6.0
    Hi guys
    Does anyone have a good link to download VMWare 6.0? I want to use this version as used in the how to install DIS/GT1 and follow it exactly as outlined.
    Thanks in advance
    Mark
  5. #155
    Nov 2009
    USA
    2000 328Ci AW
    DIS/GT1 installation question
    hello Randomy:
    I am working on getting my DIS/GT1 up and running and am using your step by step instructions. I wanted to ask you, when you get ready to power up the vmware GT1, it was so fast that i saw it installed the DIS software on the computer screen and other things just passed by too fast to read. In this case, do i need to start all over again from the start? After this, i was able to get into the BIOS practicing a few times by pressing ctrl+ alt+ delete and then i would depress F2 and get into the bios. Your instructions say that the computder should reboot and then the installation of the DIS begins, but mine did not do that. I also encountered problems with modifying the "other vmware configuration file" as DavidMc's instructions say as it would not let me access my virtual GT1 file and thus removing it and reinstating the file to its original state enabled me to be able to access. What should i do?
    Thanks,
    Mark
  6. #156
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    Mark, you have email, this question has already been answered in the forum.
  7. #157
    Nov 2009
    USA
    2000 328Ci AW
    Quote Originally Posted by David Mc View Post
    David
    Even without the quote marks, i get the same issue.
  8. #158
    Dec 2007
    E70 3.0sd E21 323i
    This is a direct copy of my Vmware Configuration file (which works with XP SP3):-
    config.version = "8"
    virtualHW.version = "6"
    scsi0.present = "TRUE"
    memsize = "256"
    bios.bootDelay = "5000"
    ide0:0.present = "TRUE"
    ide0:0.fileName = "Other-000002.vmdk"
    ide1:0.present = "TRUE"
    ide1:0.fileName = "D:"
    ide1:0.deviceType = "cdrom-raw"
    floppy0.autodetect = "TRUE"
    ethernet0.present = "TRUE"
    ethernet0.connectionType = "custom"
    ethernet0.wakeOnPcktRcv = "FALSE"
    sound.present = "FALSE"
    sound.fileName = "-1"
    sound.autodetect = "TRUE"
    svga.autodetect = "TRUE"
    pciBridge0.present = "TRUE"
    mks.keyboardFilter = "allow"
    displayName = "BMW GT1v44"
    guestOS = "other"
    nvram = "Other.nvram"
    deploymentPlatform = "windows"
    virtualHW.productCompatibility = "hosted"
    tools.upgrade.policy = "useGlobal"
    ide1:0.autodetect = "FALSE"
    floppy0.fileName = "A:"
    extendedConfigFile = "Other.vmxf"
    ethernet0.vnet = "VMnet1"
    ethernet1.present = "TRUE"
    ethernet1.connectionType = "custom"
    ethernet1.vnet = "VMNet1"
    ethernet1.wakeOnPcktRcv = "FALSE"
    ethernet2.present = "TRUE"
    ethernet2.connectionType = "custom"
    ethernet2.vnet = "VMNet1"
    ethernet2.wakeOnPcktRcv = "FALSE"
    isolation.tools.dnd.disable = "TRUE"
    isolation.tools.copy.disable = "TRUE"
    isolation.tools.paste.disable = "TRUE"
    ethernet0.addressType = "generated"
    ethernet1.addressType = "generated"
    ethernet2.addressType = "generated"
    uuid.location = "56 4d e9 e9 c2 f8 b1 ed-1b 50 a6 15 57 19 8a ca"
    uuid.bios = "56 4d e9 e9 c2 f8 b1 ed-1b 50 a6 15 57 19 8a ca"
    ide0:0.redo = ""
    pciBridge0.pciSlotNumber = "17"
    scsi0.pciSlotNumber = "16"
    ethernet0.pciSlotNumber = "32"
    ethernet1.pciSlotNumber = "33"
    ethernet2.pciSlotNumber = "34"
    ethernet0.generatedAddress = "00:0c:29:19:8a:ca"
    ethernet0.generatedAddressOffset = "0"
    ethernet1.generatedAddress = "00:0c:29:19:8a:d4"
    ethernet1.generatedAddressOffset = "10"
    ethernet2.generatedAddress = "00:0c:29:19:8a:de"
    ethernet2.generatedAddressOffset = "20"
    checkpoint.vmState.readOnly = "FALSE"
    checkpoint.vmState = ""
    tools.remindInstall = "TRUE"
  9. #159
    Nov 2009
    USA
    2000 328Ci AW
    Thanks David for the VMware pointers and i fixed the issue i had with the line that had to be added to the configuration file of the vmware. I managed to get through the DIS installation, but at the end of the installation i get the following message:
    "THE DIS Installation has been completed with faults. Fault code 250" I used the GT1 file i had on my computers hard disk. I did make a copy on DVD. I make mention of it just in case it may have to do anything with this. Where do i go from here? Try going back to daemon tools, and mounting the GT1 file from DVD?
    I went ahead and powered off the virtual machine and restarted it. System loads and shows the white dotted dislpay (llooks like a roof of a house) and say : The system is coming up please wait. It loads the DIS screen (front end picture of a BMW) and i decided to select installing the software again to see what happens. UPDATE: The second installation of the GT1 files ended up the same, with the same 250 fault code.
    Thanks,
    Mark
  10. #160
    Dec 2007
    E70 3.0sd E21 323i
    The DIS base program has not loaded correctly or has not fully loaded, you need to reinstall DIS from the CD.
  11. #161
    Mar 2010
    Tokyo Japan
    E46 318i M43
    Hi
    Finally I could install both DIS and INPA and also ordered a Chinese interface
    everything was fine I can diagnose and also can erase the error codes and check lot of parameters however in DIS I have one problem
    DIS found two problems about my transmission and when I click on arrow botton I get this error has anyone seen it before or any idea about it
    * I am using 20 pin interface
    **sequence of pictures are from 1 to 5 and the error is pic 3,4 and 5 ( it is a 3 page error)
  12. #162
    Dec 2007
    E70 3.0sd E21 323i
    This question has been cross-posted.
  13. #163
    Mar 2010
    Tokyo Japan
    E46 318i M43
    what does it mean?
  14. #164
    Nov 2009
    USA
    2000 328Ci AW
    SCO Openserver Loging?????
    Quote Originally Posted by timoa View Post
    but where can I download this SCO OpenServer 5.0.7. I found some sites, but not sure, which programm or update or etc is right for me...
    I just turned on my virtual machine and just below the message "The system is coming up Please wait, it says:
    SCO Openserver(TM) Release 5 (gt1ap) (tty02)
    login:
  15. #165
    Dec 2007
    E70 3.0sd E21 323i
    It is asking you to login to the root system, there is a problem with your DIS Base installation that is causing it to fail to boot. If you have not saved a snapshot of your system, re-mount the DIS Base installation disk in your CD drive and re-start the virtual machine to re-install the base program.
  16. #166
    May 2010
    Osceola, IN
    2000 BMW 328i
    Quote Originally Posted by Steamyrotter View Post
    C.
    Spot on mate.
    I See where i went wrong
    Didn't use the set option (as i didn't look for it lol)
    Many thanks.
    So you were able to get this up and running on a Windows 7 64bit machine? This is what I have as well and just want to make sure it's possible before I buy the cables and put in the time. And you're using the Carsoft cables, right?
  17. #167
    UK Sheffield
    2004 bmw 330d
    Im so weary about the chinese interfaces since I read that guy whos yellow box just burnt half way through the coding process
    Ended up costing up a bit a ton ! !
  18. #168
    Feb 2010
    UK
    E39,E53
    Quote Originally Posted by jvidamin View Post
    Yep. Carsoft cables & CS6.2 under WIN7
    INPA under WIN7 (But both run in XPSP2 Compatability mode)
    DIS under VMWARE on WIN7 shell.
    Works OK but make sure you follow the instructions within this thread.
    Tkes a couple of times before INPA will connect but once it does it is quite bulletproof.
    Gave up under WINXP mode (glad i did!)
  19. #169
    May 2010
    UK
    2001 BMW M5
    Hi All,
    First post here, but i'm a regular on M5Board, and i'm in desperate need of some help.
    I have the problem that i'm trying to install Easy DIS to a netbook, i.e. a laptop without an optical drive, and this is causing all sorts of problems. Windows XP BTW.
    I'm using VMWare 6.5 too, but this doesn't appear to be a problem, and i seem to have been able to make all the setups as per the guide using it.
    My problem comes with the install of the base program.
    I have tried numerous methods to mount the .nrg (and i've tried a convertion to .iso too) as a physical drive, then set vmware to use the physical drive as the cd, and then 'boot from cd' in vmware. This includes magiciso, deamontools, and xp's own version.
    Once i start the vmware, i simply get the message that i do not have an optical drive, and the vmware goes black screen.
    I thought i had cracked it with 'MagicDisc' which is a virtual cd drive, installed this, mounted the base iso on the virtual cd drive, selected this virtual cd drive as a physical drive in vmware, started the workstation, cd as first boot device with no errors, and then just a black screen, and it trys to attempt to boot from network.
    The Virtual CD Drive (Click To Enlarge) With the Easy DIS v44 Base ISO mounted
    The VMware Settings (Click To Enlarge)
    The VMware BIOS Settings (Click To Enlarge)
    The Resultant Load Attempt from the network (Click To Enlarge)
    I really have no ideas now, and i desperately hope someone can help
    Matt
    2001 E39 M5
  20. #170
    Jun 2008
    Denver CO
    96 328i, 07 E91 328xi
    I have been able to do this on a laptop without using the optical drive, but I used daemontools to mount the NRG files instead of magicdisc.
  21. #171
    May 2010
    UK
    2001 BMW M5
    Quote Originally Posted by randomy View Post
    Oh I tried it with Daemontools first as per the guide, and then tried the other programs afterwards when it didn't work
    Anyone any ideas on what i could try next? Or what the problem might be?
    Matt
  22. #172
    Nov 2009
    USA
    2000 328Ci AW
    Inpa
    Quote Originally Posted by StreetDragster View Post
    Matt
    That is kind of strange as i also use Daemontools and worked perfectly.
    Regards,
    Mark
  23. #173
    Dec 2007
    Anaheim, CA
    2002 M3 Cabrio
    Hi All,
    Matt
    2001 E39 M5
    Did you enable the virtual drive? once you mount the iso, do you see it in your my computer folder? or you can select the iso file on this screen
  24. #174
    Dec 2009
    Rocklin, CA
    '02 540i/6, '14 F10 535i
    need serial# for vmware
    Hey guys,
    I'm having problems getting the keygen to work on vmware. It asks for encryption password. Please help.
    I've got everything working, now if you guys could tell me which cables I need. I have a serial cable that will plug in to an OBD2. Will that work?
  25. #175
    May 2010
    UK
    2001 BMW M5
    Guys, thanks for all your help!
    I believe i have fixed my issue, although the car is in the body shop so i can't go out and test the connection just yet.
    Here's what i did..........
    First of all, i redownloaded the trial of Daemontoolspro, and i also got hold of Version 6 of VMware for simplicity.
    I then install it all on my desktop, to check the files weren't corrupt, and it all installed fine, as expected (Vista)
    So, i then turned to the netbook (XP), and install daemontools first.
    I noticed no virtual drive avalible on loading the software, so i tried to add one, and got a "Daemon tools pro error -1", which is a driver problem.
    So i followed THIS websites guide to correct the driver problem, i actually did it twice, once to remove the driver, and once to reinstall, and this allowed me to create a SCSI virtual drive in daemontools, and mount the BASE.nrg file.
    So then it was over to VWware, and following the guide, the install went as described.
    Massive thanks to all!
    Matt
