Page 39 of 40 FirstFirst ... 14293031323334353637383940 LastLast
Results 951 to 975 of 977
Thread: How to install DIS w/ EasyDIS v44 step-by-step
  1. #951
    Apr 2017
    台灣
    2002 BMW E46
    I need help
    My computer is win10 64 VMWARE15
    Stay in the systen is coming up please wait.............
    留在系統即將到來請等待.............Attachment 638103
  2. #952
    Dec 2014
    Stuttgart, Germany
    One Too Many
    Are there any new guides with links? This is all down.
  3. #953
    Mar 2017
    burbank, ca
    2004 bmw 645 ci
    heres the link for your GTA1 files. Make sure and follow the OP's directions on page 1.
    https://mega.nz/#F!qK4V0KZD!CA2ljfjmO1L6xoKRbU-mRw
  4. #954
    Jun 2017
    Los Angeles, CA
    BMW M3
    awesome! appreciate the info
  5. #955
    Nov 2018
    bay area, ca
    02 325i
    thank you eriknight! finally got it working on my computer.
    for fresh installs of GT1/DIS, you need to install INPA. make sure that works and talking with the car before moving on to install GT1.
  6. #956
    Feb 2018
    Zimbabwr
    bmw 325i
    Hey guys, i installed DIS running on a virtual machine. My diagnostic head however does not get recognized from DIS or SSS. Its likely my EDIABAS file or virtual machine isn't set up right. My Car been sitting for 5 months on a DME swap. help please
    m sure its a small fix via teamveiwer
  7. #957
    Apr 2019
    sedro woolley wa usa
    99 bmw 328i
    hopefully im not out of place here. is that what I would use to reset my throttle on a 99 bmw. from my understanding I need to reset it if I replace it. Is it difficult to use these programs and where do I purchase? thanks.
  8. #958
    May 2019
    Slovakia
    1993 E36 316i
    Can someone provide a working download link for easydis v44 and VMware 6 / 6.5, maybe even inpa 3.x?
    Thanks.
  9. #959
    IL
    2000 740i sport
    Anyone have any issues connecting on a windows 7 32bit machine using a true serial port cable to an OBD2 car? I copied my setup from my windows xp machine that worked fine and even went back over DavidMc read this first pdf and I am still unable to get ifhsrv to apply the IP and connect to the car. I have ediabas configured correctly for IP and port as well. INPA works perfectly...
  10. #960
    IL
    2000 740i sport
    Nevermind I win... Windows7 ultimate required me to manually apply the IP to the windows side of the tcp/ip v4 connection for the VMnet adapter in the network and sharing center. After this the API Test passed and I was able to communicate with the car using gerts serial cable successfully. It appears windows xp automatically assigned the IP or it's been so long that I missed this step...
  11. #961
    Jul 2019
    Ireland
    e36 318iA,e34 540iA,F21
    hi. iv tiny ads interface and dis v44. DME reads ok, but cant read EGS.
    how to fix this ? :|
    edit: e36 318 m43 1994, 4l30e automatic gearbox
  12. #962
    Jul 2019
    Ireland
    anyone ?
  13. #963
    Aug 2019
    malaysia
    1995 E36
    Quote Originally Posted by 318ia View Post
    Can i know do you able to access all other module with DIS? im asking because im also have early model E36
  14. #964
    Jul 2019
    Ireland
    hi
    no, just DME.
    this car has no ABS or airbag
  15. #965
    IL
    2000 740i sport
    Is your ediabas.ini set to ADS and did you run ADSSetup.exe which is only required once?
  16. #966
    Jul 2019
    Ireland
    exactly
  17. #967
    Aug 2019
    Estonia
    E30 E32 E36
    Hello everyone.i have similar problem with same interface as 318ia.i can read all other modules exept egs module.i am using dell d630 wich has some wierd com port or something.replaced ads32.dll file with specially for dell computers modified ads32.dll file.changed so much that now i can read zf 5hp18 egs but not older gearboxes such as e32 4hp22 or e36 325td wich has gm automatic.dis v44 says something like no module found
    Make sure it is installed...etc(exactly same error as pictured by 318ia).any ideas please.
  18. #968
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Quick question. I’m on the last step (installation under administration). If this works, am I going to have to go through this set up every single time I want to use the program?
    Reason I ask is because the few times it froze I had to start over and each time I started over I could get a little farther. Will this be locked in once I get through the last step?
    EDIT
    after pages of reading i got it working, corrected all my issues and passed my vanos test. Thanks.
  19. #969
    North Carolina
    1988 325 Super ETA
    I can't seem to find the files for download, seems all the links are dead. Does anyone know where to get them?
  20. #970
    May 2009
    Pittsburgh, PA
    Pm me your email I’ll send you what I have saved. Somehow I got it working and it’s 99% English
  21. #971
    Dec 2014
    Suomi
    1988 BMW 320i 2D sedan
    Quote Originally Posted by Michalp View Post
    Thanks.
    I would like to have these too...
  22. #972
    Dec 2014
    Suomi
    i had dis v44 but my hard drive broke and all got lost. cant find working dis or vmware 6.5 anywhere. Ista D would be nice too beacause that works on obd one bmws too? so can someone put links where to dl?
  23. #973
    Mar 2020
    Tours, France
    1992 BMW 520i
    I may have found a link where to download DIS v44. https://www.beemerlab.org/2015/07/wo...on-simple.html
  24. #974
    Feb 2009
    Arizona
    1998 e36
    did you get it working and how?
  25. #975
    Feb 2021
    UK
    Z3M Coupe S50 Engine
    Hi
    Like many I'm having some problems with my install, I've read several sets of instructions and searched a lot but to no avail yet.
    Any help would be much appreciated.
    I managed to get Easy Dis up and running and also to install VMware.
    error is when the black "system is starting" page is displayed:
    portmapper on server 192.168.68.30 is not responding
    Easy DIS tries to start, displays this error and then goes to a blank screen but with the mouse cursor showing (previously it had loaded up)
    I've been going into the scoadmin page of Unix and trying different network adapter configurations to no avail.
    I tried to look at one of my Intel network adapters on windows device manager (windows XP) and the added a new network card with matching bus and device.
    This is on a Dell Latitude D505 laptop...
    Driving me nuts!!!!!!!!!
    Any pointers??
