It is still valid. Not sure about Windows 10 but on 7 there no problems.
Sent from my GT-N7000 using Tapatalk
Hi!
I just installed DIS v57 and I noticed that it contains only E36 engine version since 1998 (S50B, M52B). Where is earlier engine versions (M50B) and how can I find / get them?
This is because you have identified the car manually - if you return to the previous screen you should have options to identify earlier variants.
Yes, I identified the car manually (E36) and after that will appear this screen. If I go back to previous screen, I return back to screen where have to choose again bodytype (E30, E36 etc.). All cars what I get are since 1998. Does this have anything to do with INPA (5.02) / EDIABAS (6.4.7) configuration or missing me something on this DIS v57 package?
I also tried DIS v44, but the result was the same.
My car is 1993 BMW E36 325i Cabriolet.
Nothing is missing, scroll the slider on the right hand side of the MODEL column right up to the top and select All Models before 1998.
Hi and thanks!
My problem found. Connection to IFHSrv was not ok, so it was a configuration problem. Now I get all tests from that menu.
Hello, i have the following configuration
Asus laptop with windows 8 on it.
I have the cable for inpa.
I installed VMWare professional with 2 virtual machines -> 1 virtual machine with windows XP on it -> Installed INPA and NCS, everything is working perfect
-> another blank virtual machine with all the modifications made in order to install DIS (remove soundcard, modification of network cards and so on). I downloaded dis base and i tryed installing it by mounting the image on windows 8 and boot it from virtual machine, or by booting directly from the image. Made the modifications in BIOS....but i am stuck to the message "Dump not completed. Safe to shutdown or restart" and the instalation does not start
Can anyone help me install DIS??
Thank you!
Is it possible to update bmw modules softwares with DIS?
The problem with attempting to update module software is that BMW's software is not backward-compatible, so if a car has been updated using PROGMAN or ISTA, you can no longer update it using DIS v44. Since v44 was released over 10 years ago, unless you have a car that is a barn find or has never been to the dealer in the interim, it is likely that it will already have been updated using a later product.
What about V57 and bmw using ADS?
V57 has no coding or programming functionality - it is diagnostics only. SSS Progman was used for the coding and programming side.
What about V44? Are there any useful links or manuals about coding in V44?
David
I downloaded the 5 DVD set and I'm trying to install trouble is inpa easy is in German when I do the English path then inpa in English but the rest is in German
I also have inpa FX90 and above but the program installs in English but the EDIABAS is 7.3.X
I have an E38 1995 so problems with DIS 44 not working as the EDIABAS version not supported
Do you know where I can get EDIABAS version 6.4.7 (I think)in an English format as my German sucks
EDIABAS v6.4.3 (came with INPA V3.01/4.4.7) or EDIABAS v6.4.7 (came with INPA v 5.00 to v5.02) will support DIS v44 - I have PMed you with a link.
Q DOS to the support from David MC always there to Support
Heads up DAVID and the rest of the support team
Hi, can someone PM me a link to download DIS v44? I tried the 4shared site, but not all the parts of the .rar file were there, hence giving me a corrupt file when extracted.
David Mc, if my laptop has been previously configured to use ADS interface, is it possible to use STD:OBD function also? If yes, what exactly should I do? I've already installed obd interface drivers, edited ediabas to STD:OBD and also installed OBDSetup.exe. And can I use DIS with OBD interface? (It works with ADS)
All you need to do now is to run OBD Setup.exe from c:/EDIABS/Hardware. It should all work fine.
I did that. Is there anything else?
Sorry to ask, but what post in here should I look at for the most current installation instructions for Windows 10?
I just want to make sure I'm using the most current one.
I found a bunch on google, but the download sites are full of malware and there's so many revisions of the software and install instructions.
1997 BMW 328i | E36 Solo Werks S1 Coilover Review
fifteen52 - Project ST
Anyone have a current preference on setting up the interface with DIS, EasyDIS or whatever? I have DIS and EasyDIS working fine but haven't been able to set up a connection to the car. I have a carsoft cable but on the software side it didn't appear the same as others have got. Even though its marked as the same version. Any write ups I can look at other then what is most readily available?
I'm hoping someone here could point me in the right direction.
I have a Mac, running Windows XP via Parallels, and have installed all of the software and followed the steps from the PDF as well.
INPA works, connects to the car, communicates no problem. When I run DIS v57, all is good until I click "Diagnostic Head". When I click this, DIS mouse pointer turns to an hour glass and the software becomes unresponsive. I have IFHSrv32.EXE and DiagHead running prior to opening vmware. I have triple checked settings and everything seems to line up with the instructions. Does anyone know what I'm doing wrong?
BTW this is my second attempt, I also tried with a Windows 7 OS and had the same issues. I thought it would work better on XP but still not!
From where did you get instructions telling you to use diaghead.exe? I would expect that attempting to run DIS on a Mac with vmware would be fairly resource-hungry, but further complicating the process with a diaghead emulator would probably grind it to a complete halt.
