Page 29 of 40 FirstFirst ... 4192021222324252627282930313233343536373839 ... LastLast
Results 701 to 725 of 977
Thread: How to install DIS w/ EasyDIS v44 step-by-step
  1. #701
    May 2012
    Owasso Oklahoma
    Multiple e46s
    Booting VM to BIOS
    I haven't seen this mentioned yet but if you go to the menu on the VMWare, "VM", goto "Power" and then you can power on the machine into the BIOS without trying to hit f2 so quickly.
  2. #702
    Nov 2012
    Doha, Qatar
    2006 X5 4.8is
    Hi all,
    Is it possible to diagnose air suspension with this Easy-DIS?
  3. #703
    Mar 2012
    ky
    2000 bmw 528i
    ive instaled dis but when i get t the root screen with login then password it wont let me type my password it does nothing but i can type in root this is my holdup is there a configuration file where i can manualy put 192.xxx.xx.xx diaghead
  4. #704
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    Quote Originally Posted by maverick831 View Post
    Bear in mind that the root directory is written in UNIX so it is case and space-sensitive. The password you use to access the directory the very first time is the one you must use to access it on subsequent visits.
    I don't know of a back door to configure your system other than via this directory, but there is a way to reset your password if need be.
  5. #705
    Mar 2012
    ky
    2000 bmw 528i
    Yes how do you do the password reset but I think I might be at the same position again at the login screen it wont let me type any letters in the space at all I never did put in a password to begin with.
  6. #706
    Sep 2010
    england
    1998 bmw m3 coupe smg
    iirc when you type the letters of the password you dont actually see anything on the screen,just incase you didnt know.
  7. #707
    Dec 2007
    E70 3.0sd E21 323i
    It lets you type the letters all right - it just doesn't show the letters or move the cursor, so if you chose the appropriate option and typed a password originally, then hit [ENTER], then that is the password that has been set.
  8. #708
    Mar 2012
    ky
    2000 bmw 528i
    Thanks guys didnt know about the password i finally got logged in and im still making a go at it I have this anoying beep followd by = In the root I domt know whats up with that but thats my password crazy hugh im having to count until I think I have enough of them then hit enter and im logged in so far I have the bottom lights on but not the top ones in the far right corner I believe it the interface.
  9. #709
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    OK it's late and I did not read all 29 pages of replies to see if someone else has this issue,
    Win XP, Dell D610. Everything is unerstandable on the instructions on page 1, but when I go to the BIOS and set CD-Rom as the primary boot device, and save, the VM machine does not look at it, it goes to the three networks instead and finds nothing. I am using Daemon Lite, is that an issue? Have tried for the last 5 hours with no luck.
    If this is the easy way of installing, what's the hard way?
  10. #710
    Nov 2012
    Doha, Qatar
    2006 X5 4.8is
    The easiest is just to set VM to use iso image as CD drive.
  11. #711
    Oct 2012
    Germany
    E39 540i 6-Speed MT
    Do I need to use Diag Head Emulator with easydis? I have an OBD cable which works perfectly with INPA already.
    What are the next steps to get DIS to recognise the Diagnose Interface?
    I succesfully installed DIS as described on page 1 and I already configured the Net Configuration in VMWare. What are the next steps?
  12. #712
    Nov 2012
    Austin
    n/a
    will DIS V57 work on bmw 2013 128i? My concerns is being able to register my own battery instead of going to the dealership and whipping out loads of cash.
    I ended up asking questions about BMW DIS v57 | BMW PROGMAN V32 | INPA Package on their website in regards to purchasing. This is my response.
    Just wondering, will there be support for 2013 128i in the future?
    On Nov 15, 2012 3:44 PM, "Chris Pointon" <turbodiesel1973@hotmail.com> wrote:
    Hi,
    Unfortunately this software will only work with BMW's upto 2009 year.
    With a 2013 model vehicle, your only option is to take it to a BMW Dealer.
    Regards
    Chris
    OBD Software UK
    Hi,
    No, BMW have changed their diagnostic protocol, access to these vehicles can only be made with an authorised connection to the BMW server in Germany, and therefore unavailable to owners outside of the BMW network.
    In short, BMW have now made it impossible to work on their new vehicles unless you are a BMW dealer.
    Regards
  13. #713
    Mar 2012
    ky
    2000 bmw 528i
    I cant get anywhere i have a endless beep followed by the equal symbol (=) its keeping me from making accurate inputs i uninstaled everything and started back over thinking i might have a bad cp or file its in the root in vm when checking ips and the ediabas.ini both ways says new file any ideas.
  14. #714
    Aug 2012
    GA
    2000 740IL E38 04/99
    I spent another few hours trying to get it work and it still wouldnt. I installed GT1_v44_programs.iso in VM and made sure the VM diagnostic head is connected. The coding/programming button on the opening page in DIS is still grayed out for some reason.
    I used the clear blue cable with ft232bm chip inside. Is it the cable or the software? I need to retrieve trouble codes on the e38 so I can send the unit back to repair. Any inputs would be appreciated.
    Beauty and the Beast
  15. #715
    Dec 2004
    Landstuhl, Germany
    97 528I, 07 328I
    I can't get pass install DIS V44.0 programs. Everytimes I hit the "Installation" under DIS, enter password "12345"...I get "Fehler! Das eingegebene Passwort ist falsh. Fehlernummer: -34"...Any ideal? Thanks
  16. #716
    Sep 2012
    USA
    EE05063 97 Alpine Sedan
    Is it just me or is this guide dated? Seems to me there is a new version of DIS (v57) and newer versions of the other software like INPA 2010.....and it sounds like some guys are now running this stuff natively on Windows 7 instead of Windows XP or VM?
    I downloaded all the packages but am looking to figure out how to do a more current install with the latest packages that will work with the E36. Also need advice on what cable to get. It looks like this one http://forums.bimmerforums.com/forum....php?t=1435617 is solid.
    Thanks for any help
    My M3 is 1 of 2
  17. #717
    Sep 2010
    england
    for the e36 dis v44 and inpa v3 is all you need
  18. #718
    Sep 2012
    USA
    Quote Originally Posted by jamie123 View Post
    My understanding is INPA 5.02/EDIABAS 6.4.7 is 32 bit though which would be better than the older 16 bit app. I understand the E36 doesn't necessarily make use of the improvements but from a pure application improvements standpoint I'd rather be running the 32bit version if no other reason than it should have access to larger memory pools and be quicker in some instances as a result.
    Do I have to install the INPA 3.01/EDIABAS 6.4.3 (INPA v3.01-EDIABAS v6,4,3) Full install and then upgrade to 5.02/6.4.7 using the (INPAv5.02_EDIABAS v6.4.7 UPGRADE ONLY) directory files or can one do a clean install from those files?
    Also with DIS v44, if I want to run v57, do I need to first install v44 and upgrade to v57 or can I just go straight to v57 install?
    In other words, can I follow the guide, but where it calls for DIS v44 use v57 and where it calls for INPA 3, simply use the INPA 5 files?
    Sent from my SCH-I535 using Tapatalk 2
    My M3 is 1 of 2
  19. #719
    Aug 2012
    USA
    2000 M5
    Quote Originally Posted by indianajames View Post
    I too have this same question? I have DIS 57, and would rather just use the newer version if possible
  20. #720
    Nov 2008
    Germany
    323i
    Quote Originally Posted by mackle View Post
    You entered a "Dealer Number" before, did you do it correct? Itīs your password!
  21. #721
    Dec 2003
    Orlando, FL
    14 X1 x3.5i - 16 C300
    Quick question... Can I install this on Linux? I'm dying to know if I could run this program off of my raspberry pi...
    I already checked and I saw that I can install VMware to raspberry pi, so I have faith that it can be done.... Rite? LOL
    Follow me on Instragram @bassrebel
    2003 2014 X1 X3.5i 2016 MB C300 4Matic
  22. #722
    Jan 2013
    uk
    2000 bmw 320d touring
    Hi any help please i had dis running and then followed this link
    Operate DIS to get to "expert" menu
    not allowed to show links sorry.
    now when i boot up gt1 i had to do login and password
    after a bit of reading i see login is root so used that with my password
    now i have logged in with root and my password and now have a message about copyrights
    followed by
    you have mail
    TERM = (scoansi)
    not sure what to do next as just end up with not found
    any help please ????
  23. #723
    Dec 2007
    E70 3.0sd E21 323i
    At the # type init 0 then hit [RETURN] to shutdown DIS without saving any modifications.
  24. #724
    Nov 2012
    Jakarta
    318i, E36 M40B18
    I'm success instal DIS & GT in my vmware 6 on my laptop IBM T43 (windows XP)
    what interface can I use for this? Can carsoft cable scan my E36?
    Many thanks
  25. #725
    Dec 2007
    E70 3.0sd E21 323i
    Get an ADS interface from interface4beemers.com
