Read my post on the previous page.
thanks for helping!
And sorry because of my bad english..
I'm stragling to set up it...
It's not clear to me..
Do you have msn?
yeah i think i chuse the right driver on vmware.. It's the E driver..
daemon tools just showing that for me..
when i mounted the easydis with daemon tools, it's not saveing anything, just showing in /my computer/ E: 44-fister-10 ....
but some times not...
Im having probs with this EASYDIS v44 installation, everything works fine as instructed, but in the installation screen, where i specify the dealer coder, and the adress etc, im following the instructions, but it always starts in GERMAN lang..??? when it reboots after quiting.
Anyone had this probelem?
- Select your Country, and Enter 12345 for Dealer Number. The rest of the info you can make-up
- Once you have entered the required information, click End > Quit
Awesome post, had no troubles at all setting up GT1. Now its time to get my cable :-)
Hi is there anyone in London who could help me set this up (i've spent lots and lots of hours with no sucess) I will come to you and reward you for your help! Cheers
Hi !
I have a problem... so i alredy instaled easy DIS.. it wasn't on first time, because vmware was freez so many time...
its now done...
The problem is when i do installing v44 programes after 2-5 min the vmware freezing every time...
I tryed to switc off everything else including security.. but nothing changed..
My basic system is Windows Vista on my laptop..
Anyone could help me?
Thanks!
Joe
Sorry for my English.
I have a problem when running apitest, I installed and uninstalled many times the virtual machine, I read a lot in this forum about the installation of GT1, supervised EDIABAS.INI file, it is impossible that the IS OK APITEST more error NET 0009 is common TIMEOUT IFHSERV32 also run before but I've had different errors whenever I modified Ethernet adapter to use vmnet1 not get the apitest is correct.
INPA PROGRAM communicate well with the car
Could you give me any suggestions, I'm about to leave
Windows firewall is disabled?
If your firewall is disabled, and also the antivirus
I am pretty excited to get this going, I have an old xp laptop that would work perfectly. I need to get this all installed first, and then I will start bugging people trying to figure out what cable I will need. I have a 2004 e46, and I only care about programing and resetting CEL's.
Now, my question is - can someone repost the link the the 4shared site? I was on it last night, but cant figure out where I got in there from. I have VM ware, daemon tools, and I downloaded the 3 DIS and 9 GT1 files. I will give this a shot when I get home.
Enable your email and PM's.
try now.
10 posts....10 days membership for PMs.
I got the 10 days
Do I need the 10 posts too?
Well nevermind on the password. I just needed some help to remember it. I have everything installed and working ok (I used vm7 so its a little different to install). Now, here we go. What cable do I need. I have a serial port on my laptop, and my car is a 2004 e46. If someone would go onto ebay, and link me to one that would work, I would be much obliged and buy you a virtual beer!
http://cgi.ebay.com.au/BMW-Ediabas-I...item255b5e8a23 I am very virtually thirsty.
No modification should be required and yes they do deliver beer, but not to anywhere near me (I am 30 miles from the nearest major town).
Is it possible for me to use this install with a carsoft interface? I've seen it done by sammyv
HI!!
The SSS progrming software is runing on my laptop.
I learning to use..
i know the basic things.. but i heve changed 4 of the diesel injectors on my 302d(150bhp) and i would need to programing them to the EDD, i didn't see the opcion to do that!
Can any one help for me?
Thanks!
Joe
I was installing Vmware 7 and followed the procedure as stated in the first post. Everything went smoothly. The screens were not exactly the same but so very close. Well when I got to the end of installing the program (EasyDIS) after that finished all looked well until I went to use the computer for Windows. The Unix based program would not let me. All I coud do was use the EasyDIS. I reformatted my HD and re installed windows. I started to reload Vmware again but things did not go as smooth. It seems like when I got to the point of selecting "Host Only", that never appeared. So I just continued. At the end I edited what settings I could to make the Vmware appear as it should with out the operating system.
Anyone have any ideas why the second try did not go the same as the first? Thanks.
Right I'm having some trouble as there's loads of different things I'm reading about DIS.
I've installed everything as per this thread with no problems but I can't connect to the car. I've been reading something about installing INPA and/or yellowhead emulator. What are these? Do I need to install these as well to make it work?
Thanks in advance.
