Page 38 of 38 FirstFirst ... 132829303132333435363738
Results 926 to 947 of 947
Thread: How to install DIS w/ EasyDIS v44 step-by-step
  1. #926
    Feb 2017
    Hampshire
    X5 E53
    Need your help please
    I have installed the GT1 software on my laptop and I have got as far as having the USB cable attached to the car and the two power bars come up. It it will not read any of the memory / error codes and won't allow me to recode the steering angle sensor. It is frustrating the hell out of me because I have followed the dingbats guide to the letter and it still won't work. Need help please....
  2. #927
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    If the coloured bars are lit on the DIS home screen your installation is not properly configured. You need to close the IFHSrv32 netserver and make the following changes:-
    1. Use the Admin tab and configuring touch screen menu option to enter the 12345 password and access the configure-matic main menu
    2. Use the menu options to confogure protocols so that vm is set to not run and both nsw and dsm are set to run
    3. Change the translator from Softing to Fister
    4. Again using the configurematic menu option, reset EDIABAS
    5. Finally, use option 0 to exit DIS and save your new settings.
    6. Start the IFHSrv32, then restart DIS - provided you have correctly configured Ediabas.ini, you should not see any coloured bars illuminated on the DIS home screen, but should be able to connect to your car.
  3. #928
    Feb 2017
    kent uk
    bmw
    Hi guys, wicked helpful thread but damn im struggling with DIS44. I got INPA working no problems but the past few days and now iv realised that when removing the scoadmin network adaptor and adding the new one with the 192.168.68.30 ip, when on reboot DIS44 does not load and stuck on black screen. Any help be gr8! Thanks
  4. #929
    Feb 2017
    Ontario, Canada
    2007 530Xi
    Hello everyone, does anyone have a link to download all the parts required for DIS? Thanks in advance
  5. #930
    Mar 2017
    South Africa
    BMW X3 E83 2005
    Good Day,
    Same problem here please
    I'm busy losing my nuts
    Quote Originally Posted by David Mc View Post
    EDIABAS v6.4.3 (came with INPA V3.01/4.4.7) or EDIABAS v6.4.7 (came with INPA v 5.00 to v5.02) will support DIS v44 - I have PMed you with a link.
  6. #931
    Jul 2013
    London, UK
    '01 Alpina B10 V8
    I am about to install DIS/GT1 on my Windows XP laptop. I am using Virtual Box as I couldn't find a 32-bit version of VMware Workstation that would install on this old laptop. I am using BMcables software install DVD. I see that installing SSS Progman creates a virtual machine that is 20GB in size. Regarding DIS/GT1, does it really need a VM 18.3GB in size? I may have to wipe my computer and start again as I partitioned it without regard to these requirements. Cheers.
  7. #932
    Dec 2007
    E70 3.0sd E21 323i
    Yes, DIS does require 18.35Gb of virtual drive space, forget about installing PROGMAN, it is a waste of time and effort and will not work on any car that has been updated using later software. You can code and program much more safely using NCSExpert and WinKFP.
  8. #933
    Jul 2013
    London, UK
    '01 Alpina B10 V8
    Thanks for your input. The car is from 03/2001 (E39).
    BTW, I when running the DIS/GT1 vmdk file in Virtual Box, it seems to boot up SCO ok and I get the screen message that it's starting up, but then the VM screen goes blank and I get repeated error message: 'warning utrap invalid TSS 0X0000000A'. Does anyone happen to know what problem this would this indicate please? Cheers.
  9. #934
    Jul 2013
    London, UK
    '01 Alpina B10 V8
    Deleted
  10. #935
    Southern California
    2000 M Coupe, 97 318Ti
    Been getting stuck on the part where its supposed to boot from the CD (Daemon tools mounted image). Every time I start VMWare, it will not even see the CD drive to boot but it bypass it and goes straight to try to boot from network. I already went in the bios to change the boot order placing CD drive first. I am using VMWare 6.5 with the newest version of daemon tools. Am I supposed to use Daemond lite or the pro? What else am I doing wrong? Thanks in advance
    Update - Turns out I was mounting the wrong ISO file. I was mounting the program iso instead of the base iso.
    Sold95 M3 - Ground Control Track/School coilovers | Eibach Sway bars | Powerdyne supercharger | Dinan Exhaust | WAR Chip
  11. #936
    Aug 2008
    Kangasala
    e36
    Hi, unfortunately I was not able to find out files to download, would someone send updated links where to find DIS?
  12. #937
    Southern California
    I was able to install DIS and followed the steps by Zigzag skys pdf. However after I link the kernel and during the prompt where it said "Do you want this kernel to boot by default [Y/N]" it said in the instructions to select yes. If I select yes, I will not be able to boot back up into DIS. I get a blank black screen with a cursor arrow. Am I doing something wrong?
  13. #938
    New Jersey
    95 M3;87 325;84 318
    I am also looking for the files if anyone can help out, thanks in advance!
    Quote Originally Posted by permanent View Post
  14. #939
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    I too am looking for these files, if anyone has them or knows a link please send.
  15. #940
    Oct 2017
    Italy
    320d touring e46
    Hi everyone, im New and im in trouble... In trying to install dis v44 (founded in web) and vmware 5.5 too.. On my laptop with win 7 i have many problem to update vmware, but on my desktop with win xp i have installed vmware 6 and daemon tools like this guide...
    I can create the virtual machine, i can start with dis install program, the VM say "partition 0 reboot", the VM reboot but it still blocked with black screen with cursor... If i restart the VM or i unmount tge virtual drive nothing change...
    This appen everytime i create a New VM... I hope you can uderstand my orrible english... many many thanks...
    Inviato dal mio LG-H870 utilizzando Tapatalk
  16. #941
    Dec 2007
    E70 3.0sd E21 323i
    Have a look at the DIS installation troubleshooting guide here https://www.bimmerforums.com/forum/s...6#post27153566
  17. #942
    Oct 2017
    Italy
    320d touring e46
    Hi David, many thanks for your help, im trying to find my situation in the post tuo have link but i cant find nothin like my problem... I dont understand if its an hardware of my pc problem...
  18. #943
    Sep 2013
    How do I get the softwares below? When I try to unrar those on the thread I am told volumes are missing. When I look at the download in one instance files 7 and 8 were missing.
  19. #944
    Oct 2017
    Italy
    320d touring e46
    Quote Originally Posted by Deron View Post
    Hi! I have found the ediabas 6.4.3 full in this forum, splitted in three parts!!!
  20. #945
    Sep 2013
    Hi Andrea,
    Not seeing a link. Also i want the GT1 files and Daemon Tools. Could you say where I could get those?
  21. #946
    Nov 2013
    Roamnia
    BMW E46 320D 2002 Sedan
    Create an account http://bmwcoders.com/forum/bmw-codin...4-disv57-8916/ and download files v44 and v57 . Enjoy
  22. #947
    May 2010
    Macedonia
    1997 BMW 328I COUPE
    Can you explain what was the problem and the solution?
