Has anyone removed the back splash plates behind the brake rotors? I have been told that the parking brake is attached to this part so that its removal eliminates the parking brake. True? Should this be the case it seems to me that simply cutting the plate away accomplishes the removal of what amounts to a heat retainer while keeping the parking brake.
Thoughts?
MAB
I think it is there to keep rain and other undesirable substances off the rotors. If you don't drive your car in the rain, you should be fine.
- John
Yes you cut it with a large pair of tins snips.. Cut just to the parking brake pads... slightly lower if you can. Just try not to tweak what is left because it it holds the parking brake mechanisms.Originally posted by MAB Badgerbimmer
Thoughts?
Remember though to put a new one on requires pulling the hub.
