Results 1 to 3 of 3
Thread: I'm confuse about Trans. and Dioff. fluid?
    Feb 2001
    Oklahoma City, OK
    Exclamation I'm confuse about Trans. and Dioff. fluid?
    Transmission D4-ATF how many quarts do i need?
    Differential &%W-90 how many quarts do i need?
    I'm going with redline.
    What's the different: MTL, ATF, MT 90, which is better for
    M3 street use and do I need to change both Trans and Diff.
    fluid and the same time?
    Where is good place to get redline.
    Saul
    PS or should I go with amsoil since I use it on my engin already.
    1999 Tit Silver ///M3
    May 2001
    37N 22' 122W 03'
    search the archives, plenty of info
    Mar 2001
    Nor Cal
    1996 M3 lux, 1988 325
    ATF and D4ATF are both for the tranny. Don't use either in the differential. MTL is also for the tranny. I think MT90 might be a bit thick for the tranny.
    I dont remember the capy for each exactly but If you buy two quarts for each,then you will be covered. I think the trans is like 1.3q and the diff is around 1.7q. Use the 75w90 in the dif.
    == Stable mates ==
    -1996 M3 Lux, bright red (hellrot), Modena interior. Aus Freude Am Fahren!
    -1988 325, Alpenweiss. The commuter.
    BMW HOWTOs
